General Forestry => Sawmills and Milling => Topic started by: firefighter ontheside on February 26, 2018, 11:36:53 AM
Title: Cutting stacking sticks at the mill.
Post by: firefighter ontheside on February 26, 2018, 11:36:53 AM
How do you guys cut stickers on the mill?  Do you mill boards all the same size and then stand them all up together and make cuts at 3/4?  It seems like it will be unsafe as I get down toward the bottom.
Title: Re: Cutting stacking sticks at the mill.
Post by: Rougespear on February 26, 2018, 12:08:59 PM
I always cut the thickness of the sticker first - usually I cut them at an even 1" as I'm opening new log faces.  I'll save these boards until I have several and then I'll stand them up on the saw deck vertically and cut down through them all on 1.5" increments.  This produces even-thickness stickers.  I have found cutting the 1.5" dimension first and then vertically sawing down every 1" is not the way to do it because it's harder to produce even-thickness stickers because the boards move slightly as I'm sawing down do the deck.
So cut the sticker thickness first, then width second - just my two cents.
Post by: kelLOGg on February 26, 2018, 12:17:51 PM
I cut my stickers 1" x 1" and from edgings. They are generally waste but I get long enough pieces to make stickers. When I have used an entire board for stickers I raise the squaring arm high enough for support and lower as I cut. That way I am not trying to stabilize the original width by clamping the bottom half inch.
Post by: terrifictimbersllc on February 26, 2018, 12:30:21 PM
You can saw several boards stacked vertically, safely, down to 1" from the bed, if you observe several practices.
1) use enough boards so the clamp is tightly clamping them.
2) have a fresh square edge on the bottom of all these boards, flip them over when half sawn, for example, so this happens. Have a helper hold the boards vertical, pressing down on either side of the clamp as you clamp them.
3)  Clamp is low and tight to clear the last cut you have planned, so it doesnt have to be re-adjusted
4) the side supports are up enough to support the boards sideways against the force of the blade when the boards are taller, and are dropped as the cuts get lower.
5) once the side supports are down, saw the last cut or two a bit slower to minimize sideways force
Post by: POSTON WIDEHEAD on February 26, 2018, 12:50:25 PM
 (https://forestryforum.com/gallery/albums/userpics/24625/11stickers.jpg?easyrotate_cache=1519667400)
Post by: firefighter ontheside on February 26, 2018, 01:02:17 PM
Thanks for all the replies.
Post by: Kbeitz on February 26, 2018, 07:00:18 PM
I put all my  edgings in the bell saw edger.
Post by: Dave Shepard on February 26, 2018, 07:05:13 PM
I saw 5/4 boards, then stand them up on the mill and mill my 1" thickness.
Post by: firefighter ontheside on February 26, 2018, 07:31:54 PM
This is basically what I had in mind.  I was just concerned that sawing the last couple of rows would be sketchy.  I will make sure it is all clamped well and take it slow toward the bottom.
Post by: Sixacresand on February 27, 2018, 07:55:36 AM
I use my "not so good" pine logs for stickers.  And I generate a lot of stickers from edging and resawing odd length lumber.
Post by: Southside on February 27, 2018, 09:45:20 AM
Notice the boxed pith in the photo by @POSTON WIDEHEAD (http://forestryforum.com/board/index.php?action=profile;u=14625)  - that's just showing off!!  (https://forestryforum.com/board/Smileys/default/cheesy.gif)
Post by: Jack S on February 27, 2018, 10:20:22 AM
It might be showing off but it still takes some skill in setup.  OK now lets see a picture from the other end that will really tell the story.     ;) ;) ;)
Post by: Ga Mtn Man on February 27, 2018, 06:04:53 PM
I think he just got lucky. ;D
Post by: woodmills1 on February 27, 2018, 06:26:39 PM
When I get an order for oak 2 or 1.5 material I edge the flitches on the mill, dropping an inch at a time.  It is surprizing how many stickers I get this way.
Post by: firefighter ontheside on February 27, 2018, 10:34:51 PM
All great comments.  My dad will get less firewood, but great idea.
Post by: firefighter ontheside on March 02, 2018, 12:04:46 PM
I just stacked and stickered a red oak and used stickers made from the side lumber of the same log.  Now every time I mill a log, I'll make some sticks from it too.
Post by: Peter Drouin on March 02, 2018, 12:17:47 PM
Green on green wood will stain.
Post by: firefighter ontheside on March 02, 2018, 12:22:46 PM
Noted.  I wouldn't call it green.  I've had these logs for over a year.
Post by: Peter Drouin on March 02, 2018, 07:49:51 PM
Well then wet on wet will make mold, stain, rot, junk. What it dose to me.
Post by: POSTON WIDEHEAD on March 02, 2018, 08:12:27 PM
Quote from: firefighter ontheside on March 02, 2018, 12:22:46 PM
I've had logs over 2-3 years and the MC be 30% on stickers from these logs.
Logs don't dry...lumber dries.
Post by: firefighter ontheside on March 02, 2018, 08:46:37 PM
Thanks guys.  I'll start cutting some more sticks so I have dry ones to use with green logs, however long they've been down.
Post by: YellowHammer on March 03, 2018, 08:22:23 AM
Stickers dry real fast, I've laid them out like carpets of noodles on the pavement in the summer and they would be baked dry in a few days.
Saw ahead, so there are dry stickers ready to be used for each job.  Good stickers make good wood.
There are few things more frustrating and shot in the foot costly than unstacking dried lumber only to see the dreaded zebra stripes. Sometimes, in some species, they will plane out.  Sometimes, they will not.
