Lots of search results, so I may have missed it.
I know dull a blade and certain woods can be the culprit. But even with new blade I have had that string. Logs debarked and clean.
I've noticed that milling with the butt end first seems to eliminate those strings.
I like milling small end first, and maybe its not the fix, but had a few logs that were not worth spinning mill nicely.
Anyone else?
Strings happen. Depends on the species and grain orientation on the exit side. If the grain is running out you'll get more strings. A quick scrape down the corner with an edge tool of some sort will knock the strings off. A lower powered mill or a dull blade will make more strings. No big deal, just knock them off.
A little more detail about species, mill type, blade type and condition can help us give better feedback, but sometimes strings are just gonna happen. I just scrape down the corner (going WITH the grain) and knock them off. Takes about 4 seconds.
The strings are not an issue at all, just wondered if anyone else noticed a difference milling from small end of log versus butt end. I've even spun a cant and noticed a difference.
I use a scraper too, if I want to bother. Lumber for my own use as well.
Forgot species-White Pine.
Bandmill 14 hp. Woodland Mills. Think the blades are 4 degrees.
Gotcha. Switching ends can make a difference can change the string factor if it makes the grain run in instead of out on the exit side. Doesn't seem worth the effort to me compared to rotating to balance or counteract stress in the log.
Small end/big end gets discussed from time to time. Usually turns up more reasons to saw from the small end than the big end. Personal preference always seems to be the deciding factor. I used to like big end first, but then I just started sawing them as they showed up.
It'll be interesting to see if there's anyone who switches ends to reduce the string factor. I'm betting that it's rare.
I like milling from the small end too, and agree its not worth the effort spinning them.
Strings on any species are a good indication of a dulling band, but certainly not dull enough to change. I am aware of them, but don't worry about them.
I often wondered if I was the only one that wondered about the stringy shavings coming off.
What would Danny name these, I would ask myself ? @WDH (https://forestryforum.com/board/index.php?action=profile;u=4370) may even have a very long polysylabic word for them: "starting to get dull but not dull enough to change bands". . . . seems to be the answer from Yellowhammer.
I'll have to keep an eye on the 'top to bottom, no strings' theory. More of a "whaddya think" entertainment kind of thing, than an actual indicator of high level sawyer secret knowledge. 😆
It is complicated:
https://en.wikipedia.org/wiki/String_theor (https://en.wikipedia.org/wiki/String_theory)
Quote from: WDH on August 03, 2021, 07:15:18 PM
It is complicated:
Your submission certainly is!! Not sure the OP had that in mind.
Quote from: KenMac on August 03, 2021, 07:40:36 PM
It is complicated:
That would be the Mircosoft answer. Totally correct, yet of no help what so ever. :D
hugs, Brandi
Generally, when I'm pondering at what stages of "Paeneplumbeus finalumaufero" my band is in, I also think about the hidden secrets of string theory and the depths of quantum gravity. However, as far as I'm concerned, the most important question of string theory isn't about the mathematical description of the universe, but is more in line with "How DO they get all that string into a can of Silly String??"
Hmmmmm . . . I think somehow this will evolve into food references after a couple more replies.
YH, have you been throwing the weeds on the burn pile again? :laugh:
When single edging against the fence strings are a pain.
Quote from: YellowHammer on August 04, 2021, 11:04:53 PMat what stages of "Paeneplumbeus finalumaufero" my band is in
paene: almost, nearly
plumbeus: blunt, dull
aufero: carry/take/fetch/sweep/snatch away/off, remove, withdraw
finalum: the final 'ummmm' made before making up a Latin word
@YellowHammer (he may have spent a considerable time in school) may be quoting from Roman Army jarheads as they were carping about dull bands on their sawmills.
PS: maybe too much free time, which leads to posts like this, because we can't cross the border for the Pigroast. ;)
10° in pine, string meant the band was getting dull. Turbo 7 and a 51 HP Perkapiller in pine, strings just mean you are getting things done in a hurry.
I was wondering who would dissect the phrase and figure out the Latin. @Andries (https://forestryforum.com/board/index.php?action=profile;u=9307) takes the cake.
That Andries is a smart one too.
Forrest Gump's Mama: "Smart is as smart does."
I'm pleased with myself if I don't make the same mistake, six times in a row. 😆
Dulling teeth will cause stringing and only 1/3 of the teeth are cutting each side of the kerf beyond the band thickness. Therefore, the outer part of the set teeth will dull much quicker than the part that is within the thickness of the band where all the teeth are cutting in this area, therefore only doing 1/3 of the cutting that the outer set of the teeth are doing. Hmmmmm..... that's my thoughts and I'm sticking to it. ;D
i am a 71 year old sawyer and enjoy wdh,s and andrais reply but if the band is cutting straight and flat the strings interest me but i can live with it. Big word overloaded my small brain with his reply but i am use to that from him . We have been friends for years and i know when to be quiet and listen .
Too much fiber and I get stringy. smiley_smelly_skunk
I actually believe it happens whether the blade is sharp or dull, but increases as the blade dulls!
Specie of the wood also matters. Who here knew that specie is both singular and plural and that species has nothing to do with plants of any kind?
I stand advised.
