Author Topic: Homemade circle mill sharpener  (Read 178 times)
Offline glendaler
« on: October 12, 2021, 09:14:30 PM »
Thought I'd share my latest project. I've always been terrible at making things straight or square by eye so I wanted a jig to sharpen the bits on my Belsaw. I looked at all the commercially available ones but some are quite expensive, and with the current global situation, not likely to arrive. I headed to the scrap pile and got to work. I liked the idea of the dexter file guide but figured it was exessively adjustable and I only have one blade to deal with so mine got all welded up once the angles were proper. I also went with plastic on the backside of the file against plain old bolts rather than ball bearings or hardened rollers. Anyway, been seeing a few circle mills showing up here lately I thought someone might find it interesting.
Belsaw A10 circle mill,
Offline moodnacreek
  • Sawin by the notches
Re: Homemade circle mill sharpener
« Reply #1 on: October 13, 2021, 08:34:32 AM »
The Dexter saw guide is a refined version of your jig. It is adjustable for any mill saw. The file is not attached as it is held in the other hand and it is dropped in between the pins. To bad you are far away as I have a collection of saw filers and grinders of wish 2 are Dexter's. They work good and are still made.
homemade circle mill 25"blade gets hot and dishes
Started by buildthisfixthat on Sawmills and Milling
Last post September 28, 2010, 10:19:47 PM
by Reddog
Homemade Stake Sharpener
Started by boscojmb on For Sale
Last post January 31, 2017, 01:48:25 PM
by boscojmb
Why are there more smaller Band Mill operators here then circle mill?
Started by MaddiesDad on Sawmills and Milling
Last post March 05, 2009, 03:18:06 PM
by TexasTimbers
question
sharpener for chase mill
Started by wheelinguy on Sawmills and Milling
Last post March 05, 2012, 08:13:29 PM
by wheelinguy
