General Forestry => Forestry and Logging => Topic started by: BurkettvilleBob on August 29, 2022, 08:15:49 PM
Title: Clark 665D Axles
Post by: BurkettvilleBob on August 29, 2022, 08:15:49 PM
Does anyone know what axles are under a 665D and where I might find a breakdown of the axle assembly?
A picture would be worth at least 100 words, but looked at a machine with suspicious rustholes on what whatever part attaches to the outboard end of the axle tube. I'm wondering if water and dirt entering there is damaging wheel bearings.
Title: Re: Clark 665D Axles
Post by: C5C Tree Farmer on August 30, 2022, 10:10:03 AM
Pull the the drain plug on the outboard planetary unit. If the oil is milky it has water in it. If the magnet on the drain plug has a large "icicle" of ground up metal filings stuck to it that is a sure sign of either wheel bearing or planetary gear train failure. In my experience the gear train failed first.
Post by: BurkettvilleBob on August 30, 2022, 01:06:58 PM
Good idea, thanks.
