Business Plan: doing my homework
Started by DoubleD, January 17, 2006, 06:39:28 PM
DoubleD
I am doing my homework because I want own a mill and operate it at least as a part time business. I am planning as a stationary electric mill, because here in Italy gas and diesel cost barely 6$ per gallon  smiley_crying smiley_eek_dropjaw smiley_furious3
I was unable to find some important information, I hope that you could answer some of my question
Which are the formulas to calculate overrun\underrun and the LRF lumber recovery factor in cubic meter?
Which are the log scaling rule used in Europe and in Italy?
Which are the grading rules for Europe and Italy?
Which is the volume of high grade and low grade lumber in  a log 17"(circa 45 cm) in cubic meter?
427 Board Feet= 1 cubic meter. Is this a valid conversion?
If a sawmill have an estimate production of 400 BF\hour Could I assume that the production is 1 cubic meter\hour?
Thank you
Wannabe a sawmiller
Chris Burchfield
I'm a bit metrically challenged. You may do better @ http://www.woodmizer-planet.com/ which is a website for European Woodmizer owners. However, similar to the Forestry Forum, I've seen comments by other mill owners as well. Hope this helps, Chris.
Woodmizer LT40SH W/Command Control; 51HP Cat, Memphis TN.
DoubleD
Thank CB it helped to found the production per hour :P
Wannabe a sawmiller
