Author Topic: 230 timberjack throttle adjustment  (Read 631 times)
Offline lynde37avery
  • machines from the 1970's making a living today
« on: October 20, 2014, 07:08:17 PM »
353 detroit motor. The pedal barely does anything. I have to use the hand throttle. Any tips on adjusting the pedal linkage?
Detroit WHAT?
Offline deerguy
Re: 230 timberjack throttle adjustment
« Reply #1 on: October 20, 2014, 07:47:27 PM »
 lynde37avery,
Not sure if it's of any help, but on my ol' TJ330 with a 353, I had the same problem. My issue wasn't so much the linkage as it was the hinge pin at the bottom of the pedal. It was so badly worn that the pedal had free movement in every direction but one that would rev it up !! I fixed the hinge and then only had to do minor adjustments with the linkage.
Good luck !!
Deerguy
I knew she was a keeper when she told me to buy the old skidder !!!!!
Offline David-L
  • present and accounted for.
« Reply #2 on: October 20, 2014, 07:51:39 PM »
Is this on the franklin or the Jack. If on the jack make sure the hand throttle and the foot throttle linkage is not bound up. They are connected together near the left side of the tranny which you can see. The spring should be able to put the foot throttle back in place. There is adjustment where the foot throttle linkage goes through the firewall. Give me your address and I have an extra manual for these 200 series and I will get it to you. I would follow that linkage from the pedal.
                                                            David l
In two days from now, tomorrow will be yesterday.
« Reply #3 on: October 20, 2014, 09:00:06 PM »
Yea timmyjack 230. Ok check ur msg box davidl.
Detroit WHAT?
Throttle adjustment on LT40
Started by woodhick on Sawmills and Milling
Last post March 08, 2014, 08:11:35 PM
by woodhick
Throttle cable adjustment
Started by Junior437t on Wood-Mizer
Last post June 24, 2021, 08:50:18 PM
by Magicman
adjustment of lt 40 woodmizer throttle selenoid
Started by NC Woodworker on Sawmills and Milling
Last post January 25, 2015, 05:03:05 PM
by MartyParsons
Throttle Adjustment ? 24 HP Kawi motor on my Husqvarna lawn tractor
Started by JOE.G on General Board
Last post July 14, 2012, 10:11:48 PM
by JOE.G
