Setting bandsaw blades-how often
Started by Joe Hillmann, September 07, 2016, 03:06:11 PM
Joe Hillmann
For those of you who sharpen your own blades how often do you set them?  I used to set them every time I would sharpen them.
Now I have been doing some testing and the blade that I have on my mill right now is on its third resharpening without being reset.  I plan to reset it the next time I sharpen it but wonder just how often I really need to set my blades.
millwright
ladylake
 3 times is pushing it, maybe OK in hardwood but not softwood.  Steve
pine
If they are out of set then setting helps.
If the set on them is fine then setting them does no harm as it does effectively nothing.
Time is a cost but it is not that much time as I see it.
I tend to set each time as I like the result.
Just the way I think.
I also touch up the chain on my saw every tank of fuel.  It results in  longer chain life as less is removed.
Tom the Sawyer
I clean, set, and sharpen.  I check the set of every blade, every time.  If it is off, I re-set the blade.  If it is within specs, and consistent, then I just sharpen it.  In a batch of bands, about 3 in 10 will get reset.
If a blade was changed for something other than getting dull (hitting metal, binding, diving, etc.), I make a note with a black marker, near the weld, and it gets a closer look after cleaning.  I do them in batches of 10-15, usually on a rainy day, and normally have 30-40 blades in rotation at any time.
07 TK B-20, Custom log arch, 20' trailer w/log loading arch, F350 flatbed dually dump.  Piggy-back forklift.  LS tractor w/FEL, Bobcat S250 w/grapple, Stihl 025C 16", Husky 372XP 24/30" bars, Grizzly 20" planer, Nyle L200M DH kiln.
If you call and my wife says, "He's sawin logs", I ain't snoring.
drobertson
What Steve said! Soft wood seems lots more tempermental.
I go three and suffer some,
Chuck White
I run my bands through the rollers (my unsetter) that I had made and then set every time, then sharpen.
Setting a band usually takes me around 5-8 minutes to do both sides!!
killamplanes
I sharpen mine and after 2-3 times I throw them away. Call me lazy, just not dedicated enough but my blades cheap 15-20$ never ran 30-40$ ones or I might change my tune...
jd440 skidder, western star w/grapple,tk B-20 hyd, electric, stihl660,and 2X661. and other support Equipment, pallet manufacturing line
Peter Drouin
A&P saw Mill LLC.
License NH softwood grader.
4x4American
If the blade is in the saw shop it's going to come out of the shop with an even set.  I mark the blade with what I set it at (I set my 4 degree blades to different sets so that when I'm having problems, I can experiment) and how many resharps it has undergone, and what it is too...I mark near the weld joint so I can find it, and it looks something like- (K-7/35 3RS S.025"  now that would mean it's a Kasco 7 degree blade that's had 3 resharps and is set to .025")...
I find alot of times that when I'm running a blade, one side of the teeth (I think it's the bottom/outside teeth) usually will lose .005" set compared to the other side.  I think it's because I do alot of trimming and skimming to make a good board.  So I usually like to put that back in...when I was using my DTS, I would often just not set it, because who really knew what the thing was reading, but now that I have a single tooth setter, and can trust it's accuracy, I like to use it and make sure that all my blades leave the shop within .002" tolerance.  Does it matter that much?  To me, I try to hold those tolerances because now I can, and.. my grandpappy taught me never to half-butt more than one thing in a day).
So, short story long, X2 to what Peter said  :D
Boy, back in my day..
YellowHammer
I sharpen then set.   Setting is fast, I'd guess a couple minutes per band with a dual tooth setter, and give me confidence the band that is going on the mill is in top shape.
It gives me something to do while waiting on the sharpener.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Percy
I have no hard and fast rule about this. I just check the set with my hand held gauge on several random teeth. If its within my tolerances....heh.... it goes on the sharpener. If its had an "incident", it gets the full treatment...
Bandmill Bandit
Depends what I am sawing BUT every band get set at least once during each sharpening cycle  AND twice when I cut hardwoods and dry logs of any type. When done properly this policy extends the useful life of the blade a LOT and increases the amount of lumber produced per sharp cycle.
Not setting is a lazy way out of the shop when you have to sharpen blades. It is costly policy, pure and simple!
LeeB
I set then sharpen every time. I don't cut a whole lot any more so it is not a big deal to set the few blades I do now-a-days
Quebecnewf
I know this is going to sound funny but I never set. I sharpen my blades with my Dinosaw sharpener and get 8 to 10 sharpens per blade. Saw only softwood. About 15 logs then I swap out the blade. This works for me. My setter sets in a drawer unused.
When I first had the mill I set after every third sharpen . I think the blades have gotten better.
Like I said it works for me
Quebecnewf
Kbeitz
I set if the blade sticks in a log...
Love machine shop work
and Wood work shop work
And now a saw mill work
Ox
I generally set every third sharpening or so.
Deese
I set every time I sharpen. Don't know if it is necessary, but I do it anyways.
2004 LT40 Super 51hp w/6' bed extension
Cooks AE4P Edger
Cat Claw sharpener/Dual Tooth Setter
Kubota svl75-2 skidsteer w/grapple, forks, brushcutter
1977 Log Hog Knuckleboom loader/truck
Peter Drouin
The setting is easy. Just push a button. ;D
A&P saw Mill LLC.
kelLOGg
Quote from: Deese on September 08, 2016, 09:28:34 AM
Same here. Sometimes I find they don't need it so I have wasted some time but I know...
Bob
I usually set every other sharpening. I made a small device with a dial indicator if a band has been cutting well I check a few teeth if their close it just goes on the sharpener. One of my sharpening customers wants very little set I almost never set his bands. If you have sharpened and set a lot of bands you can look at them and tell if their set enough. Frank C.
drobertson
Anything that works is the best answer, no doubt setting/resetting can do no harm for sure.
4x4American
I found that if I had too little set on the saw, I would get a dish on the cant.  If you get to the point that it's binding I think you've let it go for too long lol
Peter Drouin
Quote from: 4x4American on September 08, 2016, 08:19:45 PM
:D :D :D
A&P saw Mill LLC.
Bandmill Bandit
setting bands is like getting dressed. You can put on clean underwear in the morning or none at all. By the end of the day you will know the difference AND the end of the day will arrive sooner for you.
