Calculators
Started by Coon, November 25, 2006, 09:50:27 PM
Coon
I know there has got to be some kind of online calculators that uses the number of teeth on sprocket to figure out the gearing, but I can't seem to find one.  The baum hydraulics site only uses the diameter of the sprockets so......
I am at a critical point with my tracked skidder that I need to figure out the gearing.  All help is much appreciated.
Brad.
Don_Papenburg
The only help I can offer is Machinerys Handbook . I don't know if they have a website . But the book is chock full of practical info on just about any worthwhile endever .
Onthesauk
Can't help you Brad but think you better go over and check the full membership board.  They're talking about you. ;D ;D ;D
John Deere 3038E
Sukuki LT-F500
Don't attribute irritating behavior to malevolence when mere stupidity will suffice as an explanation.
Don P
With 4.11 gears you can really get lost  ;D
Gears and sprockets are figured by counting the teeth and using the ratio. If the motor sprocket has 9 teeth and the driven sprocket has 37 teeth, divide 37 by 9 =4.11. Take the motor rpm and divide by 4.11 to get the output rpm. If the drive sproket has the greater number of teeth multiply by the ratio.
Woodwalker
Just cause your head's pointed, don't mean you are sharp.
Coon
Thanks guys I got it almost all figured out now except for the fact that I know the diameters of the sprockets needed but don't have a clue of how many teeth are on any of the ones I need to buy.
Brad.
Woodwalker
Brad, Look at this link again. http://gadi.agric.za/software/renting/pulley.php The "size" is number of teeth.
Coon
Thanks Woodwalker.  I guess I forgot to mention that the link wasn't working earlier.  I see that it is now.  Looks like exactly what I am looking for.  Have to see if it will work offline.  Don't wanna burn up net hours if I don't have to.  180 hours doesn't go too far between 3 people...
Brad.
