New project
Started by maple flats, May 06, 2021, 05:49:50 PM
maple flats
I sell my syrup online and at just 1 local retail store. That store outgrew it's first location 2 yrs ago, and has now outgrown the second. The first was in an old school house with 6 classrooms, It's now in an old Home Center that went out of business likely because they lost too much business to Lowes.
At any rate, they are now moving to an Army/Navy store, likely 4x the size of their current location. For in the new location I'm planning to make a nice display using a retired oak barrel from a distillery as a base and I'll make a top using a good size slab of Oak I have. Slabs aren't real easy to make on a Peterson, but, a few years back a neighbor had 2 oaks removed from beside a highway. I wish I'd kept the measurements, but I think the logs ranged from about 24" up to 32" x 10-12' long each. The landowner had the butt logs cut in two, making 4 total, he cut the rest into firewood. My 8000# old tired excavator couldn't lift the two biggest ones onto my trailer, I got the smallest one fine, the next larger one barely, the two biggest, according the the FF log weight tool, weighed between 3300-3700#, I struggle to lift 2500. So I talked to a friend at the local stone/block yard if I could hire him to load them, He did and didn't even charge, I gave him 2 half gallons of maple syrup the next day as a thank you.
Well, as I was sawing those logs into 5/4 x 4 boards mostly, to be made into oak flooring, he had me make a slab for him. On a Peterson, you can basically make just 1 slab/log. You cut down to about 1-2" below the pith, then flip the log, and saw down on the rest until a slab remains of the desired thickness. After I did that on one log, he asked (he was tailing the saw) if I could make another on the next log, which I did, when I finished that he said it was for me. It's a slab about 22-25" wide and 2.25" thick if I recall.
Back to the store display I'm going to make (yes, I'll make it a point to get pictures) a display table using an oak barrel as a base and that slab cut into 2 pieces to make the top. Will likely make designs in the oak of some sort, before I put poly on. I do have a very talented niece who I might get to do a design If I get it ready soon enough and she has the time. This all needs to be finished before June 1.
