This is more of a venting exercise as I think I might need a day or 2 off from framing work. Moved 3 x 20 footer English oak 6 x 9" beams into my garage to work on as the rain just wouldn't stop. Using snap line square rule and thought I'd get 2 of these marked up in preparation for the wall plate joinery... Was completely busted after moving these and then a bit disappointed when there was more bow in the wall plate pieces than I had thought
. About 1/4 over 20' (maybe that's not much or maybe it is?): if I were to do the joinery and set the plate on the 3 jowled posts either the 2 post end tenons would fit and the middle not, or vice versa.
Should have enough margin in the stock to account for bow. I had thought about using the persuader and leaving this in and letting the frame suck it up but I have concerns that additional outward pressure on the plate tenon could help split the jowled post between post tenon and teazle tenon.
Anyway, broke my chalk line >:(and thought I'd try using a laser line I already had. A lot slower as you have to draw in the line but worked quite nicely as a backup and much nicer than the photo shows. Unless you had a really expensive model, it wouldn't be much use in strong daylight though (green lasers apparently work better in strong light).
The previous day's work was test fitting sill members. You can see my beam transportation apparatus at the right
I made a slight modification of my boring machine to help get more consistent depths. I had been counting revolutions which was fairly accurate but found my mind wandering back to the roof details which continue to keep me awake and so kept loosing count. So instead I made some markings on the upright with zero corresponding to the top of the sliding guide and when the snail is fully engaged and the cutters just touch the surface. Originally just light penciled in but couldn't properly see so now lightly scored. Anyway, I feel a bit better having got that all out. Apologies for the ramble.
