The best and most decadant meal I had from Thanksgiving clear til New Years.
Started by Jeff, January 01, 2013, 09:10:10 PM
I'm not kidding. What I just ate, leaves me feeling guilty as sin, because I forgot to take a picture, so ate it twice!
(you can tell by my not so fresh plate and fork)
Tammy made me some waffles and I put some of thecfarm blueberry jelly he sent me for Christmas on it and some whipped topping. OH MY GOODNESS GRACIOUS SAKES ALIVE!  Ray, put me on the list for next year to buy some Jelly!  It is some of the best I ever had.  :)
Thanks Ray!
Corley5
Let me know in late July or August. I will put you on the list. I'm glad you liked it.
You should have chopped up some pecans and put them on it too  :D.  Looks awesome!
POSTON WIDEHEAD
Slab Slicer
Jeff, the next time, try it on a waffle made in cast iron. Nothing like it my friend.  :)
2016 LT35HDG25, Kubota L2501 w/ FEL, Kubota BX1500 w/FEL and custom skidding rig, Stihl MS 500i, Stihl MS362-25", Stihl MS250-20", Stihl MS192-18",  2001 F250 SD 7.3, GMC Sierra Dually 6.0 gasser, Peaqua 16" 10K trailer, Sur-Trac 12' Dump Trailer 10K
Chuck
Jasperfield
With your right hand, drag the waffle through some maple syrup, through streaked-meat gravy, on into the blueberry jelly, and into your mouth.
Then, with your left hand, take a bite of the fried streaked meat.
Next; lean back, chew for a bit, and recover by re-addressing the plate for a fork-full of white corn grits.
Only then. Only then.. can you appreciate the blueberries.
I will pretend I did not read that about the g...s Not a good way to start my day.  ;D
I put very little jam or jelly on anything. Most times I take a good amount and put it on my plate with most times eggs, and just dip into that way. On every batch she makes there is usually some left over. Believe it or not,Brenda,my wife does not like jam or jelly at all. I have to be the taste tester.  ;D  It's a hard job,but someone has to do it. :D We sold alot of jars at the Veggie Stand. She had a real good outlet at a apple orchard store. I forgot the cases they would buy every year. Than they closed, :(
