General Forestry => Sawmills and Milling => Topic started by: JesseA on March 10, 2019, 09:18:34 AM
Title: Jobber j200
Post by: JesseA on March 10, 2019, 09:18:34 AM
Dad and I went halfsies on a j200 some time ago after doing lots of inefficient milling with an Alaskan.
And it's been a bunch of trouble. Mostly related to breaking blades.  Anyone have one of these to suggest pointers?
Title: Re: Jobber j200
Post by: hamish on March 10, 2019, 11:29:35 AM
How or at what point are your bands breaking (ie comming off the bandwheels? in the cut? out of the cut?).
Post by: JesseA on March 10, 2019, 04:49:41 PM
It's been a while since I used it but it seems like they break in the cut at random and are not being thrown off.  I wonder if what's happening is we're compensating for not great alignment with too much blade tension.
Post by: Southside on March 10, 2019, 05:19:05 PM
How dull are your bands when they break? Running high tension, no lube, and dull bands will cause a lot of heat and stress cracks in the band, which will result in breaking.
Post by: barbender on March 10, 2019, 05:52:20 PM
We need way more specific info to help you diagnose this problem. There's lots of things that can break blades, from running them dull to a bad band wheel bearing and everything in between.
Post by: hamish on March 11, 2019, 08:13:15 PM
Quote from: JesseA on March 10, 2019, 04:49:41 PM
Get your alignment in order and adjust your tension accordingly. I have seen J200's produce alot of bf of lumber so the lack of band lubrication on the mill is a non issue.
