Author Topic: Cypress drying schedule  (Read 3322 times)
Offline Joey Grimes
  • Quality is remembered long after price
« on: October 22, 2016, 07:10:36 PM »
I have some 8/4 cypress to dry in my l53 does anyone know a drying schedule I'm assuming the schedule would be similar to pine but I'm not sure and if it's like pine am I limited to 300 bf per load ? It is not sinker cypress .
94 woodmizer lt40 HD kabota 5200 ford 4000 94 international 4700 flatbed and lots of woodworking tools.
Offline Den Socling
  • just wondering
Re: Cypress drying schedule
« Reply #1 on: October 24, 2016, 11:57:59 AM »
I was just getting ready to write that you should forget a DH kiln if it was sinker cypress. The wet pockets in that stuff are worse than any I have ever seen. Unfortunately, I can't help you. I have never dried Cypress that wasn't infected.
Offline bucknwfl
« Reply #2 on: October 24, 2016, 05:48:27 PM »
Not sure on the schedule but it has to be air dried for about 6 months before thinking about drying.  I have had about 5mbf dried and he insists it be stickers for 6 months first
Buck
If it was easy everybody would be doing it
Offline ellmoe
« Reply #3 on: October 24, 2016, 09:47:59 PM »
Buck
It can be dried, fresh sawn, but it takes more energy ( $'s ), and time.
Offline GeneWengert-WoodDoc
« Reply #4 on: October 24, 2016, 10:06:14 PM »
Kiln schedule 257 in DRY KILN SCHEDULES FOR COMMERCIAL WOODS, and then do the modification for a DH unit.  OK?
Offline Joey Grimes
« Reply #5 on: October 25, 2016, 07:38:05 PM »
Offline Joey Grimes
« Reply #6 on: October 25, 2016, 07:43:16 PM »
So if I understand correctly I use the higher temperature schedules emc to modify for my low temp dh kiln .so for over 50%mc my dB 90 wb 86 ?
Offline tmbrcruiser
« Reply #7 on: October 25, 2016, 09:17:34 PM »
I used cypress on my mill. I know kiln dried lumber isn't necessary for board and batten siding but I wanted it dried. So I sent my cypress to a close friend to have it dried in a Nyle L200. I had the lumber on sticks for about 60 days and made out fine. We sawed about 6,000 bf and have
   a lot more to cut, what a great wood.
Once you get sap in your veins, you will always have sawdust in your pockets.
« Reply #8 on: October 26, 2016, 12:32:32 PM »
Yes, The same MC ranges and the same EMC.  You could use the same RH.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #9 on: October 27, 2016, 08:11:09 AM »
Kiln operators here will not accept Cypress until it has air dried for at least 6 months.  I have not found Sinker Cypress to be any wetter than fresh sawn.
Offline Joey Grimes
« Reply #10 on: October 28, 2016, 10:20:51 PM »
From what I've heard it's not that sinker cyp is any wetter it's that it has wet pockets that do not release moisture as fast as most of the wood
Offline Den Socling
  • just wondering
« Reply #11 on: October 28, 2016, 10:53:35 PM »
The wet pockets don't want to release water period. I'm re-drying some that a vac kiln customer doing custom drying had up to 160 degrees in a vacuum and the 16/4 Sinker Cypress still had wet pockets. But I have a way. It is really hard to get a uniform 7%!
Schedule on drying in Nyle once below 25%MC
Started by Kelvin on Drying and Processing
Last post March 09, 2009, 09:31:46 AM
by Kelvin
DH Kiln drying schedule
Started by james04 on Drying and Processing
Last post March 17, 2008, 09:50:30 PM
by james04
Drying schedule for ash 6x6 below 20 percent mc
Started by forrestM on Drying and Processing
Last post August 10, 2021, 08:41:21 AM
by K-Guy
Cold maple drying schedule
Started by Lance in Ontario on Drying and Processing
Last post February 18, 2008, 11:48:46 AM
by OneWithWood
