General Forestry => General Board => Topic started by: metalspinner on May 09, 2021, 03:57:16 PM
Title: Tearing Stuff Up
Post by: metalspinner on May 09, 2021, 03:57:16 PM
It happened when hauling the load of T&G home. Saw smoke in my rear view mirror and eased on over to the shoulder of the highway. I'm lucky this wheel didn't go flying off! It wa dangling there like a loose front tooth.
Anyway, I called a tow truck and he scooped it up and set the trailer down back at my place.
The bottom of the spindle was gauled up pretty good. I had to use a cutoff wheel to remove what was left of the front bearing. It was "welded" to the spindle.
Anyway, I got it cleaned up and found a set of bearings locally.
(https://forestryforum.com/gallery/albums/userpics/12750/DB9FCECE-0309-473D-AE0C-12FBE1475A37.jpeg?easyrotate_cache=1620589745)
(https://forestryforum.com/gallery/albums/userpics/12750/B6C04766-18E1-47FC-9625-905DDCEEA4A2.jpeg?easyrotate_cache=1620589744)
(https://forestryforum.com/gallery/albums/userpics/12750/29B552D6-8DDC-45B1-B757-387C76410BD6.jpeg?easyrotate_cache=1620589747)
(https://forestryforum.com/gallery/albums/userpics/12750/5357EADD-9F9D-4525-A59D-B446B9232EAE.jpeg?easyrotate_cache=1620589748)
Title: Re: Tearing Stuff Up
Post by: mike_belben on May 09, 2021, 08:13:26 PM
BTDT!
Post by: Tacotodd on May 09, 2021, 08:41:08 PM
And THAT folks, is just 1 example of why we do periodic maintenance on our "stuff". Don't worry though, because you're far from alone. I've done stuff just like that WAY to many times, I did say way to many! 🤫
Water intrusion on 4X4 bearings are always what got me. In fact, water will ALWAYS figure out where the easiest spots to invade are. That's just 1 of the reasons that I don't play in the mud anymore. Rocks leave "battle scars" but don't tear up what water does.
Post by: Southside on May 09, 2021, 09:01:32 PM
It doesn't count if the wheel doesn't pass you in a turn.  :D
Post by: Tacotodd on May 09, 2021, 09:36:32 PM
I don't normally let trailer wheel brgs get that bad, but it's easy to forget vehicle brgs, especially when that was the only one that I was privileged to use.
Post by: mike_belben on May 09, 2021, 11:16:00 PM
Quote from: Southside on May 09, 2021, 09:01:32 PM
I think ive had 3 trailer tires pass me, and one steer with knuckle still attached.  Also left a trailer axle behind once.
Post by: Southside on May 09, 2021, 11:49:10 PM
Now that's getting into bragging territory!  :D
Post by: mike_belben on May 10, 2021, 01:04:14 AM
Maybe.  But i promise its not the kinda trophy anyone really wants to endure.  Im not doing much with a 1 axle gooseneck behind a 5 wheeler international these days.
Post by: HemlockKing on May 10, 2021, 03:49:04 AM
Quote from: Tacotodd on May 09, 2021, 08:41:08 PM
Off-roading your truck is a fast track way to just destroying it. I haven't been "off-roading" since I was a teenager  :D sunk my truck for 3 days nobody could pull it out, never again after that, atvs in mud only  ;D
Post by: Gary_C on May 10, 2021, 04:36:12 AM
Quote from: mike_belben on May 10, 2021, 01:04:14 AM
Me neither. In fact I've never seen a 5 wheeler before.
Post by: Sedgehammer on May 10, 2021, 07:14:59 AM
My dad had a goose with those type of trailer axles. N.E.V.E.R. again
Ticks me off that many hubs don't have a means of greasing them with a gun
Post by: mike_belben on May 10, 2021, 10:25:43 AM
Quote from: Gary_C on May 10, 2021, 04:36:12 AM
Start with a 6 wheeler and remove the steer spindle retaining mechanism at speed. Youll figure it out.
;D
