General Forestry => General Board => Topic started by: Compensation on May 08, 2019, 04:17:26 AM
So I went to the dark side and got a farmpro 2425 to help with loading sawdust and other minor things. It has a FEL and I want to use a backhoe and possibly a stump grinder on the rear. Trying to figure out how to go about it since it doesnt have the hyd hookups in the rear. Thought about using a couple of T's up front or running from the FEL. Then I seen some have a plate to bolt up a pump above the pto. Figured I would ask before I start spending money on it.
you can use a diverter valve to run the hoe off the pump for the fel.
Like the power beyond port and t into the return?
if it has a power beyond valve section you can use that
