Does anybody run or have one. I've only seen one before it may have been homemade. Looked like a circle mill track and carriage with the bandsaw vertical and stationary. The carriage run the log thru the blade. I thought it was pretty neat.
Red, that's the way large commercial mills are, vertical band, log on a carriage. A mill with a carriage has to be twice as long and heavy duty enough to handle heavy logs. The advantage of most band mills is the heavy log remains stationary and just the relatively light head moves. If a fella is going to all the work of building a vertical band and carriage he might as well just use a circular saw. Frank C.
I thought about building one of these but the extra amount of track involved was a huge turnoff for me.
Be nice to not have the sawhead anywhere near the loading and unloading area but thats about all I can think of.
Now if you take the head lay it flat and make the bed go up and down then you got something there. Especially if the bed was flush with the ground so all you had to do was roll a log onto it. Then raise the bed make your cut, repeat....
Logosol makes something like that.
The one I seen wasn't commercial. Probably homemade. It took just the regular band size
A company in Missouri made a small blade traveling vertical bandsaw mill. Was it Woodland ? Anyhow it's apparently gone. There are heavy commercial slant track , traveling models built. Lumber pro comes to mind. The 'wood miser' style is a horizontal band re saw [softwood style] made to travel and cut logs. The real band re saws for hardwood are vertical.
Always thought the slant bed Sanborn looked like a handy unit myself... log stays in one place on a conventional looking slant bed "carriage" and the head goes back and forth on a track. More transportable than portable but I'd say she'd be a producer once you've got her set up.
I think the larger commercial units of verts came about for speed and smaller kerf from logs. I would guess they would be impractical for most moderate users today. Seems like everyone wants to return to the days of hernia when every log had to be carried by a carriage down a train track, this is so out of date. Most mills like GP use chip 'N' saws and such and logs are run down a line one time for speed. The game is speed and efficient handling with fewer humans, I am surprised that they still use human lumber graders, I would have thought a computer scanmra would have taken over by now.
a guy in PA sells them
https://clouserfarm.webs.com/Bandsaw/panther.pdf
Update Your Browser | Facebook (https://www.facebook.com/134618496601417/videos/1131698610226729/)
Band sawmill vertical - YouTube (https://www.youtube.com/watch?v=bDh1WeCFm-s)
I always felt this was the best method I've seen to convert a circle to a band. A lot of the time savings in a vertical mill is the amount of speed the carriage could take, especially on the gig back. This could also be used on an automated carriage system, which handles logs a lot quicker.
Slant heads are nice, but you need a different type of log loading system, as the carriage is stationary.
the board you just cut would just fall of. less handling :)
Cleereman Lumber Pro (Newald, WI) has that angled log bunk. Carriage glides to and fro with a quickness! Way out of my league. Unless someone is selling one real cheap!
tom
Many condemn the circle mill with a traveling carriage. Have you ever watched one run in a small mill with a verticle edger ? With all different dia. logs coming in and all different orders to fill this is a hot set up.
I have produced lumber in commercial setting with both and I can tell you there are advantages and disadvantages to all types of mills what is gained in curf size is quickly lost in processing time also log size and quality come into play , as an example one set up we ran I processed spruce and pine into cants with a 52" circular and used a heartwood double cut bandmill as a resaw worked good on softwood but not so much on hardwood when the money is all in the sapwood especially hardmaple and yellow birch . Also a friend of mine tried to convert a vertical resaw into a bandsaw mill it could'nt take the stress of feeding a log into it as it was designed to just resaw lumber being fed through the feed rollers, the wheel on a resaw are flat and the saw is adjusted by the slant on the wheel whereas a bandmill wheel is ground concave and the saw runs on the outside grooves called a tire these are mills with 6" or bigger bands and are pretty much stationary. Sorry for the long post .
There's a guy in the next town over from me that took the carriage and track of an old circle mill, and mounted it with a 42" vintage American Tool Works resaw. He removed the table off the bandsaw, and rigged the whole thing so he gets a 30" full cut. Pretty slick setup. I've seen it run.
Only 'bad' part is he has the track and carriage mounted about 4' up in the air, and he uses a bridge crane to load logs. This whole setup is indoors.
The last circle mill I sawed on was 5' in the air. So much easier to work on and to keep clean. Also used a vibrating conveyor to get rid of all waste. We had log decks for log infeed. Loaded with a loader, so there wasn't a problem.
The biggest problem with vertical mills is the gig back with the carriage. If you rub the saw, you might pull it off the pulleys. The Clouser mill pulls the head back on the gig back. That eliminates the problem.
For me the crucial thing in all this is sizing.
Every horizontal mill I've ever seen makes a cut, gigs back, and drops down however much you tell it to, then cuts again. It's indexed to a point in space rather then the physical surface of the log
The old verticals worked like that - back in the dark ages. In their case the carriage knees kicked the log over whatever distance and you took another slice. I know theres plenty of older mills out still doing it just the same way. But in the real world of commercial sawmills you fit a linebar. And a linebar serves as a fence, meaning you can adjust the headblock pressures independently during each cut and push your log against it and the actual thickness that you cut is indexed to the cut face of the log.
Maybe it's just me - being in Australia and cutting species with a lot of spring - but being able to cut a consistent size regardless of spring has always been a major factor in equipment choices for me.
I nearly bought an 8" (vertical) band resaw the other day. I am doing a fair bit of 3/4 and 4/4 work and I'm looking for the kerf saving over my circular resaws. But again its got that feed hob that holds each cant tight to the fence during each cut. You can swing the hob out (or leave your linebar out) if you wish to take a shim cut because of tension issues. But what you can't do with horizontal is bring it in and know every board is the same thickness, even if its bowed from end to end.
Lurker, ever see a gage roll on a circle mill husk?
Okay what's a gauge roll? I figure its a translation thing but maybe not. Seems like around here we went from breakdown saws to fully hydraulic linebars in one jump... We never had handset headblocks at all.
Most of my time is around circles of one sort or another, but band or circle is all the same regards general setup in a vertical.
A gauge roll was an option on old time sawmills. Some small guys like me still use them. It is a vertical iron roll mounted on a horizontal screw just ahead of the saw guide. It can be flipped out of the way. In use you pull a cant up against it and saw the board off. It gauges the thickness of the cut and improves the accuracy. You have exposure to sawing machines I have never herd of. Thanks for the reply, Doug
This quickly became an education thread. Liking the whole conversation.
Like Ron said, the converted circle to vert. band is the most efficient way run a band.
I have a really, really good geuss that an automatic carriage and track with a band headrig using a 2" wide blade would CONSISTENTLY out produce any horizontal band mill on the market.
Quote from: Ron Wenrich on January 29, 2019, 05:06:36 AM
The lastest design from Clouser uses a moving guide now. They don't use the tilting head anymore for some reason.
Brewco do a 2½" band headrig thats actually designed to be a "drop in" replacement for a circle husk. If you watch close you can actually see the saw set back as the carriage returns.
1 VERTICAL BAND BREWCO 22 CUT.wmv - YouTube (https://youtu.be/Jv0q3f6DYNg)
Never saw that tilt back feature before. No problem gigging with that. To bad you would need a debarker. If I sawed that maple I would get 2 less boards.
That Brewco is exactly what I was thinking.
Doug, you wouldn't have to have a debarker, but it would significantly extend blade run time, maybe enough to justify a debarker alone, without figuring in chipping the slabs. But as you probably already know, a debarker and chipper will replace one warm body that would have to stack slabs.
Quote from: moodnacreek on January 30, 2019, 08:58:13 AM
Yeah but...
This goes around and around in my head about 3 times a year.... how to go forward from where I'm at / how to be more efficient / use less labour / actually have a life where I get like a normal life with days off in it.... over and over and over.
Lot of ways we're in different places..... there is 200 years worth of equipment optimisation to suit local resource and conditions between me and you guys. And yet we're still pretty much all running circle saws and while techniques and equipment are different the basic stuff is still the same. I'd love to be able to sit down and have a beer and a talk with ya's.
Australian mills are different: we use the headsaw to cut flitches and cants and then sort it out on the (circular) resaws... its a response to the resource. Technology came along in say the 60's and meant that instead of the straight breakdown saws the headsaw became a linebar carriage with independently controllable headblocks so the flitches were sized, and the circle resaws got faster and had automated sizing and flitch returns and linebars and waste separators etc on them as well.
Now technology has taken the big guys to optimised twins (like super giant scrags) and multisaws (like a gang edger). I stood in one of those mills a while back and came to a number of conclusions:
* that I can't compete with that anymore then a small operation cutting softwood can compete with a quad canter.
* that I don't want to compete with that anyway
* that their equipment has limitations too, and theres a place for me doing what they can't.
* that theres still a difference between small and backyard, and small and boutique, and I need to push that difference.
* that I still need to increase my yield per man, and my dependance on dumb labour, by using the smart stuff where it can be fitted to equipment more in my program..... even if its their castoff's. Auto stackers and the like: I can buy a second hand, outdated stacker for like 12 months worth of two dumb guys standing at the back stacking boards and placing sticks.
* 300 other odd thoughts as well and I'm getting sidetracked away from the band headsaw debate.
Yanno that extra two boards, its highly dependant on log size and you might only get 1. And if you'e cutting 6/4 or thicker you might not even get that. I keep looking at bands.... particularly when we're doing the 3/4 and 4/4 timbers... but it's always to install a band resaw
as well as my circle resaw. I still don't see a place for a band headsaw... it just doesnt add up in my operation. It's about the debarker, and knots or rot pockets that will make a band do silly things and... yeah.
So thats my current goals, aside from more "smart" tech that can run itself pretty much: circle headsaw, and a vertical band resaw on a roundabout. Oddly enough when I look at whats about secondhand both there and here that gear: the big vertical band resaw, is often available at a pretty reasonable price being cast offs from some bigger operation because it aint big enough no more. Still way to big for me but.... cheap horsepower... all that means is I fill the infeed chains, maybe run another longer greenchain to it for more storage, then turn it on at the end of the day for two hours and pick up a 10% yield increase in my 4/4 and 23% in my 3/4 ( that ¼" kerf gets realllll hungry cutting thin stuff as you guys know)
Dunno... I've got to get bigger to meet demand and order deadlines and diversify my risk. (We had our largish wholesale customer go under last year and it hurt: not the initial lost $ when he went into bankruptcy but the giant cashflow hole behind it. I
need that guy, and the only way to diversify that risk is to have more then one of them but while he might have been 50% of my business I was only 10% of his so it means some bigtime capacity upgrades to think about having a couple of them)
Sawmills.... why can't I own a strip club or something?"???
60" optimised twin edger in action...
carriage can take logs from 10 - 18', cant goes to a multisaw with chipper reducers and stuff, slabs go to a resaw and then everything to an edger..... all of it with scanners and positioners and all that technical gear that replaces sweat and dirty hands.
Optimising Twin Edger 60" - YouTube (https://youtu.be/ZtYR9efQQzI)
Scary isn't it?
You guys are always thinking, keep posting. Lurker mentions the resource and so many forget or don't realize that the size and shape of the raw material means everything. A softwood, low grade mill a few hours from me runs 2 circle mills, r/h and l/h side by side delivering cants to a horz. band [small like W.M.] run around re saw system. This of course ups production and the wide kerf of the circle mills means nothing here. The Brewco band conversion shown is cutting boards on the mill, this is being done less than ever and if a mill put in a band re saw they might keep the circle head rig. There are so many ways to do it, always interesting.
Quote from: JB Griffin on January 30, 2019, 09:47:21 AM
Mostly I'am just runin my mouth. Don't have much land and not young. have to build a pantograph and get hydraulics on the carriage now.
Double L, that looks basically like a big end doggin scragg mill, I couldn't get enough logs to feed that thing.
Doug, ain't nothing wrong with old school, a lotta times its better or at least easier to troubleshoot and fix. Are you gonna run hyd dogs, tapers, and setworks? Or just dogs and tapers?
The whole scope of things is that in any mill situation, the bottleneck is supposed to be the primary breakdown saw. That has to be matched to the resource and markets. Efficiency comes about by keeping the saw in wood and cutting as fast as conditions allow.
The Brewco looks like you can get a board or two on occasion, but the speed slows down because the blade can't take the dust away as efficiently as a circle saw. The band will not take a feed as aggressive as a circle mill. That means the increase in fiber use efficiency comes at a cost of time. Time has value, and can be figured out.
The debarker increases efficiency at the headsaw by allowing longer cutting before there needs to be a sharpening. We don't know how long you can run a Brewco blade before it needs to be sharpened. On most normal days, I would sharpen my saw after lunch and after work. The rest of the time I was sawing, unless I hit junk in the log. A good debarker operator goes a long way to that.
A double cut band mill increases efficiency and yield. But, the efficiency is the big factor. The carriage is productive on both cuts. The lead in circle saws prevents them from being efficient double cuts. You'll heat the saws. The double cut efficiency has to pay for the millwright to take care of the blades.
Resaws are the same as adding in another headrig. Material handling is increased, as is labor. Cost evaluation is whether that is profitable enough for the capital investment. There is some fiber saving, and you'll get an extra board here and there. But, the savings comes from being able to breakdown logs on the headrig quicker. You bypass the debarker on the added resaw as compared to adding another headrig.
The biggest efficiencies can be had in material handling. You must get material away from the headrig as quickly as possible. A belted takeaway is the easiest method. It eliminates a man. Drop conveyors for slabs also eliminates handling. You want to handle your waste product the least. Shutting down to shovel sawdust takes away from sawing. Efficient handling will get rid of a lot of labor. I had one good hand that could trim and stack 15 Mbf a day. Usually we used 2 guys for trimming and stacking.
Another production hog is downtime. Poor maintenance or waiting for something to fail before replacement costs a lot of production time. We had minimal daily maintenance, but had repairs and major maintenance handled when the crew wasn't there. I was pretty good at finding things that were failing and we repaired at opportune times.
I ran a mill with a vertical edger. The lure of these machines is to do away with an edgerman. The theory is better than the practice. It slows down the sawyer. Instead of having 1 saw to watch, I had 3. I had to move the carriage further back to accommodate the added 3 feet for the saw. That's an extra 6' per cut for a board. It doesn't sound like much until you figure thousands of cuts in a day. Add in the extra time to set the blades, and how often you might miss the mark. You do lose some volume in order to keep production up. Deep cuts also caused you to slow down. You can't upgarde boards, which has to be done on a horizontal edger. The upside was that slabs were cut better so there wasn't a chipper problem.
J.B., This is what I got; live log deck w/ stop and load, old crow foot log turner, manual carriage, off bearer over husk, spiral roll case w/ 2 flags dropping flitch boards on [floor] trap door/ scissors lift , accumulate for edger, then flat belt to flip table, l/h to green chain, r/h to slab drag accumulate for slab wood saw. This set up is so 1 man can run mill and it works with low production of course. When I have help and nice logs the manual carriage is the bottleneck. To start I think powered set works would be the thing, help turn faster. Thanks for your interest.
What i want to do is build/buy a slant mill like a sonborn running 2" bands, with a roll case as an outfeed sending cants to a verical band resaw(2") with run around, all feeding the same greenchain with the edger located after the resaw outfeed to allow upgrading any lumber off the resaw and headrig. And a "grading station" located on the greenchain just below the resaw outfeed.
What type of production are you aiming for, and how well can you buy that volume of logs in your area? There was a mill up around Shinglehouse that had 2 Woodmizers feeding a resaw and had 13 employees to run things. Their production was less than my circle mill without a resaw and 5 employees. Shut down by fire.
Much depends on logs ... types sizes and volumes.
And markets. A whole lot depends on markets. I've got a want verging on a need for a band resaw. The reason its still just a want is market driven... we're running a fair bit of flooring and panelling feedstock. But as a percentage of my overall volume its maybe 15%(though growing) the balance is still 8/4 and 12/4 structural, and we do maybe 10% of our output as bridge and wharf timbers at 16/4.
Aint much point saving on kerf when you've got a market for ties. The kerf equation tilts to circular saws cutting 8/4 or thicker in average logs, because you can't save that 1/8" enough times to get an extra board between heart and bark.
And you got to price your fibre too: thin bands cost time due to slower cut speeds, and time is money. Wide bands cost money in maintenance. Circles are cheap to run - they're faster then thin bands by a mile and cheaper to maintain than wide bands. Sometimes the most profitable thing to do is save the money you were going to spend on either slow cutting time or band maintenance and put it to more logs and make more sawdust but sell more lumber.
Every one of us that saws to eat has to find a place in the equation that works for us, and it might not look like anyone elses but it doesn't have to so long as there is black ink on the balance sheet.
Ron, glad you dropped by with valuable insight. Labor is a big problem here and many of the circle mills have went to a vert edger because of that. Assuming that brewco blade is 20-24ft long and 2in wide, a good blade in clean logs would last about 2hrs and coat approximately $50- $55 or about $12-$16 to resharpen if farmed out.
Doug, hyd dogs, setworks, and a bar or chain turner would make life easier on ya anyway. Hyd setworks might not be as easy to set on the money as quick but saves pullin the handle. I have shy'd away from circle mills because Im a one man show and couldn't figure a way to make it work.
LL, spot on again. Logs down here usually don't grade real good and it drops fast when sawing. Sawin decent 14in and up logs into 7x9s and 4/4 I will always get more out of those logs, always. Sawin 5/4 the difference is significantly less, but still there, but not nearly as much at all.
The circle costs would be about $60-70 for a change of teeth. I could get 60-75 Mbf out of a set of teeth, since I didn't take them down to nubs. Resharp costs about $10. How many resharps on a band until it has to be replaced? Hitting a nail is usually replacing a few teeth at worst. Saw costs are much less on the circle than a band.
I had a portable Jackson automatic that had a simple hydraulic setworks that was dead on. It had mechanical stops, just like the manual setworks has. It had 4 sets of 4/4, 5/4, 6/4, & 8/4. They moved on a bar that had a hydraulic cylinder on it.
Those Jackson's were a pretty cool setup and you could saw by yourself if you had a green chain to use as a surge deck. Load your deck up and then sort it out. You could use either a vertical edger or a horizontal edger, depending on your setup. Production capacity on that mill was about 1 Mbf/hr. If sawing by yourself, figure half of your will be spent sawing and the other half sorting and loading logs. And, you wouldn't have to carry lumber or slabs around.
No doubt saw costs are less with a circle mill, it blows my mind that mill that costs 3-4 times as much is actually cheaper to run, but it is true.
A good quality band that is well taken care of would last approximately 6-7 resharps before the hardened tip would be mostly used up. I think (I know, thats dangerous) in good logs 14"-20" that 1mbf/hr is entirely possible sawing 4/4 and 7x9s
So, 2hr run, 2mbf per run= 12-14mbf per blade. So blade costs would be just over a penny a foot, something like 1.2 cents. It would be much more if you hit trash in the logs regularly.
The only circle mills I have been around had computer setworks, I was unaware that there was such as you described on that Jackson. I literally was thinking Doug would have to set off a dial, instead of the ratchet.
(https://forestryforum.com/gallery/albums/userpics/32746/IMG_20190203_102920.jpg?easyrotate_cache=1549167219)
(https://forestryforum.com/gallery/albums/userpics/32746/IMG_20190203_104807.jpg?easyrotate_cache=1549167219)
Cutting ¾ feedstock again today... My circle resaw runs a ¼ kerf... cut 3 boards and turn the 4th one into sawdust...This is hurting just watching the sawdust pile grow.
