looking at different, but cost saving methods of lifting my saw head. i saw on another build thread, where a member used a winch on his, and even hudson uses them on their mills. instead of using synthetic or standard wire rope. i want to tear up a new winch, somehow, mount a sprocket on the drum and go with chain drive. not sure exactly the weight of the saw beam with pwr plant, wheels, and all the other stuff on it, but im figuring around 1500 lbs. we use this winch https://www.warn.com/4000-dc-winch-94000 at work to pull our internal fire fighting tank inside our acft, mostly bc at the time, it had the slowest FPM line in speed. granted the tank is on 8" pneumatic tires, the tank weighs around 1500 lbs, and add the dolly system, another 200 lbs and rolls relatively easy, even going up the install ramps, which is about a 4-5° angle. after using it for the past 3 yrs, i have noticed that it doesnt have the tendencies to keep moving after releasing the switch, like some winches do.
any thoughts? any experience with the above mentioned winch for this type of application? even other brands, do the users have issues with drifting while raising/lowering? lowering of course should provide the best chances for drift after releasing the switch, but is it negligible or fairly drastic, enough so, that 1 has to bump it back up?
this is a temp solution, seeings how the system WM uses, with motor and gb, would cost around $800-1000 for both, then the added sprockets and double roller chain.
Any good winch should be able to lift and lower, more important is the drifting. I ran a Hudson a few times and whatever brand they used it worked pretty good
Friend of mine used a 12v tarp motor. Cost him around 125-150 but was easy to mount the gear.
Quote from: BigZ La on January 29, 2019, 02:36:33 PM
does it drift, especially during lowering?
Run your winch or tarpmotor or DC linear actuator motor etc to a jackshaft and then run your cable or chain ends to the head off the jackshaft. This way youve got a center mounted winch and end mounted lifting for squareness (design in some form of turnbuckle slack adjustment) and a very easy way to make a holding brake if your winch brake fades out over time. You could use ebay motorcycle or bicycle parts or even just a sheave on the jackshaft with a rubber belt tugged over it to bind up [like an oil filter strap wrench in reverse]
A dc reversing contactor is the easiest way to power your smaller winches. Harbor freight sells just the remotes for it i think. Surplus center and ebay will also have then around $40. I see no need for a 4k winch if you use a jackshaft, they have like 10:1 planetary reduction. A 1500lber should do it for $60 and be remote control.
On the Hudson 60 it came with a 2500 lb winch and I had braking problems right away. Worked fine at idle but engaging band blade in the log at high rpm it would start slipping.
The sent me a new 3500 lb. right away never had issue again.
The lifting design is real simple roller bar. What ever you decide too get make sure the braking is stout, and keep your cable going in winch lube free
Mike,
i was watching a vid on the wm lx450, and they use, which after a google search, a jackshaft, which i was planning on doing anyways, just didnt know it was called a jack shaft. due to the weight and 10' wide saw beam, i would HAVE to lift from both sides to achieve an even lift. i was thinking turn buckle too, but i was also brainstorming the idea of a bracket (probably 1/2" plate cut and welded into a "U") and using an eyebolt with double nut at the bottom and single jam nut above the bracket.
you really think a 1500 lb winch should be used to lift and hold a roughly 1500 lb system? by NO means am i saying it CANT lift, but being at its limit is in my industry, asking for trouble. the reason i was going that brand or big winch is, im familiar with it, i know using it in the application we purchased it for, it works within its limits and doesnt have any creep/drift, and the way it is designed, with the planetary gb mounted to the motor, instead of a shaft running through the drum from motor to gb. this design, along with the tarp winches, now that i see how they are made, would be easier to mount a sprocket, without having to drastically mod the winch drum/gb. and drastic may be a bit of an over statement. idk, but i think, IF there is no or minimal creep/drift in a tarp motor, i will go that route, since its already designed the way i would have to mod the atv winch.
1500lb winch is rated at 1500lb direct line pull on the first wrap, and no i would not use one that small in a direct pull application. But with a sprocket to jackshaft you can then gear reduce the ratio to slow the speed and increase the torque capacity. For example If you used a 20tooth drive and a 40 tooth driven youd have a 3000lb winch pulling up a 750lb head give or take. And itll be slow enough to land on the mark every time. The gear reduction is also in favor of the brake holding.
Yeah each head height change takes more time but you cant have everything without lots of $.
Quote from: redbeard on January 29, 2019, 03:09:57 PM
i saw the pics of your's in your gallery, which is what made me go back to thinking about the winch method. and if your 2500 was slipping on our saw head, and yet it could have been just a bad winch, but they sent you something bigger (could hudson have had enough reports of slipping systems using those lighter winches?) again brings up the decision of using more power than required. plus im betting, but not guaranteeing, your saw head doesnt weigh what mine will end up weighing. id rather have it and not need it, than need it and NOT have it. i lucked out on the price ($3000, running) of the engine, granted it WAY to big for my needs, but to have to replace/rebuild, along with replacing the band wheels, blade guides, blade, more material to build/repair blade/wheel covers, is $ id rather not spend, when i could have spent an extra $100-150 for a double/triple capacity system.
and this idea may NOT work, and i have to go to acme rods, which i will still have the winch and chain and some of the sprockets, all in all, would probably cost about what the motor/gb, that still may be to lite for my purpose, that wm uses. hopefully wm will have the 450 at the belton fair and i can take a look at it and get the part numbers off the motor and gb and research to see if they have to umph to do what i need them to do.
Quote from: mike_belben on January 29, 2019, 03:20:40 PM
ahhhh, so that is how you snatch block using sprockets. so id have about 2x the lifting capacity required. only down side with the slow speed, is IF i used, and i might, the mill for extra $$ on the side. i guess i could just charge less, then there wouldnt be a downside, unless the customer was in a hurry. i guess he/she should have gotten there 15 min earlier then. ;D
Going heavier AND faster will indeer take more winch. The challenge is that higher power winches do indeed run faster and at some point, you may start missing your mark and having to go back. None of us knows the sweet spot really until the r&d phase begins. If you build with jackshaft and sprockets then you have a tunability built in. Either to dial in a small winch or make changes from a small to a larger one down the line. There is also the option of using a belt and a pair of drillpress pulleys to give you a 3speed range setup. Youd need to use a brake and an idler for belt speed changes. Itll need to be tight to hold up 1500#
If u have the quicker winch already, sure build around that one. If you dont id consider starting at the smaller one because it will be a cheaper replacement part. Chinese winches are as consumable as starters and alternators. Cheap enough one can keep a spare on hand is a big virtue to me. Driving 80miles back home on a custom cut because any winch croaked will be a bummer. I have known the remote controllers to come alive on their own and drain batteries so plan in a disconnect switch from the get go.
DC-Powered Vehicle Mount Electric Winch: Pulling - Gamut (https://www.gamut.com/p/dc-powered-vehicle-mount-electric-winch-pulling-std-duty-rating-12v-dc-ODQ1NzA1)
this 1 is in between, on capacity and line speed. plus, depending shaft size, i could just direct couple it to the jack shaft and reduce 2 sprockets and a lil chain. but it has a HIGH amp draw under full load, but with gearing, im guess the draw would be cut in half???
Quote from: charles mann on January 29, 2019, 02:51:20 PM
Ill have to ask him tomorrow but I have seen trucks running down the road with the tarp not completely down or up. That kind of wind resistance tells me it has pretty good braking.
There's a long and old thread on this subject:
Question on homemade bandsaw head lift in Sawmills and Milling (http://forestryforum.com/board/index.php?topic=75176.0)
Quote from: kelLOGg on January 29, 2019, 08:47:28 PM
thank you. i did read this a long time ago, well, long for me, probably 6-7 months ago, and knew there was something on here, just couldn't find the right keywords for the search engine. even though he went cable, and I'm not taking any chances, I'm going to go roller chain, probably double roller on both sides. and as the cooks system lifts from 4 posts, i think i may end up having to do that too, depending where i have to place my engine to keep the radiator in the back, blowing the saw dust off the engine and away from the intake side of the radiator. i do remember on crusarius's linn mill build, we discussed lifting from all 4 corners and the problem that may arise, along with getting them timed with ea other. but i may not have a choice. i think iv found a tarp motor, like what bigz recommended that will work, now to see if i can find it on eBay, or better yet, amazon, since i have $600 in amazon gift cards to still use. i thought about wheel chair or power scooter motors too, but having to fart with getting a 24v dc alternator, then stepping it down to run the rest of my 12v system will be a pain. but i guess what isn't, when building from scratch
How does a tarp motors output torque compare to that of a cheap winch? How does the price compare? How quick and local can you get another?
Same with the cable, you can buy a lot of aircraft cable for the price of a foot of double roller chain. Then the sprockets. Then how to tram them. A cable crimp is 50 cents, smash on a loop and hook it to a $6 turnbuckle and anchor eyelet that you can get anywhere instead of need to machine yourself. Youre away too much to find the time for every custom part.
Price out a pair of double chain sprockets and then the keyed shafts. It frees up a lot of time and money to just drill a hole through the shaft ends, insert the wire cable and wind it up. 1500lbs, no big deal. Ive seen heavier commercial heat treat oven doors and baskets lifted this way with ease and no maintenance issues. If you somehow snap one, go cut off 6 feet of cable from your loop and smash on another 50 cent lead crimp then back to sawing. I wanna see this thing get built!
mike, i dont trust cable. i was yarding on a walnut top, that my tractor picked up, so just under 3,000, with a 12,000 lb winch, and a straight line pull. i had inspected the cable bare handed prior to pulling the main log, got the log onto the trailer and was attempting to get the canopy section loaded. i just happened to be standing between my tailgate and the headache rack on my gooseneck when the cable let go, sending it back towards me, getting tangled up in #2 pencil lead sized twigs on a live tree i had parked up. that cable was 7/16" and i had a tight wrap on the drum. i guess it got boogered up yarding the log onto the trialer and i didnt see it.
i aso saw a 1" cable break and broke a soldier's legs. we had the 88 recovery track pulling 1 of our howitzers out of the mud and for the 88 to have solid ground, we ran nearly all his cable out, and snatched it for max pull. i dont trust cable, even though, YES, i agree with 100% of what you said, and i believe in the KISS method, keep it simple stupid.
as for roller chain and sprockets, tractor supply always has sprockets and chain on hand, and if my local store doesnt, there are 3 more within a 45 min drive that should.
as for ease of getting a tarp motor, probably austin (1 .5hr drive), san antone (2-2.5hrs), houston (3hrs and if my business partner is off shift, he can fly it to me), dallas/ft worth (3hrs nd if 1 of my maint clients is hm, he can fly it to me).
but yes sir, simplicity is always the easiest when it goes down, compared to more complex systems. and i may try the cable method to get up and running at first, but upgrade later.
Then use a piece of amsteel as if it were cable. There is no way its just gonna randomly snap 2 sides without warning. Thered be a huge birdnest fray hanging out for you to see.
I just wanna see you get up and running. Life flies by while we plan for it. Mine sure has anyway
i wasnt even thinking of synthetic rope, instead of steel wire rope. ill check it out.
@Vautour (http://forestryforum.com/board/index.php?action=profile;u=43405)
even though the idle pulley thread kinda got off topic, dealing with lifting and now into band life
I see you have your sprockets and chain laid up there for an example reference or possibly you mocking the system up before committing to burning a rod to it.
Where will your drive motor be? i know how i plan on building mine, and that is mounting the winch and jack shaft to the saw beam, running a short loop of chain around the jack shaft sprocket from the winch, then using the "S" configuration to snake the chain from the beam, to the carriage upper cross over structure, on both side.
I may be over thinking all of this, and may not understand it till i just start doing it. my brain works in a monkey see, monkey do fashion. I can read all day long, but until i put it to practical application, i stay lost.
when i was going to go all hydraulic, i was going to use 2 rams. mounted to the carriage, to pull the chain over a crossover tube like yours. but since im not going full hydraulic yet, im trying to keep it simple, and i hate to say it, cheap.
So last night laying in bed I had a random dumb idea. for raise and lower winch.
Simple harbor freight chainfall. has gear reduction and brake built into it. Be very easy to put an electric motor on it. has nice heavy chain that will probably never break or wear out.
They used to be $40 from HF for a 1 ton. No idea what they are now. could run single or double. If you can find the balance point a single would be great.
and Vautour, i see you built a collar to clamp around your vertical carriage posts. what did you use for guide material? it looks like some kind of thin white plastic material, like uhmw, tivar or some kind of polycarbonate. im doing the same for mine, using the forward carriage supports as a guide rail. with the wt of my saw head, i was going to use 1/2" x 6" flat plate, cut 12" long, and boxing the guide rail/support, using 1" uhmw, hysoled to the flat plate, then where 2 of the plastic pieces overlap the other 2, install some 3/8"x 20 counter sink bolts, just for some added mechanical bondage. i will have to split the box in half, then like you did, bolt it back together, so if at any point in the future, something fails, or i want/need to mod it, i can just unbolt from the sawhead, unbolt the guide box and fix/mod to my needs.
Quote from: Crusarius on January 31, 2019, 11:54:44 AM
@Crusaius
I saw your post and was getting around to the replies. it seems most of yaw are 3hrs ahead of me.
i think finding center would be easy, but it would be keeping that cg nearly all the time, to prevent binding on the guide rails, and i think i can do it. i was going to mount my fuel cell at the bottom, on the outside of the carriage, so humping 1-4 5 gal jerry cans, 4, 5 or even 6 ft in the air to fill them sounds crazy. so mount it on the bottoms, and use a low psi (NMT 15 psi) fuel pump to push fuel upwards. not sure about blade lube though. mount it low, use pump, mount it high, use water hose. but then, it throws off the CG. a double chain hoist, with a crossover tube connecting both together and a single sprocket and a loop of chain run to a winch. but what about running opposite? those chain falls/hoists have a leaver that has to be moved to change direction, or, pull the chain the other direction. which heyyyy, they already have the chain installed on the chain fall, just find a sprocket to fit the chain, run chain to connecting tube, run a loop from a hand crank, or lighter duty electric motor, and go to town. may be less cost and fabricating to using that method. idk. but iv got 1 fall already, just need to buy another if i can find a sprocket to fit the chain.
I am thinking keeping it balanced for center will not be as critical as you think if you guide the mast the way you are talking.
Quote from: Crusarius on January 31, 2019, 12:23:52 PM
im hopping so. its a lot of weight, and i hope the 3x3x1/4 sq tubing will hold up. i will be dispersing the wt along a total of 24" span, with 324 sq" of surface are per guide, or 648 sq" all together. i need to do the math and make sure the psi of the sq tubing is within tolerance. or i can mod the build and use 2 2" 4140 solid rods, which does have load capacity. but i think when a co-worker and i were talking, he pulled up a site that gave load ratings for different size/thickness of metal, and i actually upsized, from 4" x14" sq tubing, to the 5"x1/4" sq tubing, bc its capacity was a good bit more.
(https://forestryforum.com/gallery/albums/userpics/53405/20190131_163136~0.jpg?easyrotate_cache=1549016136)
@ Charles mann....my gearbox/motor will be attached to the carriage frame to one side and a overhead door spring will be added to the jackshaft to help with the raising of the head.......you asked about my plastic inserts for frame rails.. i bought this round stock piece at a scrap yard and machined them to proper size.. don't actully know what material there are made off??... TK has the same set up but only square tubing with regular theflon inserts i believe..very easy and simple to make.... hope it helps thumbs-up
@ Charles mann... just curious as to what is your plan for the adjustable roller guide method... i like Cremona's idea... i belive the B20's have this method also .@ DOC ... tks for the compliment the other day... did i read that you have the B20 model?..if soo what's your take on this method?.. the newer TK models have the horizontal i belive!!... your insight would be appreciated.. :)
Quote from: Vautour on February 01, 2019, 07:43:26 AM
going to use a similar method as both our saw head guide, and the carriage guide for a wm mill.
weld a 1" rod, probably 2" off (that is the width of the 1/2" flat bar i have) bottom of the saw beam. take a piece of either 3" or my 2 1/2" sq tubing, fill it full of uhmw, bore a 1" hole through the plastic, cut a 1/2" wide slit in the top or the tubing and upper part of the uhmw, and slide it over the 1" rod. or depending how heavy the sliding guide system will be, i may end up boring the hole through the plastic and not cutting a slot in the tubing, but suspend the, probably go up to 2" rod though, with the 1/2"x 2" flat bar and let the guide system just slide across the rod, but weld a stop on the other side, around 24" from the other guide. i wont be milling anything under 24" with my mill. operating cost would be more than the value of the material im cutting, esp if i hit something and damage a blade.
....... @charles mann (http://forestryforum.com/board/index.php?action=profile;u=41365) ... in my last pic. i forgot to mention about the sprocket i had not yet installed on the jackshaft as you see the chain going around the gearbox and going around the jackshaft(with sprocket missing)..the chain is only attached to the head not and the carriage... i will have the lifting part all done in a few days and post pics up... oh by the way...which magic button do you press to tag someone?? im still a little ignorant :-[
so, i visited the portland, or WM the other day and finally figured out the lifting mechanism. for the longest, i couldn't figure out where the "extra" chain would go as the head if lifting. after looking at an LX150 that was loaded and ready for delivery, i found out nearly everything i need to get my lifting mechanism up and going.
now, I'm still not sure if I'm going to use a winch or utilize the same motors and gearboxes WM uses. I'm thinking bc of the weight of my power plant, and where it will need to be located (won't know any rough locations yet, until i get the raise/lower linear guide boxes built and installed) to keep the drive wheel shaft within acceptable length and location, either behind the band wheel, or behind the carriage vertical support. i may have to grab my back carriage vertical supports to help disperse the load on all 4 corners, not just the front 2.
question is, would grabbing the back 2 supports be beneficial for load distro, or grabbing the rear motor support structure with a set of roller chains and snaking it through the sprockets to either a single, or maybe a sec jackshaft placed above and at the back of support structure?
YES!!!, it will require a LOT more double roller chain, but it will help share the load of the sawed beam and motor structure. I know, timing the 2 roller chains may be a fiasco, but in the end, it may be the better choice for longevity, until i can find suitable replacement engine that doesn't weigh 2x more than a 38 hp kohler gas burner.
if I'm not making since as to where I'm talking about linking the chain, i will do my best to draw it, but i SUCK at drawing plans, but i can read them, and i SUCK at conveying my meanings/descriptions.
but basically, how the saw head would lift, i would do the same for the back of the motor structure, and run a roller chain, off the sawed beam jackshaft, reward, to the support structure jackshaft, and mirror the sawed beam lifting mechanism.
what diameter rod and material did you make your jackshaft out of?
i was thinking 1.5"-2" 1045 hot rolled, or maybe an alloy steel for corrosion resistance.
(https://forestryforum.com/gallery/albums/userpics/51365/lifting_mechanism.JPG?easyrotate_cache=1551051508)
sorry its not to scale, but the gist of the system is there.
@ charles mann ....my jackshaft is just a 2'' boiler tube (higher carbon than regular steel) 1.05 wall ...but i did machine solid insert at both ends for my pillow block (1.75'')... will read up your LX150 post.. seems interesting.. not tonight.. we're having a snow storm so i need shut eye for the morning snow removal... haha
I wonder if anyone has thought about a simple rank and pinion with stop set for raising and lowering the head. If to much weight on the head then spring and counterweight. The point is to get it to zero resistance. Woodmizer I think has a spring system in their LT15 head beams. Any way just looking at the rack and pinion on my drill press stand got me thinking. On my simple Lt 15 start it is just basically a hand winch machine with dial stops turning a fixed 1 inch sprocket to bottom 3 inch sprocket by #40 roller chain with no spring or counter resistance assists. Anyway just thinking out loud, I think the jackshaft and roller chain and sprockets are the way to go with dc gearmotor. Ones that are used on assembly production lines etc. Ebay has a ton of gear reduction units. I also noticed on some of the European units they are using gearmotors to raise some of the heads.
Quote from: Woodpecker52 on February 24, 2019, 10:59:47 PM
the gear boxes WM uses on their 30-70 models are kind of a rack and pinion style, of more so, a helical/worm gear style gb.
Cast Iron Worm Gearboxes | AutomationDirect (https://www.automationdirect.com/adc/overview/catalog/power_transmission_(mechanical)/general_purpose_cast_iron_worm_gearboxes/right_hand_shaft_output)
so instead of both the ring and pinion having a spiral bevel gear, its a straight tooth gear on the o/p, and a worm/cock screw on the input.
as for a spring, i was thinking about doing that, but i don't think i will need it.
I'm just trying NOT to have grab the back vert supports, which is my i was thinking of using another jackshaft and roller chain.
I'm sure its over kill, but #40 double roller on all 4 corners should do the trick. plus i will put a turn buckle or eyebolt on each end of the chain for fine tuning and not running out of tensioning adjustment as fast.
iv got 2 solid 9' sections of left over 2x8x1/4" sq tubing from my first frame bed build that i had to cut apart and start over. i think that should work for part of the eng support structure. just have to get the idle wheel box and band wheel installed to see how high i need the structure above the saw beam to clear the blade and guards. I'm hopping by the end of my off schedule, to have the sawed guides built, the idle box and wheel installed and the eng yarded out and a start on the support structure and determine which direction the eng rotates and move my idle wheel to the opposite side so I'm pull the wet noodle, not pushing it. then send the carriage off to the machine shop to get the drive axle housing and shaft built, along with the eng output shaft pulley bushing ordered and a shaft machined. hopefully in the 2 wks I'm at work, ill have all the pieces to assemble when i get hm and get the eng in place and mocked up, along with my carriage cross supports cut and tacked in place. iv learned to ONLY tack everything in place, in case i have to change/mod something, I'm not spending hrs grinding welds off. once mocked up and have my ducks in line, ill weld it all up and paint it.
Smart Idea to tack weld set it up right then finish welds, sure is hard to correct a long weld done in error.
so I'm still kicking around the idea of using a winch to lift the saw beam. but i was also looking on surplus center and was kicking the idea of using an aluminum 30:1 RGB that has an output tq of 3632 in lbs, which is 302 ft lbs. if i go with, say a 14 teeth #60 sprocket on RGB, to a 60 teeth #60 at the jackshaft, that should multiply my output tq to the jackshaft by 4x correct, at the same time, reducing my speed by 4x, correct? after looking at build of the guy from NZ, and using acme rod, i figured going that, well, made my mind up to go that way, till i found out i could only get the rod in either 6' or 12' increments, pretty much from every place i found, except 1 place that wanted $25/6" for their 4140 1.5"-4 rods. so now I'm back to either a winch or using the RGB and sprocket/chain for either. would that 302 ft lbs, or 4x that if my math is correct, be enough to lift and hold a 1200-1400 lb unit? i know a 2500 lb winch will, was just wanting the ability to lift faster after exiting the cut by using a 12v dc electric motor and a pot to control speed. but if that RGB doesn't have umpf to lift and hold, then the winch it is.
also, by coming of the jackshaft with a 60 tooth, then stepping down to say a 30 on the same shaft, at each end, down to my sawhead, then going around say a 12-14 tooth idle sprocket, then around another idle sprocket at the bottom of my carriage, then back up the bottom of the sawhead. would that just throw all the speed reduction and tq increase out the window? iv tried finding these calculation on the inter web, but I'm at a lost.
..... I've tried several gear box with different ratios on mine but still not satisfied with the "lifting speed".....since i'm using 24v i'm limited on power... my next try is using a 24 volt electric motor from a forklift instead of a treadmill motor... with the weight of your unit ..you might have to go hydraulic tapped into that diesel power... my two cents
Im going with 1.5" acme rods and basically the same set up as the builder i got the plans from but with a much higher tq rating on the rgb, but a lower ratio to increase raise/lower speeds and control the down with a pot. Iv gotta find that sweet spot in motor rpm-ration to i can run at 80% capacity w/o burning out the motor prematurely. Im trying to stay away from hydraulics for now, but if i have to, ill get a continuous run 12 motor to run a pump just for raise and lower, and maybe enough flow to add carriage travel at a later time.
