General Forestry => Chainsaws => Topic started by: Ventryjr on September 18, 2020, 05:53:09 AM
Title: 661 bar selection
Post by: Ventryjr on September 18, 2020, 05:53:09 AM
So I came across a good deal on a new ms661. Long story short dealer ordered it w/ deposit for a guy before pandemic. Guy never picked it up.  It has a full wrap handle and came with a 36" rollomatic bar/chain and a 25" duromatic  bar/ skip tooth chain .  $1100 cash.   Is it in my head or does the duromatic bar rob a lot of power? It doesn't seem to perform as good as my older ms460 w/ 25" bar and skip tooth.  All the bars are stihl.   But I'm open to trying out other brands. I fell a lot of hard/soft wood and will be cutting logs to go on the mill this spring. Is it worth getting a different short bar? Maybe a 20" rollomatic? Thanks in advance
Title: Re: 661 bar selection
Post by: ButchC on September 18, 2020, 06:45:42 AM
When using the bottom of the bar the chain is not tensioned around the nose thus there is zero practical difference in power needed to operate the chain. I'd guess your power issue is a break in or tuning issue. I well rememer how much power my 661 picked up after about 5 tanks of fuel and owning both a 661 and a 461 I can also attest that for the first tank or two a brand new 661 will not embarrass  a well tuned and we'll broken in 461!
Post by: Ventryjr on September 18, 2020, 08:35:09 AM
I didn't even consider the break in period.  That does make sense.  I've only put about 1.5 tanks of gas thru it.
Post by: nativewolf on September 18, 2020, 09:07:26 AM
Not sure why you'd want a duramatic anymore.  The semi-skip chain it came with however, that is my favorite chain.
Post by: sawguy21 on September 18, 2020, 11:16:50 AM
IMO a 661 is wasted with a 25" bar, it is a lot of extra power and weight for nothing.
Post by: Greenhighlander on September 18, 2020, 05:44:15 PM
Quote from: Ventryjr on September 18, 2020, 08:35:09 AM
I know it is a different saw but it took at least 6 tanks or so for my 395 to come to life and I could tell a huge difference by 10-12 tanks.
Cheers
Post by: Ventryjr on September 20, 2020, 07:08:22 AM
I put another 3 tanks thru it yesterday cutting some firewood.  Seemed to pick up a little bit more.  Had to stop and tighten my chain about 10 times tho.  Over all I'm pretty happy with the saw.  It starts very easy.  First pull when warm.  Second pull cold.
Post by: lxskllr on September 20, 2020, 08:33:31 PM
Tens times is a lot if you're running decent chain. I've never used a hard nose, so maybe that has something to do with it, but make sure the bar's getting enough oil. The 661 has a compression pin you can punch in on the oiler adjustment, and turn it up higher. I keep mine maxed, and even with the 25" bar, I don't consider it too wet.
Post by: Ventryjr on September 21, 2020, 07:26:15 PM
Well the chain is/was brand new.  And I'll take a look at the oil adjustment.
Post by: alan gage on October 14, 2020, 04:07:58 PM
Quote from: sawguy21 on September 18, 2020, 11:16:50 AM
I got a 661 with 42" and 28" bar for ripping big logs to fit on the mill. I only used it with the 42" bar for quite a while because I had a smaller 70-something CC saw with 20" bar that handled pretty much everything else. One day I was bucking a bunch of 20-24" oak for firewood and after a couple logs decided to try the 661 with 28" bar. I couldn't believe how much faster it chewed through! Not saying everyone should run out and buy a 661 with a short bar but if you've already got a 661 I think it's worthwhile to have a shorter bar on it for cutting larger firewood. I doubt I will but I'm tempted to run a 20-24" bar on it for those situations for a little better balance.
I've used the 661 to drop a few trees and to me that feels like a lot of extra work compared to the 70cc saw but for bucking firewood where you're standing up and just letting the weight of the saw chew through the log it doesn't seem like much effort required on my part. Actually I'd say the 661 felt like less effort in the above scenario just because of how much quicker it got the job done.
Alan
Post by: Walnut Beast on October 14, 2020, 06:51:55 PM
Quote from: alan gage on October 14, 2020, 04:07:58 PM
Alan
That's what separate the men from the boys 😂
Post by: ehp on October 14, 2020, 11:04:34 PM
On the 661 I had I ran 25 inch most of the times and I always used every bit of power that saw could give me , its all in the gear and the chain setup. the dura bar will take quite abit more power to cut with than a good ES bar , have no idea on why anybody would want to run one unless in real dirty stuff
