Author Topic: Are small defective logs worth it? Here is how I do it.  (Read 944 times)
Offline richhiway
  • Rich
« on: December 05, 2021, 09:11:37 AM »
align the Crack horizontally
slab the log then flip 180
now you have parallel sides flip 90 and make sure it is squared
 take the best boards off the cant working around the defects
 about 30 board feet of decent maple for small projects. Better then firewood. Probably worth it for your own use. Remember quality logs kake quality lumber!
Woodmizer LT 40
New Holland 35 hp tractor
Stihl Chainsaws
Offline WV Sawmiller
    • Green's Sawmill Services
Re: Are small defective logs worth it? Here is how I do it.
« Reply #1 on: December 05, 2021, 09:34:43 AM »
Rich,
   Sounds similar to what I try to do. I get the good/useable boards above and below a big crack like that as best you can. I have even cut the bad part up for stickers but that is erratic at times.
Offline doc henderson
« Reply #2 on: December 05, 2021, 09:42:22 AM »
I love big solid logs, but you only need so much firewood.  I make a lot of small projects from maple especially.
walnut, ERC and maple coasters.
Offline richhiway
  • Rich
« Reply #3 on: December 11, 2021, 08:58:59 AM »
very nice doc.
Woodmizer LT 40
Stihl Chainsaws
Offline Sixacresand
« Reply #4 on: December 12, 2021, 07:39:44 AM »
the cracked, twisted, crooked logs produce unique figure and shapes.  Not much building lumber, but the craft folks love them.
"Sometimes you can make more hay with less equipment if you just use your head."  Tom, Forestry Forum
small wack,small logs,small project
Started by Dave H. on Sawmills and Milling
Last post February 01, 2016, 08:58:54 AM
by Sixacresand
Ms 201c defective valve jet?
Started by Swedo on Chainsaws
Last post April 05, 2022, 11:37:23 AM
by Swedo
sawing defective cherry on a Cooks mill
Started by woodman52 on Sawmills and Milling
Last post Yesterday at 10:20:11 PM
by WV Sawmiller
How small of walnut worth sawing?
Started by D6c on Sawmills and Milling
Last post March 08, 2017, 07:26:50 PM
by Brad_bb
