General Forestry => Sawmills and Milling => Topic started by: welderskelter on May 01, 2022, 08:04:16 PM
Title: Sawing dry Tamarack
Post by: welderskelter on May 01, 2022, 08:04:16 PM
I was given a bunch of tamarack logs. The guy says they are dry. Are they going to be hard to build with cause they are so hard. Will they also be hard to saw on the mill?
Title: Re: Sawing dry Tamarack
Post by: barbender on May 01, 2022, 08:23:37 PM
It is a hard softwood. The main battle when sawing it is keeping pitch off of your blade, and learning to read tamarack logs for which ones are worth sawing and which ones are better used as firewood. Butt logs with large bells, and ones with spiral grain get passed over unless I'm just sawing blocking or something. Tamarack is unique in how much the sawn lumber will follow the shape of the log. If the log has a big stump flare, the lumber will look like a hockey stick. If the log has a 4" sweep, the lumber will too. Tamarack says, "I grew that way and you're not going to change me"😁
Post by: moodnacreek on May 01, 2022, 09:05:47 PM
For rough cut 1" exterior siding, fence or wagon boards, tamarack is what you want. Sawn thick you better bolt it down today and keep tightening.
Post by: welderskelter on May 01, 2022, 09:48:47 PM
Dont sound good. I was wanting to build a wood shed and use them as the posts
Post by: ladylake on May 02, 2022, 03:34:25 AM
 I'd think  Tamarack would work fine for shed post ,put it up soon as possible.  Steve
Post by: welderskelter on May 02, 2022, 09:30:37 AM
Ladylake I like your idea best . I figured they wouldnt warp so bad as they are airdried in the log.
Post by: moodnacreek on May 02, 2022, 12:55:38 PM
Quote from: welderskelter on May 02, 2022, 09:30:37 AM
Air dried in the log means rot and cracks and still wet in the center. Saw logs should not be allowed to dry and get warm.
Post by: ladylake on May 02, 2022, 05:53:02 PM
 If the bark falls off tamarack it will last a long time in the log form, if the bark stay on it will rot around the outside fast. Lots of buildings , fences ,hayracks , silos etc were built out of Tamarack in the past.  Steve
Post by: Mooseherder on May 02, 2022, 08:34:56 PM
I used Tamarack probably similar to what you're describing to re-deck my trailer.  There was just enough to cover but I had to use a couple of pieces that had twisted some but still okay for this purpose.  You can saw all of the lumber for your project if you got enough logs.  :)
It makes purty trailer boards.
(https://forestryforum.com/gallery/albums/userpics/13635/20200907_175103.jpg?easyrotate_cache=1651537592)
Post by: KWood255 on May 02, 2022, 09:46:10 PM
Quote from: welderskelter on May 01, 2022, 08:04:16 PM
I cut around 500bf of dry tamarack today. It seems to have a lot more memory/stress in the log compared to red/Jack pine or white spruce. Not as bad as poplar or birch though! It's beautiful looking lumber in my opinion.
Post by: KWood255 on May 02, 2022, 09:47:53 PM
Quote from: KWood255 on May 02, 2022, 09:46:10 PM
(https://forestryforum.com/gallery/albums/userpics/34884/B8D6A5FB-A722-4895-A7B3-69D3CDB220FA.jpeg?easyrotate_cache=1651542440)
Post by: barbender on May 02, 2022, 10:51:11 PM
It is pretty stuff. Like I said, learning to recognize the logs that are likely to give you problems and setting them to the side is half the battle with tamarack.
