General Forestry => Sawmills and Milling => Topic started by: Deese on December 19, 2019, 11:07:36 PM
Title: PLAN C
Post by: Deese on December 19, 2019, 11:07:36 PM
After burning up two mofset modules in a row, I decided to make a minor adjustment or two until I have time to determine the issue.
(https://forestryforum.com/gallery/albums/userpics/33361/20191219_215029.jpg?easyrotate_cache=1576814067)
(https://forestryforum.com/gallery/albums/userpics/33361/20191219_215016.jpg?easyrotate_cache=1576814058)
Title: Re: PLAN C
Post by: Nebraska on December 19, 2019, 11:24:27 PM
Desperate times call for desperate measures or so it looks.  Good  life hack.(at least I think it qualifies as such) ;D
Title: Re: PLAN C
Post by: YellowHammer on December 20, 2019, 12:50:45 AM
Wow, what's WM told you as a possible cause?
Title: Re: PLAN C
Post by: Deese on December 20, 2019, 01:34:16 AM
Quote from: YellowHammer on December 20, 2019, 12:50:45 AM
I'm fairly sure I have solved the puzzle...There is a short wire (2 connected wires I guess) that is red on one end and black on opposite end connected with a small diode. The little diode is not visible, as it is shrink wrapped in black rubber. The diode failed, which then fried the mofset gadget. Well...what do we all do when something like this needs replacing? We call WM and order it. That's exactly what I did. The box arrived and it contained the new Mofset gadget and all of the wires to replace  the old wires. Well, all of the wires except for that one short wire containing the diode. I followed the instructions came with package. Fairly simple if you are in a distraction-free area. Hooked it all back up and bam, started sparking and smoking and back to square one. If they would have included that single wire, I would have been good to go. But instead, I lost what small amount of money I had budgeted for spare parts and still no autoclutch. The DeWalt actually does a great job but now I think I've slightly bent the shaft coming out of the gearbox.
I'm sawing at this very moment finishing a cypress beam order that's leaving here 4:45AM (4 hours from now) going near your neck of the woods, YH. Timberframe build.
Title: Re: PLAN C
Post by: Deese on December 20, 2019, 01:41:32 AM
I didn't mean to sound like I was publicly smashing WM for what had happened. The guys I always deal with are great. Really. It's probably my fault, as I should have known better. You live and learn. Yes, I'm still frustrated but not pointing fingers at anyone but myself I guess. I did read the manual and it does mention the possibility of a bad diode. So that really puts me at fault for not being thorough enough. However, I sure could have used that new little wire. All is good I reckon.
Title: Re: PLAN C
Post by: terrifictimbersllc on December 20, 2019, 01:45:26 AM
Where is this mosfet?
Title: Re: PLAN C
Post by: Deese on December 20, 2019, 02:01:17 AM
(https://forestryforum.com/gallery/albums/userpics/33361/20191220_010242.jpg?easyrotate_cache=1576825241)
Title: Re: PLAN C
Post by: terrifictimbersllc on December 20, 2019, 02:22:15 AM
Oh-that one-thanks.
You going to get a nap before morning?
Title: Re: PLAN C
Post by: Deese on December 20, 2019, 02:33:08 AM
Quote from: terrifictimbersllc on December 20, 2019, 02:22:15 AM
Oh-that one-thanks.
I'm paying someone to deliver. I've gotta go pick up my new log splitter first thing, then it's naptime.
Title: Re: PLAN C
Post by: YellowHammer on December 20, 2019, 06:46:49 AM
You are certainly working late, late nights trying to get done, I congratulate you.
Ingenious solution with the drill.
