This is the third one this saw has eaten in 21 years. They have always been some years apart, but I forget to keep up with how long between. I think it was in 2012 when I put the last cylinder kit on it. This is the only saw I've ever had this happen to. I used OEM clips. It was probably getting due for another cylinder anyway, but it's strange that the same thing happens. Any ideas?
OEM piston?
Are you installing them right with the open ends either at the 12 o clock or 6 o clock position. Steve
I can't remember exactly what I did yesterday, so am hopeless about 8 years ago. I'll do them like that this time.
I think the last cylinder kit was a Meteor, but since it had eaten the wrist pin clip, I used OEM clips.
It's hard to say how much use it's had. I let the two guys that work for me cut their firewood with that saw, so it's had some use that I don't see. It just seemed strange that the final event is the eaten clip every time. It ate the factory one the first time, but that's been enough years past that I don't remember how many years it ran the first time.
I've never split the case on that one, and the bottom end is still as tight as a new one.
Could there be some inherrent vibration from somewhere causing this situation. Bottom end/top end bearing issue? Most unusual with other p & c's having the same outcome.
Vibration is a good theory, but I really don't think so. It's been my favorite saw to operate for a long time, and even with the old AV system, compared to newer ones, it's not an unsmooth saw to handle.
I'll just stick another cylinder kit on it, and see if it will run for another 8 years. It's been a good one, even if it doesn't. I'm keeping it for my own use now, and gave the guys a 290 that someone gave to me.
Seems odd but apparently the saw owes you nothing, I guess you could change the clips at 7 years for the price of two clips and a gasket(s)?
Wondering if the connecting rod has some extra side to side play causing the wrist pin to tap on the clip, that may eventually push the clip out.
Make sure to get the open end of the clips either at the 12 or 6 position. Steve
A little update: I'm having too hard of a time getting all the metal scards out of the crankcase, even after leaving it upside down with the parts washer shooting up into it for a half hour, so I ordered a new aftermarket crankshaft assembly for it, since I need to split it anyway.
The aftermarket crank kit, with new bearings was $62 with shipping, so it's probably worth putting that much more back into it. Maybe it'll last for a while yet, but if it doesn't run for another year, or two without going back into it, it's been a good one.
Would you trust the non OEM bearings, lots of people change them for Stihl bearings and seals.
You certainly got your money's worth of cutting from that saw.
I would sell it, as there is bound be other components nearing the end of their life too, that means more down time, diagnoses and parts, is it worth the time and hassle.
I've never understood why somebody that's had a saw and used it for a long life, would put back cheap aftermarket parts in it. To me, I 'reward' the saw by putting back in the best parts & bearings I could find. Unless you've spun a crank bearing or damaged the case halves somehow, the saw should be like new again.
But given the state of aftermarket parts out there, trying to dodge all the cheap parts and China crank bearings, my outlook is not shared by most. Even if you go OE or Meteor et al, you're still well under the price of a new saw similar to what you have. The crankshaft in particular is a very precision piece of kit.
Kevin
Valid points, but I'm not using that saw for a living, or even making any money with it. I'll just use it when I need a saw that size around the farm. I certainly won't sell it, and pass on problems to someone else.
These parts are cheap as dirt, so if they crap out, I'm not out much for a 21 year old saw.
I have a hundred acres of Pines I need to do some selective secondary thinning on in about a year, and am planning on getting a 261CM from Mastermind to do that with. Seeing the latest on the next version of that saw, I'm glad I decided to wait closer to the time I need it. I wouldn't want to tote this saw off into the woods to do that with, and have to end up walking back out with a dead saw.
Quote from: Tom King on June 11, 2020, 09:47:23 PM
Better chance of walking out of the woods with a dead saw that has new Chinesium parts in it, than used OEM.
I am curious about the wrist pin problem? I've have two 036 pros, one I got used 25 years ago, the other I got free that someone straight gassed 2007. On the later the OEM cylinder cleaned up and I put new OEM piston assy in it along with new seals and the clutch drum up grade.
The only problem I've had with either, was the first one had the clutch bearing grenade. I put in the clutch drum upgrade with the bigger bearing.
The 036 is about my favorite saw for medium size work, they just balance/feel right with a 20" bar and have decent power stock.
Quote from: Mad Professor on June 12, 2020, 12:39:20 AM
That's why I'm getting a new saw for the in woods work. If enough work for a 60 cc saw presents itself, I'll just get a new version. This one is probably tired in more ways than are apparent right now. I'll post after I get it running with the cheap parts, and see how it goes.
Quote from: Tom King on June 12, 2020, 07:51:36 AM
You won't have fun working on the new saws. The 036 is pretty simple. Look at carb setup for MS362 vs 036....then there is M-tronic fun.
I'd find good used OEM crank and cylinder. Use a meteor piston/rings and OEM bearings. Gasket seal set, rubber parts as needed, carb kit, filters. The clutch upgrade if yours has the small bearing. Only other wear items are oil pump/bar + chain.
I got a straight gassed 036 for free. It didn't need crank, and cylinder cleaned up. I had about $200 into it including stihl piston, new ES B/C, clutch upgrade, and rubber/filters as needed. It's close to as new.
(https://forestryforum.com/gallery/albums/userpics/16532/DSC_0015~0.JPG?easyrotate_cache=1591974869)
(https://forestryforum.com/gallery/albums/userpics/16532/piston.jpg?easyrotate_cache=1545483182)
(https://forestryforum.com/gallery/albums/userpics/16532/cyl_ex_side.jpg?easyrotate_cache=1545483322)
IMHO my time is worth more than I can save by using Chi-Com parts that won't last as long as OEM
I may decide to put the crank, and bearings back in it that are in it now. They don't seem bad, but I'll be splitting it to clean it out good. I'll not open the cheap crank kit, and send it back if the original parts are okay, on close inspection. I expect this one is as good as any other used one I could find.
I just want to get it back together in the same session that I take it apart. I already have too many different things in the middle of processes, including this one, so far.
Back to the wrist pin issue, I mentioned connecting rod side play but forgot to mention crank end play.
Either way I'm wondering if a movement of the crank or connecting rod could cause the wrist pin problem.
Was the wrist pin to one side as well or just the clip gone off the piston?
Didn't appear that the pin had moved. Clip just gone off end. Not sure how it was the other two times, because those were years ago, and years apart.
Haven't had a chance to get back to work on it, but all the parts are here.
There doesn't feel like any play anywhere in the bottom end, but too much metal detritus in it to get out without splitting it. There has to be some in the bearings, I would think.
Quote from: Tom King on June 15, 2020, 10:20:41 AM
You could get the crank split and fit a new OEM bearing, and OEM seals and case bearings, that should keep your saw running for a long time.
As mentioned, no MT carb or related issues on that saw, if that matters to you.
Quote from: Mad Professor on June 12, 2020, 11:16:57 AM
I plan on giving the Chinese nothing more as a reward for their inflicting the world with disease, would rather pay double for a saw or parts not made in China, I think we should all contact businesses with China plants and express our dissatisfaction and intentions to them, bring the manufacturing to our own locales.
OEM clips are better quality than AM, but not always a better fit in some aftermarket pistons. Sometimes they are too loose in the groove in which case you need to use the AM clips and hope they hold up.
Always a crap shoot with any of these AM kits, but getting 8 years out of a kit with 3 guys using it is probably as good as can be expected with this stuff.
Yeah, I can't complain about what the saw has done. Just odd that it was always the same fatal event.
Still haven't had time to fool with it, but have all the parts now.
Was wondering about putting 272 Locktite on the clips??
It wouldn't hurt to try but I doubt if it would make any difference. I have only seen wrist pin clip failures a few times in a 40+ year career but have never used aftermarket pistons, doing it over costs too much time and money. @Greenerpastures (https://forestryforum.com/board/index.php?action=profile;u=34896) we have nobody to blame but ourselves for the state of the market. Walmart, Harborfreight and Amazon thrive because the driving force is price.
Am not suggesting that at all, I meant you could advertise and sell your saw mentioning the issues, a buyer may be looking for a case, a cylinder, a crank, panels muffler air box parts etc, so the piston clip may be of no signivigence, lots of people buy parts saws.
Quote from: sawguy21 on June 25, 2020, 11:40:12 AM
It's the same mindset responsible for the Chinese invasion of cheap stuff. It's brought us to the precipice of having only cheap parts and cheap machinery/tools/engines for our choices in
everything.
Kevin
Quote from: Real1shepherd on June 26, 2020, 06:22:09 AMIt's the same mindset responsible for the Chinese invasion of cheap stuff. It's brought us to the precipice of having only cheap parts and cheap machinery/tools/engines for our choices in everything.
Yup, we keep buying the stuff and they keep sending it. Us consumerw are driven by the price tag no matter how small. Sure has me thinking about things.
My wife went shopping the other day and looking at some nice garlic she looked a little closer. The bloody stuff was from China. Good grief, we live right in the middle of heavy farming here and they ship it in from China? I have a few words about that but Jeff would have a few words about my words.
Quote from: donbj on June 26, 2020, 11:24:29 PM
In my life, I always thought it more plausible to save and buy better quality stuff. To buy instant and cheap seemed to me to just bring on more problems & issues. Yet here we are.......people buying P&C kits for $45 or
less.
Yes....you can't say anything personally insulting or use swear words here....learned that lesson. Can't even use the term "cheapskate", as someone would take that personally.
Kevin
Quote from: Real1shepherd on June 27, 2020, 10:05:32 AMYes....you can't say anything personally insulting or use swear words here....learned that lesson. Can't even use the term "cheapskate", as someone would take that personally.
My comment about words was meant in humour, not a jab at anything or anyone.
Kevin
I agree, getting mixed up with China was the wrong thing to do. But Stihl Husqvarna Makita and many others did, then the general public followed by dealing with them, online purchases taking more money out of the pockets of our neighbours, who lost their jobs because of the greed to put more profit in the hands of big business, even Boing got burned with the Chinese putting up their prices when their hands were tied as a result of their moving manufacturing to China.
I can only do my part, and have decided to try at all cost to buy nothing more that is made in China, I feel its not right to stand by and keep on giving for what in most cases amount to substandard products while we see good companies go under in our own towns, this is not political, it's common sense on every front, I see it as very unwise to count on China for any of my needs.
In all honesty, I let price influence my purchases too, but am awake now, and like the rest of the world will not alone loose any money I saved by buying Chinese products, but will be in great debt paying for the disaster that is Covid19. You can guess where I won't be shopping anymore.
I don't mind spending my money for overseas stuff as long as it's not from CERTAIN states and places. After all, when they get their quality up, so goes the good prices.
I'm just trying to be self moderating.
Quote from: donbj on June 26, 2020, 11:24:29 PMYup, we keep buying the stuff and they keep sending it. Us consumerw are driven by the price tag no matter how small. Sure has me thinking about things.
The last thing I remember making a decision about was standing in walmart looking at wiper blades. A US made blade was $16, and the one from Vietnam(I think) was $5. I was thinking "C'mon guys, work with me here..." I'd have gone twice as much to buy US, but $32 for a replacement set vs $10? That's a tough pill to swallow, especially for something like a piece of rubber on a stick. I ended up getting the import. Didn't feel too good about it, but...
I had the same dilemma but went with the U.S. made. Got tired of having to change crappy blades when I needed them most.
Quote from: lxskllr on June 28, 2020, 01:17:05 PM
Think on the lifestyle of the people providing these $10 blades, pretty grim a lot of them. Compare that to the $32 lifestyle we are trying to maintain.
Corporations here are just as much to blame by chasing the cheap labour to out do the competition. The day will come when we will be too dependant on foreign products and their market control.
Lots of what I own is Chinese or nothing i.e. I can afford a $5k lathe but I can't afford a $20k Southbend or US/English machine imported to NZ. So I have a Chinese lathe or I have no lathe =/. Sucks and I don't like it, but it is what it is.
Quote from: JoshNZ on June 29, 2020, 02:19:11 AM
For sure. We are all in the same boat with this Chinese situation. The part that gets me going is the tech theft and knocking off products that match brand name items. Best example here is the Chinese saws that can be "upgraded" with oem Husky and Stihl parts. If they want to design and market their own saws, they can go for it and see how it goes from there. If they are half the price of our brand names they'll probably sell. That's the thing, price tag rules.
Quote from: Greenerpastures on June 28, 2020, 10:45:48 AMI agree, getting mixed up with China was the wrong thing to do. But Stihl Husqvarna Makita and many others did
I don't think what country things are made in has much to do with quality its more to do with the company making it, 30 years ago I would generally avoid buying things made in the USA because of poor quality, (tools, electronics, vehicles....) the best stuff was made in Japan or Germany. When my mother was young the post war stuff from Japan was very poor quality. There is some very good quality stuff as well as poor coming from China. It seems to play over and over with the latest cheap place to make stuff, they start off poor quality but after a while they figure out that it is worth their while to improve quality.
I've had no problems with my made in China Makita chainsaw, I wish I could say the same thing about my made in Germany Stihl.
Quote from: Hilltop366 on June 29, 2020, 09:10:47 AM
It shifts like power & politics. Yes, post WWII Japanese stuff was junk. Then as you said, Japan & Germany became powerhouses in quality goods.
After bicycle companies like Raleigh quit making bikes in England, almost every bike frame in the world was made in Taiwan for a time. They were decent, but not especially 'hand crafted' like their predecessors. The sudden adult interest surge in bicycling created a demand that only mass produced bikes could fill.
And so it is with China who can make anything for a price point. They can also make quality products....but not at a price point. And then you have their human rights issues and politics. When you buy their products, you support that.
Kevin
Quote from: donbj on June 27, 2020, 10:42:12 PM
So was mine, but it still brought a wrath of hurt feelings.
Kevin
The last I did was an 036 cylinder on an 034 crankcase .I used a Meteor piston and have had reports it's still doing well after maybe 10 years .
I have another in the shed I don't think anything is wrong with it I had landed from a dealers" dead pile " which is an 034 Super which in essence is an 036 .That model is pretty snappy for it's size .I'm not certain if it runs the small or large sized rim sprockets .Doesn't make a diff I have plenty some place in a box .
Quote from: Al_Smith on June 30, 2020, 10:14:44 AM
Al, Stihl up graded the clutch drum to a larger bearing and larger sized rim somewhere in the 036 series. They sell a kit to convert the early saws.
I had an early 036 loose the bearing but the crank survived. It got the kit.
That 034 I upgraded had the tar beat out of it,tree trimmer you know .They lost the E-clip blew the bearing out broke a clutch segment and finally locked it up .I stuck it back together with parts i had laying around .I don't remember if I put the large bearing drum on it or not but I did use a clutch segment from I think an 029 and the springs .A guy from Louisiana on another forum sent me a cylinder from an 036 It survived to live another day .
The story goes on .I only ran it about 15 minutes ,did okay .Traded it off for a cherry 805 Mac ,I mean like a new one ,bad chrome on the cylinder.Got a used cylinder from an 850 ,back in business until I straight gassed it by mistake with a squeeze bottle ,oops .Found an early model 850,cheap,rough ,real good engine .So now it's an 805 hiding an 850 engine . You just never know where that road will take you ;D
The good thing about oil mixes is that they color the gas. If you don't see that color from the oil, then don't put the gas into you saw. I mark all my gas cans for 2 cycle. The other day I grabbed a gas can that wasn't marked and noticed the gas with no color going into my Stihl weed-eater. Was straight gas and so I dumped it out of the weed-eater. I'd only put a little in, but not taking any chances.
Not sure how anyone could fill an entire tank with straight gas and not notice there is no coloring. Label all your cans and stick to your system of marking.....
Kevin
That straight gas was just stupid mistake I made from being in a hurry .I've done almost the same thing by using an old anti freeze jug to store my mix gas in . Anti freezed a weed wacker and gasolined my old tractor .Duh :D
Quote from: Al_Smith on July 03, 2020, 08:38:28 AM
I use old 1- 2.5- oil jugs to recycle oil. I've grabbed one of those by mistake top top off, or when changing oil.
It's at least obvious if you notice the color.
I antifreezed the weed wacker first on that episode .The antifreeze and the mix gas were about the same color . The old tractor i knew immediately ..Didn't hurt anything .I just rebuilt the carb on the weed wacker .
Quote from: Real1shepherd on July 03, 2020, 07:51:18 AM
The good think about oil mixes is that they color the gas. If you don't see that color from the oil, then don't put the gas into you saw. I mark all my gas cans for 2 cycle. The other day I grabbed a gas can that wasn't marked and noticed the gas with no color going into my Stihl weed-eater. Was straight gas and so I dumped it out of the weed-eater. I'd only put a little in, but not taking any chances.
Kevin
91 octane (lowest grade at pump) is died red in NZ. Stihl chainsaw oil is red, I can't tell if it's mixed or not. Maybe if I pour it into a white ice-cream container and analyse side by side but I cant tell while pouring =[]
If you cut to the chase nobody intentionally straight gasses a two cycle . Anybody can make a mistake unless for arm chair quarterbacks that do nothing.
Quote from: JoshNZ on July 03, 2020, 06:47:00 PM
Kevin
That's a bummer.
At my age, my only salvation is to put gas in two cycles that was from a designated, marked can. When I was younger, I never made this mistake....ever.
I never heard of anybody straight gassing a 2 cycle(at least that they would admit to), except in the last ten yrs. Maybe it's just a function of being in a hurry.
Kevin
All my small cans(<5G) are 2stroke only, and I never fill them unless I'm adding oil at that time. It's virtually impossible for me to add straight gas to my gear.
Quote from: lxskllr on July 05, 2020, 11:56:56 AM
I use a chemistry graduated cylinder to measure out mix oil. Then do 2-5 gal of mix at a time.
I transfer the mixed fuel to repurposed labeled 1-gal Coleman/white gas metal cans. The cans are handy size to bring into the woods and they protect the mix from light and air/moisture. It's hard to mix those up as my stove/lantern fuel cans are with my camping gear and are not labeled mix
If you're needing portability, take a lesson from fire line fighters. They use special cans and have a 'system'.
In the woods for yrs I used the double cans that are oil/gas mix on one side and bar oil on the other. The ones Baileys used to sell I could slip my axe handle in. One arm carried that and the chainsaw/bar slung on my shoulder with the other arm.
Kevin
Just an update. I still haven't bothered with this saw yet. Too much else ahead of it on the to-do list. I did run across the parts book, so called to price some OEM parts.
Long story shortened: New Stihl crank, and bearings would run about $435 plus shipping, and sales tax. New MS 362 with new 20" bar and chain $767. Meteor cylinder kit was something like $135. That puts parts for the old saw at less than $200 below the cost of a new saw.
OEM bearings were only around $23 each, so I may get them, and try the chinese crank.
OEM crank, for more than half the cost of a new saw is not going to happen for this one.
Meteor now has the 'dirty' distinction of being partnered with Hyway in some way.....be aware.
Kevin
I have no doubt if you look around you could do it cheaper than that .I know I could and it would be fine .Of course it might take me a year to round up all the stuff to make it happen. :D Which is why you need a lot of saws so you have something to use . 8)
Quote from: Real1shepherd on September 03, 2020, 07:05:49 PM
Kevin
Put one in my 039 squeel about a year ago methinks.
The casting in the intake side needed some cleaning up
There was excessive (alloy) lumps in some places
Nikasil seemed fine.
Point is , I was learning about porting improvements at the time so no problem
Just playing around as a hobbyist.
But others may buy this stuff thinking it is good to go. It may go .. But not as good as..
