I am not a timber framing expert. The joint will carry compressive load just fine. It looks like the rafters will brace it well from side to side. You do need to be concerned about the joint moving toward or away from the end of building. If you can solve that problem, I think you will be OK. Removing the post and replacing it with a single piece would be a PITA now but much worse later.
