Box elder management small acreage
Started by johndough, September 11, 2022, 10:25:39 AM
johndough
Hi Guys, I'm new the the forum this is my first post. My wife and I move to a place in the country a little less then a year ago we have just under ten acres of land a mix of forest and open pasture Roughly 3 or 4 acres each. My question is, walking through the woods we have a lot of oak, hickory, and some cherry amongst others but there are a lot of box elder amongst the under growth. I burn fire wood (OWB) and have read that box elder is okay. If I start clearing the box elder will also be beneficial to the less trashy trees? I know that box elders like to sucker when cut down. Should I make an attempt to get rid of the majority of them or just get rid of a few here and there where wanted and needed for fire wood.
John
Welcome to the Forestry Forum.
Entirely up to you to take them as you feel they can be used. If you don't want them to shoot suckers back up, then treat the stumps to kill the new growth.
You will know when you get enough of the work connected to staying ahead of the box elders. Some people enjoy the smell of box elder smoke, just sayin...
Clark
Your location (state is fine) would help people give a better answer.
Based on how boxelder grows around here I'm guessing your property was all pasture at some point and when the cows left boxelder was the first thing to colonize. In all likelihood your forest should include a lot more of the oak, hickory and cherry. And probably some other species that are absent.
Since I have my biases I would wholeheartedly recommend cutting the boxelder (treat the stumps with Garlon or the equivalent) and getting more appropriate species established. Thirty years down the road you are unlikely to regret that decision.
Clark
SAF Certified Forester
Personally I wouldn't go on a specific mission to eliminate it, but put it as first on the hit list when collecting firewood each year, leaving the more desirable trees to continue growing. Box Elder is a type of maple, one of the lighter and softer ones, but perfectly "OK" as firewood. If you do that, and whack out some of the unwanted saplings that spring up, you can gradually change the makeup of your little patch of forest to more suit your wants, without making it look like a tornado has gone through.
johndough
Thanks for the responses guys. As far as my location goes it's west central Wisconsin. My pasture kind of is in the middle of true property with woods saddling the edges. My ten acres would be a boarder opening for some of my neighbors land which is largely forest.
johndough, welcome to the forum.
How are you getting the wood out?
What kind of OWB you got?
I have an old Heatmor, bought it back in 2007. It's the old style.
KEC
You may be interested to know that some birds feed on the seeds of box elder, Evening Grosbeaks are known to favor the seeds or buds. I have burned a lot of it and it burns up fast, but it kept the house warm. Best used in mild temps. Terrible to split; best to leave it big.
johndough
Quote from: thecfarm on September 11, 2022, 09:03:44 PM
I'll probably size and haul back with the mule. My wood boiler is a classic cl6048 I'm new to the wood boiler seen.
That will make some nice looking trails.
Won't even be able to tell you was there.
We use to haul out wood on a trailer, when there was 2 of us.
