Author Topic: Sycamore  (Read 2376 times)
Online WV Sawmiller
    • Green's Sawmill Services
Sycamore
« on: January 04, 2016, 05:59:33 PM »
   Got a customer with some decent sycamores he's going to remove on a land clearing project. He asked me about them. I told him had not cut any yet but understood they were bad to twist and people liked to quartersaw them for figure and to help prevent twisting.
   Guy wants to build a shed from the lumber. If flat sawed into 4/4 and  nailed up right away how does it do? If sticker stacked well with plenty of weight on top does it dry okay? How is it for framing stock?
Offline kelLOGg
  • More is better but enough is best
Re: Sycamore
« Reply #1 on: January 04, 2016, 06:21:35 PM »
It so beautiful when qsawn. It seems like a waste to use it for siding and someone else will have to advise you on that use.
Bob
Offline scsmith42
    • Whispering Pines Farm
Re: Sycamore
« Reply #2 on: January 04, 2016, 08:39:06 PM »
If they are large and clear grade logs, I would be willing to trade him an equal board footage of freshly sawn SYP siding straight up for the logs.  I'd even deliver.
SYP will last much longer in the weather than sycamore (especially with a good overhang) - it tends to rot pretty quickly when used outdoors.
Tom's 3638D Baker band mill
Online WDH
  • Forester
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: Sycamore
« Reply #3 on: January 04, 2016, 08:48:50 PM »
If flatsawn, not in my experience.
Woodmizer LT40HDD35, John Deere 2155, Kubota M5-111, Nyle L53 Dehumidification Kiln, and a passion for all things with leafs, twigs, and bark.  hamsleyhardwood.com
Offline Ohio_Bill
  • Wood is Good
Re: Sycamore
« Reply #4 on: January 04, 2016, 11:56:59 PM »
I have sawn a considerable amount of sycamore over the years and would not recommend it for siding. It is very prone to rot and a lot of it has shake so the boards fall apart as they dry. Most of what I have sawn has been for ties and timbers.
Bill
USAF Veteran  C141 Loadmaster
LT 40 HDD42-RA   , Allis Chalmers I 500 Forklift , Allis Chalmers 840 Loader , International 4300 , Zetor 6245 Tractor Loader ,Bob Cat 763 , Riehl Steel Edger
Offline red
  • we will never forget
Re: Sycamore
« Reply #5 on: January 05, 2016, 12:02:45 AM »
Sycamore the other white wood
We have a lot of good boys and girls in harms way
lets all support them and their familys.
Offline Raym
Re: Sycamore
« Reply #6 on: January 05, 2016, 05:20:46 AM »
You took the words right out of my head
'14-LT40 super, nyle l200m kiln, vintage case 480E loader.
It's not the fool that askith, it's the fool that agreeith.
Offline smoothED
Re: Sycamore
« Reply #7 on: January 06, 2016, 09:54:58 PM »
I've flatsawn it and put it up green, bord and batten on 2 sheds. No shake,no rot, only a couple boards warped. 4 years so far.
Offline Skip
  • Saw hard or stay home.
Re: Sycamore
« Reply #8 on: January 07, 2016, 07:21:50 AM »
I sawed a bunch for a customer who used it as flooring in a cabin on his farm. Looked great , he put down green and used it fast and a lot of nails. still looks good 6 years later. Used to drive log truck for a friend and would deliver sycamore butts no longer than 3 ft to a furniture maker in PA who used it to make stiles for maple chair backs. You couldn't tell the difference  .The were a pain in the butt (no pun intended ) to haul. I would not recommend it for framing
Online WDH
  • Forester
Re: Sycamore
« Reply #9 on: January 07, 2016, 07:35:57 AM »
Just like people, some individuals are worse than others.
Offline sealark37
Re: Sycamore
« Reply #10 on: January 07, 2016, 08:44:46 AM »
The customer proposal reminds me of the guy who wanted his dump truck load of walnut sawed into 4/4 so he could use it to underpin his house trailer.  His logs, his project.   Regards, Clark
Offline dboyt
  • Log On!
Re: Sycamore
« Reply #11 on: January 07, 2016, 10:42:34 AM »
I offered one individual who was about to chunk up some nice walnut for firewood that I'd swap out split, seasoned oak of equal volume as the log (22" dia, 8').  No dice.  Go figure.
Norwood MX34 Pro portable sawmill, 8N Ford, Lewis Winch
Offline Dodgy Loner
  • Forester
  • It's an anagram for "dendrology" and in no way a reflection of my personality
    • My Blog: A Riving Home
Re: Sycamore
« Reply #12 on: January 07, 2016, 10:55:26 AM »
Some people just enjoy the experience of having something that someone else wants. ::)
Using Sycamore
Started by ozarkgem on General Woodworking
Last post October 13, 2014, 09:16:00 PM
by Red Clay Hound
Sycamore ?
Started by Ianab on Sawmills and Milling
Last post January 26, 2004, 07:05:48 PM
by Tom
Sycamore log's ?
Started by BargeMonkey on Forestry and Logging
Last post November 22, 2015, 09:05:46 AM
by Dave Shepard
sycamore
Started by bandmiller2 on Sawmills and Milling
Last post September 04, 2009, 09:10:12 PM
by Chico
