First question, if you had to choose between a standard 7 and a Turbo 7 which would you pick? I currently use 10's but when I bought the mill it came with maybe ten standard 7 blades that where dull that I have stashed away. I have my own CBN sharpener and want to minimize the CBN wheels I have to buy. So is there much difference between the two and if I do choose the turbo, can I sharpen the standard 7s I currently have into turbo 7s or into 10s? I have a 51 hp diesel so power shouldn't be an issue and I saw about as much hardwood as softwood. Production rate isn't a huge issue for me as I saw by the hour and quality is my number one concern. Also, sawing is my 'side' job so maybe I should just stick with 10s. I have a couple grade sawing jobs coming up and I'm planning on getting a box a new blades and just debating what to get as my resharpened/set blades are hit an miss for finish as I haven't mastered that yet. I guess I started thinking about this because the turbo 7s are 10% off right now and when I called Woodmizer for some parts the guy I talked with told me if he had my mill and only had to one blade to choose he would get the turbo 7. Just wondering was others think???
Different horse powers, different blade degrees, different species and different sawing speeds.
Its just me and my 35 hp engine. I use mainly Turbo 7's and 4 degrees sawing Cedar.
This is what works for me.
I have never let price or a sale price dictate what to buy.
I buy the blade that matches my hp and sawing speed depending on species....I've experimented with most of them.
Please don't let your sawing as a "side job" determine what blade works for you best. :)
In my business and after finding what works best for me.....the blade is my least of worries.
I also let Woodmizer sharpen my blades.
If you want to reduce the number of wheels you buy then don't use one wheel to sharpen blades of a different profile. That will wear your wheel out much sooner. Instead, send blades in to re-sharp if you don't have that type of wheel.
I currently have a few 9s and 10s, more 4s and 7s, and am getting my first turbo 7s today along with some more 4s. I expect to love the turbo 7s from what I have seen and heard and be using up my 9s and 10s and regular 7s. I'll get a turbo 7 wheel in a week or two. I have the 4 other wheels which still are good.
Turbo 7's or Kasco 7/40's. 10's are for old people lol. You have the ponies so send it!
My 7° blades are long gone and I am letting attrition eliminate my 10° blades. When they are gone I will only have 7° Turbos and 4° blades.
I still have about 10 7degree 35s, the rest 7 turbo
I prefer the turbo.
Does it take more horsepower to run the 7 turbo's vs say a 4 degree? What is the difference from a 7 degree and a 7 degree Turbo?
Am I the only person still running 9º blades? ;D When I started milling back in 2004 I got a few boxes of 10º bands. Later I picked up a box of 9º and a box of 4º to try. I liked the 9º the most and don't have much call for the 4º so I started buying only 9º bands. Over time my 10º were resharpened to 9º. Now I have about dozen 10º left and MANY 9º bands. All of them are .045 - 1 1/4" bands.
Last summer I had Wood-Mizer upgrade my mill to the new fuel injected Kohler 38 HP. With the additional HP available I could probably use something more aggressive but I haven't been able to decide if, or what I should change to. I mill lots of mixed species but mainly oak and poplar with a spattering of pine. If I was to make a switch it would be over time as I replace worn out bands.
Deere80, when the Turbos were first offered I remember reading that they were recommended for higher hp engines. The gullets are huge compared with "standard" blades so they are dragging out a larger amount of sawdust. I know that they load my engine when I am pushing them.
I have read where some sawyers with smaller engines are having good success with them.
MM, what size of engine do you have on your Super 40. How did you like them?
My Diesel was advertised as 38hp. I am well pleased with the Turbos and am gradually replacing all of my 10° blades with them.
Wonder if I have enough ponies to run the Turbo's? I wouldn't mind trying some out if my 25HP Kohler can handle them. I guess there is only one way to find out and that is to order a box.
Quote from: Deere80 on April 09, 2018, 04:16:14 PM
If you call WM, and talk really nice to them, they will send you a free T7 blade. I was running 10's. I switched to T7s. Best move I made. I will be ordering more T7's and some 4's for pine.
My mill is a 47HP. From what I see, the T7 can be used at a slower pace, but it will not cut as smooth (leaves some saw marks). When I increase the speed, the cut is much smoother. So, if you are ok with the marks, just go slower and your engine will be fine.
hey deere80, we run the turbo 7 s on our 25 hp kohler it works pretty good ,not as good as higher hp machines but we like them ,,,,we cut mostly oak
I have an lt40 with a 25hp Kohler and I flat out love the t-7s. Yes I might get a little chatter here and there but not enough to really care about it. The biggest problem I have is trying to work in all my old 9s.
My go to is the turbo - and that is on a 35 with the 25hp Kohler. I do have some 10's left, but as they die off they are replaced with turbos. I do not have a problem with blade chatter due to the speed. I tend to keep the speed in check via the sound of the motor, right against the governor, and I get nice, smooth cuts in oak and even hickory. Sometimes in SYP I have to remember to slow down if it's really knotty or else I will get deflection.
Redneckman-I will have to call them and see if they will send me one to try out, thanks for the heads up.
I have a few 10s but most often use the 4 degree bands, just seems to work for me, but would like to see the out come of the T7.
Quote from: Deere80 on April 10, 2018, 07:59:36 AM
That is what I did, and they sent me one. They know that you will love it and turn around and buy a box. WM has T7's on sale this month with free shipping. Now would be a good time to stock up.
Redneckman you must be a lot smoother talker than me.
Just got off the phone with Woodmizer in Indy and he told me I do not have enough horsepower to run it, so I asked him if he would have one to let me try. He said he would sell me one blade but they do not give blades out so no go for this cat.
Thanks for all the replies... I was really on the fence about the Turbo 7 based on the post that were out there that happened to be a couple years old. Sounds like they are really the way to go.
I wish they had the same deals in Canada. I'd like to try the T7"s. My price here is $39.60 each. 11/4x.045 x 195".
Quote from: Deere80 on April 10, 2018, 11:57:36 AM
Ha Ha! The person I spoke with was a lady, and I have been told before that I have a "fun" accent. I layed it on thick. Sorry it was a no go for you. At least you tried. I would buy one if I was you and try it. I think the HP will be fine. Just slow down if you bog the engine down too much. I bet you will love it. Even when they are a little dull, they still cut better than a fresh 10 degree IMO. I am getting rid of all my 10's and going with t7's and 4's.
Hey folks, I too am kind of new to the forum, always been a follower though. I have a Norwood HD-36, 23hp, and have always used 10 deg bands. I was considering giving these Turbo 7's a shot based off all of your reviews. I cut a lot of oak and walnut and need a tougher band that will last a bit longer than my current ones. Quick question though, does anyone have any experience with the WM Vortex blades? They advertise they leave a lot less saw dust in the cut when finished while providing decent blade life. Figured we're on the subject, I might as well put it out there.
I have never tried the turbo's I did switch from 10 degree .42 to 4 degree .45 and never looked back. Saw mostly Red Oak and White Pine. New box of 4's arriving today. Jobs are stacking up just need sawing weather now.
Deere80 Concerning free blade samples from woodmizer. It all depends on who you talk to. Call back and talk to a different person and it may be a go for you.
Beavertooth, it would be my luck I get the same person. :D :D
Use a different accent - try Bismarck instead. :D
Quote from: Southside logger on April 12, 2018, 11:45:17 PM
North Carolina hillbilly redneck worked for me. However, I talk like that everyday, so it was easy for me. :D :D :D :D
