General Forestry => Forestry and Logging => Topic started by: J 5 on July 10, 2020, 06:27:16 AM
Title: Muskeg Skidder
Post by: J 5 on July 10, 2020, 06:27:16 AM
          Just finished this Muskeg, picked it up in oct 2017, it was an ex ontario hydro machine. At the time I was getting ready to use another hull and build a copy of a Jimmy Skidder, but this unit popped up , with only 400 hrs on a rebuilt dodge 318, to good to transform into a Jimmy.
         Tore it down, the usual suspension rebuild underneath, diff was good, clutch replace, 20 gallon pump  mounted off the crank, air compressor for the gearmatic, built a boom with fairlead and generally added what I wanted , for playing in the bush.
        I still plan on keeping my 2  J 5's as they are pretty nimble in tight spots . In the last couple months 2 Jimmy's showed up in my area, 1 for sale and the other in use by a distant neighbor..... never fails.  May have get one yet , or build one .
        J 5
(https://forestryforum.com/gallery/albums/userpics/14032/20171021_104055_-_Copy.jpg?easyrotate_cache=1594376394)
(https://forestryforum.com/gallery/albums/userpics/14032/2020-02-16_007_-_Copy.jpg?easyrotate_cache=1594376448)
(https://forestryforum.com/gallery/albums/userpics/14032/2020-05-18_may__6_2020_003_-_Copy.jpg?easyrotate_cache=1594376475)
(https://forestryforum.com/gallery/albums/userpics/14032/2020-07-07_july__2_005_-_Copy.jpg?easyrotate_cache=1594376508)
(https://forestryforum.com/gallery/albums/userpics/14032/2020-07-07_july__2_006_-_Copy.jpg?easyrotate_cache=1594376541)
Title: Re: Muskeg Skidder
Post by: moodnacreek on July 10, 2020, 07:43:20 AM
Nice work. Sounds like you know these machines. Why is it that when you settle for something the one you really wanted comes along.
Post by: gspren on July 10, 2020, 08:36:57 AM
That is neat looking, I have absolutely no need for something like that but I'd love to have it anyway! 8)
Post by: J 5 on July 10, 2020, 12:25:01 PM
Quote from: gspren on July 10, 2020, 08:36:57 AM
Yes , when the hull is stripped to a bathtub and your 16 wheels need  32 bearings repacked or replaced and  axles are bent. It crosses you mind "do I really need this "  !
   Unfortunately it's an addictive hobby for me.... I can't get enough of them !
        J 5
(https://forestryforum.com/gallery/albums/userpics/14032/july_10_-_Copy.jpg?easyrotate_cache=1594398168)
(https://forestryforum.com/gallery/albums/userpics/14032/july_10__2_-_Copy.jpg?easyrotate_cache=1594398195)
Post by: sprucebunny on July 10, 2020, 12:41:52 PM
I can't wait to see pictures of it hauling logs !
I did really enjoy working on my J5 and Muskeg but for various reasons didn't actually use them much. The Muskeg wouldn't turn with my log trailer attached and loaded; a physics problem that I don't understand and the J5 is a little light to tow the trailer but I do get around with the J5/trailer when half loaded on unsteep ground.
I even came to enjoy changing races and bearings ! And rebent each of the track backing plates for one track. I should change belts on the other track this summer to stay busy.
You are so lucky to have your machine shop tools and knowledge  :)
Post by: Andries on July 10, 2020, 01:54:57 PM
Quote from: sprucebunny on July 10, 2020, 12:41:52 PM.   .   You are so lucky to have your machine shop tools and knowledge  :)
Luck can play a big part, but dedication,  energy and smarts also play a big part.
Keep up the good work J5, loving these posts
Post by: BrushSaw on July 11, 2020, 12:03:04 PM
@J 5 (https://forestryforum.com/board/index.php?action=profile;u=4032) what model Gearmatic are you putting on the Muskeg?
Where do you source most of your muskeg parts?
Looking forward to more updates.
Post by: dgdrls on July 11, 2020, 01:20:27 PM
Quote from: J 5 on July 10, 2020, 12:25:01 PM
        J 5
The question becomes can I really do without it??  ;)
Its a dandy machine,  well done!
D
Post by: J 5 on July 11, 2020, 07:39:32 PM
Quote from: BrushSaw on July 11, 2020, 12:03:04 PM
Gearmatic N7A , 15000lbs one wrap on drum, 6612 lbs full drum .
        Muskeg parts the search never ends , and the prices keep climbing. That's  the only drawback  when it comes to these machines.
                                    J 5
Post by: Pine Ridge on July 11, 2020, 11:29:11 PM
I've never saw one of them in person, pictures only. It looks good, you've done some nice work there and you should be proud of it.
Post by: J 5 on January 10, 2021, 07:24:12 AM
             Not much snow here, makes for a rough ride. Hauled seven loads, with about four left, overall the Muskeg worked well , lots of power from the 318. Hope to do some skidding later on .
        J5
(https://forestryforum.com/gallery/albums/userpics/14032/2021-01-03_jan_2021_008_-_Copy.jpg?easyrotate_cache=1610281303)
(https://forestryforum.com/gallery/albums/userpics/14032/2021-01-03_jan_2021_013_-_Copy~0.jpg?easyrotate_cache=1610281377)
Post by: thecfarm on January 10, 2021, 07:44:42 AM
Looks good. Wood does not, but makes good firewood.  ;D  I cut out the junk too.
How are you loading that trailer?  I see a loader at the yard?
I could use one of those to cut the bog off. I cut some, but takes a lot of walking with a cable to do it. I walk out with 150 feet of cable, than hook another 100 feet to that. The deer like it when I am in there.  ;D
Post by: J 5 on January 10, 2021, 08:13:42 AM
  Full time job cutting the dead stuff, with a bit of green mixed in when the temps drop, our outside furnace is not picky.
                    Clam to load and push it off the trailers with the Loader/tractor back home, it doesn't get much easier !
                                J5
Post by: thecfarm on January 10, 2021, 09:01:12 AM
Oh yea, don't forget the skidding pictures.   ;D
Post by: nativewolf on January 10, 2021, 09:21:17 AM
Really neat thread.  Thanks!
Post by: Iwawoodwork on January 10, 2021, 12:48:20 PM
Your  photos of you Muskeg rebuild were good, I had not thought about the idle wheel bearings.  I have a "Jimmy" muskeg that has a 3 cyl Detroit, I broke the track on one side and have not repaired it yet, one of those "get to it" jobs that seems to keep  getting put off. Have since purchased a Cat D3 and  a Oregon Logger rubber tire skidder  and a Hitachi ex50 excavator so seem  to be always servicing them.
Post by: J 5 on January 10, 2021, 04:12:25 PM
     I'd be all over that Jimmy Skidder,  like a Fat kid on a Smartie  Lol ! Post some pictures if you get a chance .
                             J 5
Post by: J 5 on January 05, 2022, 06:06:30 AM
               Not much of the white stuff and nice temps , so we spent some time in the bush yesterday. First time to skid with the Muskeg, a few minor Hyd leaks to take care of, but it did well pulling some old maples out on some rough ground.
                                             J 5
(https://forestryforum.com/gallery/albums/userpics/14032/2022-01-04_Jan__1_2022_005_-_Copy.jpg?easyrotate_cache=1641380605)
(https://forestryforum.com/gallery/albums/userpics/14032/2022-01-04_Jan__1_2022_006_-_Copy.jpg?easyrotate_cache=1641380647)
Post by: thecfarm on January 05, 2022, 06:11:52 AM
Thanks for the skidding pictures!!!
Post by: SwampDonkey on January 06, 2022, 03:10:18 AM
I know a fella that used a F4 Dion forwarder. I see some used in Ontario as well as Quebec. It's quite old iron by now, anyone keeping them going. I used to see these machines once in awhile in Atlantic Forestry. ;D I've not had the magazine in awhile as it was mostly NS forestry after awhile. Logging and Sawmill Magazine was another source.
Post by: lshobie on January 06, 2022, 01:57:58 PM
Mines a little smaller, but I like yours!
             https://youtu.be/goxYa1Ijihg            (https://youtu.be/goxYa1Ijihg)
Post by: Quebecnewf on January 09, 2022, 06:38:31 AM
Quote from: lshobie on January 06, 2022, 01:57:58 PM
            [url=https://youtu.be/goxYa1Ijihg]Track Skidder Logging Day. - YouTube (https://youtu.be/goxYa1Ijihg)           [/url]
Great video . Very nice machines for sure . If ever Covid ends would love to visit your operations .
Love to see those old machines rebuilt and bouncing through the woods .
Quebecnewf
Post by: lshobie on January 10, 2022, 07:44:41 PM
Stop in anytime!
Post by: Tim on January 11, 2022, 09:07:40 AM
@J 5 (https://forestryforum.com/board/index.php?action=profile;u=4032) I'd trade you a tour of your machine for a tour of our shinglemill if you are in the Pembroke area at some point. I even have a 318 in a Ram 1500 that I have more use for the frame than the engine, if you are interested in having a spare around.
Post by: lshobie on January 11, 2022, 07:13:35 PM
Quote from: Tim on January 11, 2022, 09:07:40 AM
Im not far from you, do you buy cedar logs?
Post by: Tim on January 13, 2022, 01:19:54 PM
Quote from: lshobie on January 11, 2022, 07:13:35 PMIm not far from you, do you buy cedar logs?
I do buy cedar logs Ishobie
