Author Topic: Bandsaw mill "must have/highly desired" features  (Read 9544 times)
Offline MobileSawmillNJ
Re: Bandsaw mill "must have/highly desired" features
« Reply #20 on: December 14, 2014, 05:40:01 AM »
Totally agree with RedBeard - but I guess it really depends on what type of work you are doing.  A good portion of the work we do is with either large, live-edge slabs, or 6x6 beams for cribbing.  When we do on-site work for a client, it runs the gamut, based on their particular goals.
One tip that I found helps A LOT is to have a spotter (usually me) on the far side of the mill giving hand signals to the skid steer operator.  When I am operator, I go it alone, but whenever a helper is at the helm of the forks, I spot and direct.  So far no major foul-ups, and I've actually gotten pretty good at 'rolling' big logs onto the deck without disturbing the mill.
Offline dgdrls
  • Learning the Art of Milling Logs
« Reply #21 on: December 14, 2014, 08:33:58 AM »
One of the advantages of the dimension style mill is the fact you don't
have to move the log/cant repeatedly.  All of the Dimension style mills are
 portable, built on an end stand system and return cut material.
Of-course no mill is 100%,  depends on what you want to do.
Big wood is flat heavy (so is Hickory in any size :D),
the more power, hydraulics and roller-tables the better... to a point
at which your not really "portable" any more
search the web a bit,  lots of info out there for these types of mills
Best DGDrls
32" Crescent "C" frame bandsaw wheels for mill?
Started by markdvsmo on Sawmills and Milling
Last post November 27, 2019, 11:53:20 AM
by ljohnsaw
Seeking source for education in "sound" bandsaw mill design and construction.
Started by MikeySP on Sawmills and Milling
Last post November 06, 2018, 10:52:08 AM
by Southside
1- Twisted Sister or "Walnutz!" and 2- "Pre-Bent" or "Saw Mill Nightmare?
Started by MbfVA on Sawmills and Milling
Last post September 08, 2017, 12:33:17 PM
by MbfVA
"Magic" Boomerang Walnut Highly Valuable!!
Started by Andy White on Sawmills and Milling
Last post June 08, 2014, 08:52:34 AM
by dablack
