General Forestry => Forestry and Logging => Topic started by: livemusic on December 07, 2021, 08:42:23 PM
Title: How to keep skidded logs clean for saw
Post by: livemusic on December 07, 2021, 08:42:23 PM
Regarding harvesting for firewood... If you skid logs, how do you keep them clean enough to buck them with the saw? Not worry about it or is there a method? Lay the end touching the ground into a bonnet or something?
Title: Re: How to keep skidded logs clean for saw
Post by: mike_belben on December 07, 2021, 08:54:47 PM
pile them for a while and let the rain wash them. bark will fall off in time. then cut it up.
Post by: Old Greenhorn on December 07, 2021, 08:59:39 PM
Well for me, I try to keep the front of the log as high as I can, but log shape has an effect on which part drags and no matter who you try, given the variations in ground you skid over, the log can come in in various stages of 'messed up.' :D SO I try to adapt my bucking methods to avoid the dirt or cut so that the saw will be pushing the dirt out of the cut rather than into it. SO cutting down when the dirt is on the near side, or cutting up when the dirt is on the far side or doing a partial of each can work. Sometimes I plunge through the center of the log and cut up then down, or vice versa depending on dirt and compression and tension in the log. I accept that some dirt is 'part of the job' and frankly on 'clean wood' such as I cut this afternoon, I still see a spark fly out now and then for no apparent reason, halfway up the tree on something newly fallen. I don't see a way to eliminate it, so I don't worry about it. I am good at sharpening. OTOH avoiding rocks is still a serious concern and I do look all the time for any rocks that got driven into a skidded log. I bucked up some sugar maple last week that had a 10 penny nail with a ball of nylon twine around it and some aluminum wire to hold it all in place. It was 2" inside the outer sapwood, so maybe 25 years ago? I didn't hit it with the saw, but found the black stain when splitting and investigated (splitting wood, as we all know, can be pretty boring). No damage to anything, but a fun little find inside the tree. If I had hit that nail (missed it by 2") it would have been just as bad as cutting a stone apart.
Post by: BargeMonkey on December 07, 2021, 09:02:47 PM
Get the butt end as high as you can and drag it out top and all if you can.
Post by: moodnacreek on December 09, 2021, 07:42:07 AM
Skid on frozen ground after a snow.  A forwarder in a perfect world.
Post by: upnut on December 09, 2021, 08:26:18 AM
We usually loosely measure and mark our cuts then chip away any dirty bark with a sharp, light boys axe.
Scott B.
Post by: kantuckid on December 09, 2021, 09:28:15 AM
When possible, take a utility trailer or similar into the woods and locate near the work place, cut and toss into trailer after splitting on same site. I've thrown wood as far as my body allowed thus my trailers fenders are banged up from misses.
Post by: mike_belben on December 09, 2021, 09:35:21 AM
works good on back window glass too  ;D
Post by: upnut on December 09, 2021, 10:39:37 AM
Friend of mine killed their pet goat with an errant toss, tanned his hide and still have it, so there's that.... :D
        Just glad my Dad didn't think of that when i hit him square in the back with a mighty heave... 8)
Scott B.
Post by: cutterboy on December 10, 2021, 08:07:34 AM
Don't skid it. Carry it.
(https://forestryforum.com/gallery/albums/userpics/11157/DSC05341.JPG?easyrotate_cache=1632172372)
(https://forestryforum.com/gallery/albums/userpics/11157/DSC04965.JPG?easyrotate_cache=1614023349)
(https://forestryforum.com/gallery/albums/userpics/11157/DSC05503.JPG?easyrotate_cache=1637860486)
Post by: sublime68charger on December 10, 2021, 02:37:03 PM
I have a arch on the back of my ATV which able to get the front part  of the log up off the ground.  Also have a cutting deck I pull the logs up  on to with the ATV and then when blocking them I can cut all the way threw with out putting the saw blade in the ground.
(https://forestryforum.com/gallery/albums/userpics/40453/foreman_and_log~0.jpg?easyrotate_cache=1613785377)
(https://forestryforum.com/gallery/albums/userpics/40453/IMG_3298.JPG?easyrotate_cache=1489510674)
Post by: mike_belben on December 10, 2021, 04:08:53 PM
now thats a fine idea!
Post by: cutterboy on December 10, 2021, 04:56:54 PM
Hey 68charger, I love your cutting deck. That is a great idea.
Post by: sublime68charger on December 10, 2021, 05:12:13 PM
Quote from: mike_belben on December 10, 2021, 04:08:53 PM
log cutting deck build is here
pretty simple
ATV Firewood cutting Deck | The Garage Journal (https://www.garagejournal.com/forum/threads/atv-firewood-cutting-deck.355853/)
Post by: sublime68charger on December 10, 2021, 05:26:06 PM
Quote from: cutterboy on December 10, 2021, 04:56:54 PM
I have built 2 of them now.  I have 1 next to my wood boiler its had 3 years of weather and abuse now and probaly on its last go around.
2nd one is down in my wood land at a central point that I pull logs to cut them up at.
its quick easy to make and I can pull it around with the ATV to a different spot if needed.
It works keep the saw blade up out of the dirt and able to get blocks cut with out having to roll the log over to finish them off.  also gives you marked off cutting spots for each block makes your block all the same length.  Well cept for the ends where you free hand mark those to cut off.  Though if following the preset marks you sometime end up cutting a knot or limb not quite where you want to but can always cheat it 1 way or the other the 2x4 cross braces due have some saw marks in them LOL!
Post by: sublime68charger on December 10, 2021, 05:30:20 PM
atv goes right up on the deck most times been a time or 2 that I have spun out trying to pull a bigger log then I should have or its got wedged in the board you just cut that block off and re hook and go again.  can always make the wood log smaller and pull what you can to the deck or up onto the deck. Hook the next section and go again.
My 2nd ATV cutting deck has a wooded ramp leading up onto it and if its a little wet its slippery but If I have good speed on approach i can make it up the ramp and get front tires on the deck with better grip before the rear end spins out on the ramp.
I'll get a pic next time I'm down in the wood land where that deck is at.
Post by: livemusic on December 10, 2021, 11:49:26 PM
When you mentioned the cutting deck, I was intrigued and then you showed pics and explained, it's great!
If I were to use a log arch, I would need to widen some turns in my trails! I dunno how much it affects turning radius.
Post by: Ed_K on December 11, 2021, 08:26:07 AM
 Here's an idea to add to that deck. Find or build a lift like they use for motorcycles to put under it then when the blocks are cut lift the deck to waist height to carry to the splitter  ;) .
Post by: mike_belben on December 11, 2021, 10:45:56 AM
Skidding onto a motorcycle lift that raises onto a dead or live deck infeeding even a hillbilly manual processor like mine would be great.  It really would take the labor out and make it fun.
Post by: moodnacreek on December 11, 2021, 08:50:11 PM
Quote from: mike_belben on December 11, 2021, 10:45:56 AM
Build yourself a slasher saw from an old sawmill mandrel and an insert saw that won't run right [on a mill]. You probably got enough junk to do it. If not I do.
Post by: charles mann on December 11, 2021, 09:53:01 PM
Buck on site, if that is not possible, log arch or just not worry about it and hose it off/let nature wash it off.
Post by: Hogdaddy on December 11, 2021, 11:12:17 PM
Hard to do... but lift up high and TRY to keep them out of the mud. Mostly impossible to do in hills and hollers... just keep a file handy.
Post by: mike_belben on December 12, 2021, 08:15:21 AM
Quote from: moodnacreek on December 11, 2021, 08:50:11 PM
People decided circle blades are art-deco fodder at some point and started wanting more for them rusted and bent with no inserts than they cost oiled and new.  Ive not had much luck getting old circles and really have tried!  Ive got some old small blades but they go on a huge hub.
Post by: moodnacreek on December 12, 2021, 09:32:24 AM
Mike, most of those old saws are worth little. To have one to use for cut off it must be one of the 4 patterns still made so you can buy teeth. Somebody once made angled teeth to cross cut with a 2 1/2 pattern mill [rip] saw.  You used to see circle saw firewood processors using these as opposed to an expensive, heavy and thick slasher saw blade. The trick is to run them cool.
Post by: mike_belben on December 12, 2021, 09:58:54 AM
if you got one you wanna do some tradin on you just holler
Post by: upnut on December 12, 2021, 10:54:53 AM
Quote from: mike_belben on December 12, 2021, 08:15:21 AM
(https://forestryforum.com/gallery/albums/userpics/38622/anne_s_new_painting.jpg?easyrotate_cache=1598305298)
Imagine that.....Scott B.
Post by: sublime68charger on December 12, 2021, 02:52:26 PM
Quote from: livemusic on December 10, 2021, 11:49:26 PM
The Log arch on my ATV I can turn as tight as the ATV turns for the most part all depends if the log is heavy then it'll take a bit more to get turned but if I have to I can back up some and wiggle my way around a tree if needed.  The Honda foreman dosn't have the best turning radius to begin with but it has worked good for me.
Post by: sublime68charger on December 12, 2021, 02:56:11 PM
Quote from: Ed_K on December 11, 2021, 08:26:07 AM
My other deck is a bit higher its up on some bricks to give it more height,  Heck even have the blocks a bit higher than on the ground helps and then I use these for picking them up saves me from having to bend over alot to pick up blocks.
(https://forestryforum.com/gallery/albums/userpics/40453/20211124_174248.jpg?easyrotate_cache=1637855891)
Post by: 47sawdust on December 12, 2021, 03:50:48 PM
Never seen tongs like that.
What is their history?
Post by: sublime68charger on December 12, 2021, 04:41:15 PM
Quote from: 47sawdust on December 12, 2021, 03:50:48 PM
Gifford Wood Co is stamped on the little one on the right. I have had for 10 years and its Handy as all get out. bought it on a whim at a garage sale and its been a back saver for picking up firewood on the ground pick up 1 or 2 or 3-4 if smaller put them under left arm pick up a bigger one and take bunch of firewood on the walk to the stack vs the just picking up by hand.  I due a search every now and then and the bigger just showed up on ebay listing last month and I bought it without a seconds hesitation.  I love that you can open the jaws buy squeezing the handle.  Save's me alot of bending over to pick up firewood on the ground or even to lift the end of a log to get the choker chain under the end.
I have stopped at alot of antique shops and showed the picture asking if the have any and nobodys ever seen that desgin expect for the Pic I have.
I'm happer than a pig in stink that I now have 2 I can use or the kids wont fight over the 1 any more when there helping pick up firewood.
