what you do not want to see when...
Started by amberwood, March 26, 2007, 07:48:57 PM
amberwood
you walk down the drive to a job.
A simple one log job on a Monday. 18M long, ciustomer has very little idea what he wants. Good thing I brought the truck that day. It is amazing what a super low gear, 4WD and BIG tyres will pull without a fuss.
The result after 8 hours was about 2 cubes of mixed 2*4, 4*4 and 2*6,,plus a couple of slabs.
Good application for a swing mill..except the logs were too small and suspended!
the customer pays the customer gets.
DTR
MS460 Magnum
MS250
DAF CF85-430
ASV RC-85 track loader
LeeB
amberwood
a messmate.."eucalytus obliqua". only a baby one at 500mm dbh. Full size at 2metres diameter
DTR
MS460 Magnum
MS250
DAF CF85-430
LeeB
That be about 20" to us and full grown would be 6 1/2'. 18m = 59'. 2 cubes be about 850BF. I think.
kderby
Thanks for the views Amberwood 8) 8) 8)
Your species and dimensions are different than mine but I love to see the process.
Kderby :)
rvrdivr
What that truck be? I like the look of that !
dail_h
World Champion Wildcat Sorter,1999 2002 2004 2005
      Volume Discount At ER
Singing The Song Of Circle Again
Robert Long
dail-h
do you have a close-up pic of that truck and what's under the hood
Robert
TexasTimbers
Robert,
I doubt dail-h does - but amberwood might. ;)
CALSAW
Lucas 827 w/ slabber
Robert Long
Kevjay :-
Thanks........Dumb on my part
Robert :-\
amberwood
just checked back and saw I had missing a response!...still a truck down here. There are more pics in the gallery. Gave the winch system its first trial run on the weekend. Almost as new. It is driven as a PTO off the main gbox. Just put the transfer case in neutral and you have 5 forward winch gears but only 1 in reverse. All works perfectly except the air cylinde that disengages the dog clutch on the winchg had seized and thus no freewheel of the winch. An hour on the bench with WD40(no reaper over here) and a cot of pain and we have the reco air cylinder. Might be refitting with weekend.
DTR
MS460 Magnum
MS250
DAF CF85-430
