2" Scale Frick "00" sawmill, $5000,Not a toy.
Started by logwalker, December 12, 2005, 11:35:49 PM
logwalker
Found this last night on Ebay. I won't post the link cause it is so long. But just go to Business and Industrial and search for "sawmill". You can also plug in Item # 7572011908. Says it will handle logs 4"to 5". The bade you see is 10". Overall length is 8'. I think it is cool. Thought some of you might enjoy it.   Logwalker
Wow!  That will probably go high to somebody with a big commercial mill somewhere with lots of disposable income.  Which it was me. :-\
Murf
My problem isn't my 'disposable' income, it's the 'retainable' income I have a problem with.  ;D
Gilman
That's be neet to have.
It's up to $380 w/ 8 days left
WM LT70, WM 40 Super, WM  '89 40HD
Cat throwing champion 1996, 1997, 1999. (retired)
Corley5
DanG right it'd be  8) to have ;) but more than I want to spend in the end ;D
tnlogger
 wheres kirk now he has good luck buying and selling mills  ;D ;D
gene
Frank_Pender
I believe it belongs here on the Left Coast, David.   Let" buy it! 8)
tnlogger
frank I thought you was bidding on it  :D :D :D :D
gene
Frank_Pender
I sure would like to make a bid.  Trouble is I might win and then have to get it hauled out here, unless I can get Kirk and Furby to haul it in Kirks new trailer. 8)
Kirk_Allen
Frank I aint driving out to Oragon with my trailer and thats final  ;D :o :D  My poor Suburban wouldnt make it that far with that laod ;D
Now for this mill, I may bid on it but I will have to see where it goes in the closeing moments.  Not sure that I need another mill.  I still have the Belsaw circle mill to pick and up and get set up and I have a gut feeling after Part Timers visit this weekend I may just have to justify getting a swinger ;D
I'll keep your old mill in shape for ya Kirk! ;)
etat
The guy pulled the plug on the first auction and relisted it at a higher price.  Bidding is now up to 3,383.33, and listed as 'RESERVE NOT MET'..........
The New Ebay Item Number Is 7574459664.
Looks like Jeff was right, it's gonna take LOTS of disposable income to buy that mill, WOW.
Rockn H
Now if someone buys that Frick mill with intentions of supplying it with a load of logs from a 2" scale train model we'll know they have too much disposable income. :D ;D :D ;)
mike_van
I can't imagine this would cut a log with that no-set 10" tablesaw planer blade on it???????
Rockn H
Well, in the add, the seller did say that you may want to play around with different blades. ::) ;)
logwalker
That little toothpick maker is up to $5000. Wow. Where do you suppose that thing is going. Maybe some museum. That's where they are going to put me when I wear out. LW
footer
Wasn't someone here a while back asking about making a mill for cutting 4 to 5" logs? Whell ther you have it! No need to build one.
