Author Topic: Started assembling a new to me lane sawmill  (Read 3421 times)
Offline Ventryjr
    • The Rusty Mill
« on: May 10, 2021, 07:23:35 PM »
OI first got my feet wet with a belsaw m14.  After making some decent cuts and blowing up the power unit I had. I found a good deal on a lane sawmill at auction. With cat power unit. Log deck and log turner. I got the site work completed this spring and just started putting the pieces together.  I disassembled it myself after seeing it in operation.  So I think I remember how it all goes back haha.  Im very green at this.  Constructive criticism is greatly appreciated.  Thank you guys for the info and knowledge so far!
-2x belsaw m14s and a Lane circle mill.
Offline dgdrls
  • Learning the Art of Milling Logs
Re: Started assembling a new to me lane sawmill
« Reply #1 on: May 10, 2021, 07:44:11 PM »
Good on you!!
get those rails true!
what do you have for power now??
Best
D
Offline Ventryjr
    • The Rusty Mill
« Reply #2 on: May 10, 2021, 08:12:59 PM »
Good on you!!
Best
D
D333a.  Its a 6 cylinder cat diesel. 4.5x5.5 cylinders iirc. Has a clutch/V belt pulley setup on it.
Offline moodnacreek
  • Sawin by the notches
« Reply #3 on: May 10, 2021, 09:29:22 PM »
Well, well, well. Lane, that's my brand. And I started with a bellsaw in 1980, should not have done that but had empty pockets. So I see the V rail. Is it a green mountain or 030? I don't think it is an 036 but it could be. Hand set? What do you have for dogs? Love to know all about it and where in N.Y.
Offline Ventryjr
    • The Rusty Mill
« Reply #4 on: May 11, 2021, 05:49:27 AM »
It does have a green mountain tag on track I believe.  Yes hand set.  And I do not have a pic of the dogs specifically.  But they are cast and have lane on the side of them. And unfortunately Im in the other side of the state from you.  Western ny. But if you make it out this way PM me. Your more then welcome to come check out my setup and give pointers! :D
Offline thecfarm
« Reply #5 on: May 11, 2021, 05:56:10 AM »
Hey good luck to you!!
Offline moodnacreek
« Reply #6 on: May 11, 2021, 07:57:55 AM »
Ok, with the green paint and V rail ; green mt. The set works and the feed are the same on all the 30" mills, 'O', tractor mill, 030 and green mt. Now you can saw with the notches in the set wheel and you will like that. If you find any old 6" leather belting save it to make your next friction. Is there a big screw dog on it? Western N.Y. is less likely to have Lane than e.n.y. New England and north eastern n,y. is loaded with them.
Offline dgdrls
« Reply #7 on: May 11, 2021, 08:15:44 PM »
Western NY is pretty large,  County??
D
Offline Osterman.r
« Reply #8 on: May 11, 2021, 09:38:51 PM »
Looks good mr. I too am putting together a very similar lane mill, also started with an m14 6 years ago. Looks good, I wish I had videoed like you. Im at the same stage. Next step for me is placing the caterpillar d4400. Cant wait to see you setup in action. What was the power plant on the m14? And where did you buy this mill?
Offline Ventryjr
    • The Rusty Mill
« Reply #9 on: May 11, 2021, 09:59:52 PM »
Bought it from a gentleman in northern pa.  And if you check out my YouTube channel you can see I had a farmall m on the belsaw first then a Chevy c3500. It was a cool saw and cut some wood with it. Got my interest sparked. Then I came across this lane mill.  I just setup the belsaw in the fall.
Offline Ventryjr
    • The Rusty Mill
« Reply #10 on: May 21, 2021, 05:38:57 AM »
I Need some input From some more experienced sawyers. I currently have the mill track lagged to the wood base and where ever I check the track its either level or off very slightly.  Where the bubble on my 6ft level is touching alike and not perfectly centered.  So maybe off 1/8 between the 2 rails in 2 spots on the mill.  Is this critical? I can loosen the lags and shim it up. Or am I better off with no shims and leave it lagged down tight to the timbers? Leaving it slightly off in 2 spots.
The previous Owner told me to get it within 1/4 of level and it will be fine.  I forgot to check the level on his setup before I disassembled.   Thanks in advance.
Offline dgdrls
« Reply #11 on: May 21, 2021, 06:10:31 AM »
I suggest you shim the tracks and get them as level and square as you can.
an 1/8" here and there can add up to sawing frustration.
D
Offline nativewolf
« Reply #12 on: May 21, 2021, 06:54:03 AM »
Neat to see lots of people putting circular mills back in action
Liking Walnut
Offline Ventryjr
    • The Rusty Mill
« Reply #13 on: May 24, 2021, 05:57:11 AM »
Part 2! Its coming together.  Im in the process of building a better base for the motor. Just wanted to get everything turning before I made a permanent mount. I also shimmed the rails up a bit so its all flat.  I string lined the track and it looks good.
Question to the more experienced circle mill fellas. How do you judge how fast to feed the carriage when cutting?   The carriage seems to move really quickly when fully engaged.  Thanks in advance!
Offline sealark37
« Reply #14 on: May 24, 2021, 09:06:33 AM »
You may judge the feed of the carriage easily by the sound of the power unit.  Feed just fast enough to maintain the rpm at the governed speed.  Feeding too fast risks stalling the blade, which is VERY bad.  Go slow until you get the knack of listening to the mill.  It will tell what is right.  The carriage feed has a lot more speed than you need for sawing.
Offline Ron Wenrich
« Reply #15 on: May 25, 2021, 11:31:00 AM »
Quick comment about shimming your rails.  On some mills, if you measure your rails across the guide rail to the flat rail, you'll find the guide rail is higher than the flat rail.  The grooved wheel should fit over top of the guide rail.  When your carriage is sitting on the track, the headblocks should be level.  If you leveled using the inside track brace, you should be okay.  When the headblocks are level, and the saw hangs at a 90 angle, you should be cutting square lumber.
Offline Ventryjr
    • The Rusty Mill
« Reply #16 on: May 25, 2021, 12:17:14 PM »
I didnt check the wheel to head block. Ill be sure to do that. And I leveled from the bottom of the frame tubes and on the cross members.
Offline Ventryjr
    • The Rusty Mill
« Reply #17 on: June 03, 2021, 05:32:34 PM »
Everything was square.  Made a few cuts and produced a 2x7.5x16.   More like 2x7.5 at beginning.  And 2 1/16x 7 9/16 at the end of the 16.
Offline moodnacreek
« Reply #18 on: June 03, 2021, 06:11:21 PM »
As to the feed speed question; you feed as fast as you can while maintaining a straight line and rpm. This will take some time as you have to learn to see and here trouble before it becomes a wreck. The saw must stay cold and as another member said don't sthal your saw in the log because this may dent or worse the drive pins and tighten the nut. All a no no as it may bend the stub end of the mandrel.
Offline Ventryjr
    • The Rusty Mill
« Reply #19 on: June 03, 2021, 06:38:37 PM »
I fed pretty slow but Im busting getting a hang of the friction drive. By stahl the blade do you mean that it actually stops rotating?
assembling my new sawmill
Started by maple flats on Sawmills and Milling
Last post November 08, 2021, 10:43:47 AM
by maple flats
lane sawmill
Started by poorfarm on For Sale
Last post August 23, 2015, 08:32:27 PM
by Bystrika
Lane and a Frick sawmill
Started by Buddyw on Sawmills and Milling
Last post November 04, 2012, 07:30:03 AM
by Meadows Miller
Chase da Lane sawmill
Started by bandmiller2 on Sawmills and Milling
Last post March 02, 2008, 12:24:26 PM
by Dave Shepard
