Author Topic: Conventional Kiln Components  (Read 1703 times)
Offline Ga_Boy
  • Been rode hard and hung up wet; more than once.
« on: March 10, 2015, 07:50:59 AM »
I understand the conditions for listing items for sale.
Kiln Components for sale.  Will sell one package at a time or will combine all packages.  All items are in proper working order.  Can demonstrate if local to me.
Package 1: $1,900
Controller with 7 day chart recorder
RH Sensor
temp probe
USDA books on drying lumber
Package 2:  $550
Three way ball valves (2 valves available)
The ball valve is the Orange thing in the upper left corner
Pictures are in my library or can send directly to you via e-mail.
10 Acers in the Blue Ridge Mountains
Offline armechanic
Re: Conventional Kiln Components
« Reply #1 on: March 27, 2015, 10:31:18 AM »
Do you know if this would work for a Heat treat kiln for firewood ?
1989 Lt 40, D6C CAT, Home made wood processer in progress.
Offline Ga_Boy
« Reply #2 on: March 27, 2015, 01:21:29 PM »
Armechanic,
Yes, this equipment would work to control a kiln to hea treat firewood.  The best part is, the controller produces a hard copy record of the temperature.  I believe this would be of great benefit to your business.
You can show your customers the temperture their firewood was treated to and for how long it was held at that temperture.  It is also, insurance for you should someone attempt to say your fire wood was not properly treated.  All you have to do is pull the file for that run and show the hard copy record of the temperture and time it was held at the temperture.
Offline beenthere
« Reply #3 on: March 27, 2015, 02:49:27 PM »
It seems that it would be hard for anyone to prove that the chart is related specifically to any one piece, or load, or charge of wood. I'd almost say "impossible". Yes, I'm a pessimist.  ;)
Offline thechknhwk
    • Story of the Trees
« Reply #4 on: March 27, 2015, 05:32:52 PM »
Stamp the firewood lot with the date on your paper insert that states its heat treated and usda approved.  Keep your kiln logs which are also date stamped, and then it's your paper trail against their word.  You win :D
Offline Ga_Boy
« Reply #5 on: March 30, 2015, 01:39:07 PM »
It's a simple process of record keeping. Assign each kiln charge a lot number. Record the lot number ion each graph.  Record who you sell each lot number to.
A very simple process, even a pessimist could do this.
Nyle L53 kiln components
Started by j_d on For Sale
Last post January 19, 2021, 10:02:56 AM
by cabindoc
question
Conventional kiln?
Started by DanG on Sawmills and Milling
Last post November 01, 2003, 10:40:26 AM
by Den Socling
Conventional kiln venting
Started by Hokiemill on Drying and Processing
Last post June 21, 2004, 07:56:43 PM
by Don_Lewis
conventional kiln controllers
Started by Den Socling on Drying and Processing
Last post April 10, 2017, 01:13:25 PM
by Den Socling
