This past summer I built a shed designated just for the mill, I milled all the lumber excepted the roof joists which is repurposed 2 1/4" by 9" boards. I plan on building bi-fold doors like on a plane hanger building since the front door is 20' wide. I would of like to go bigger with the building but am limited to flat ground where I live so it ended up being 32'x20'.
(https://forestryforum.com/gallery/albums/userpics/42945/IMG_2809.JPG?easyrotate_cache=1538490772)
(https://forestryforum.com/gallery/albums/userpics/42945/IMG_2834.JPG?easyrotate_cache=1538490808)
(https://forestryforum.com/gallery/albums/userpics/42945/IMG_2893.JPG?easyrotate_cache=1538490830)
(https://forestryforum.com/gallery/albums/userpics/42945/IMG_2894~0.JPG?easyrotate_cache=1538490910)
(https://forestryforum.com/gallery/albums/userpics/42945/IMG_2899.JPG?easyrotate_cache=1538490938)
(https://forestryforum.com/gallery/albums/userpics/42945/IMG_2900.JPG?easyrotate_cache=1538490959)
(https://forestryforum.com/gallery/albums/userpics/42945/IMG_0018.jpg?easyrotate_cache=1538490987)
(https://forestryforum.com/gallery/albums/userpics/42945/IMG_0019.jpg?easyrotate_cache=1538491005)
(https://forestryforum.com/gallery/albums/userpics/42945/IMG_0020.jpg?easyrotate_cache=1538491025)
Very Nice Work!
Nice building! I'm studying on what to build. Seeing your building helps!
Nice, I put an 18` wide leanto on the back of my 48` long garage for the mill a while ago, love it, I`m old enough now if it wasn`t undercover I would use it a lot less......
(https://forestryforum.com/gallery/albums/userpics/18098/lights~0.jpg?easyrotate_cache=1538493017)
Super! I like the skylight panels and flow-through ventilation, (especially for exhaust and dust). I saw a similar build on youtube where he had a half door behind the mill for easy sawdust cleanup. (https://forestryforum.com/board/Smileys/default/thumb.gif)
Nice looking building
That will work!!
What did you use for a beam to span the 20' door? Knowing of course that you don't see much for cold or snow over that way.... :D
That looks like a great design and well done. What's the wall height on front and back?
What did you use for a header?
I'm kind of surprised a full 2x9 would be able to handle a 20' rafter span with snow load.
Alan
For the header I used 3-2"x10" laminated beams screwed together that I traded a guy for some cutting time. Because the front posts are 8"x8", then I notched into the post 2" on each side for the header to sit on. Front wall is 13' and back is 9'. So I have 3 foot drop in my 20 feet. The roof trust are on 2' centers.
Nice shed. i see the black at the bottom of your post , did you use treated or did you prep the post with something.
They are western cedar utility poles that I cut off the treated ends because you don't know if they are rotten and also I won't cut any of them that are treated then I painted them with 3/4 roofing tar 1/4 diesel. All the poles were just treated on bottom, nothing after the bottom 10'.
smiley_thumbsup
That looks real good! That mill will last you a long time in there. Did you put down some sort of stone base? :P
Nice!!
What's with the metal siding?
You own a sawmill :D
Quote from: PAmizerman on October 02, 2018, 07:59:17 PM
Nice!!
I was thinking the same thing :D :D
Quote from: Lawg Dawg on October 02, 2018, 07:41:28 PM
No I did not put any stone down yet, will have to do something in the future because I have sticky gumbo clay.
Quote from: Peter Drouin on October 03, 2018, 07:01:47 AM
Nice!!
I was planning on going with wood siding but then I have two other out buildings that match so wanted this to match them.
(https://forestryforum.com/gallery/albums/userpics/42945/IMG_2535.JPG?easyrotate_cache=1538580623)
(https://forestryforum.com/gallery/albums/userpics/42945/IMG_2541.JPG?easyrotate_cache=1538580639)
Nice, real nice!
Tin is fast and easy, Don't have to paint it, Bugs don't get into it,
smiley_thumbsup
and can be beat back into shape after hitting it with the loader :)
smiley_thumbsup smiley_thumbsup
