General Forestry => Sawmills and Milling => Topic started by: alecs on September 10, 2022, 05:22:52 PM
Title: Lumber storage idea - adjustable pallet
Post by: alecs on September 10, 2022, 05:22:52 PM
Hi,
I started making pallets to stack and sticker my lumber on, thinking it would be easier to move them around with my FEL.  But what length to make?  I had this idea today which seems to work OK.  I have come up with a base 10' long pallet with slide out telescoping wings to accommodate 12 and 14' boards. Seems to work OK so far, will update if that changes one way or the other!
(https://forestryforum.com/gallery/albums/userpics/32289/IMG_5415.jpg?easyrotate_cache=1662844711)
(https://forestryforum.com/gallery/albums/userpics/32289/68452121291__6ADA2D43-7501-41D5-8B8E-D252038BF05B.jpg?easyrotate_cache=1662844692)
For what it's worth, the white shed in the background is what housed the former sawmill at this property - which was water powered!  According to local lore, the shed got moved to this side of the property around the 1920s after the water powered mill (1676-1870s) had become defunct.  The mill owners at that time had moved their operation to the center of town where it had access to the railroad for easier transport of raw materials and finished goods, and made it a steam-powered mill.  So that's what my tagline means.
Title: Re: Lumber storage idea - adjustable pallet
Post by: doc henderson on September 10, 2022, 05:56:00 PM
bright idea alecs! bon_fire
Post by: JoshNZ on September 10, 2022, 06:46:11 PM
Do you not find your stack sags a bit across your fillets without runners under them?
Post by: Guido Salvage on September 10, 2022, 08:32:02 PM
It seems like you are adding unnecessary weight to what your loader must pick up. I stack mine on 4x4 posts that I can easily get my forks under.
Post by: Walnut Beast on September 10, 2022, 09:40:37 PM
I would have a little more overlap on your frame extensions on your pallet for the next ones. Seems a little wide also without a support on the 1" material
Post by: doc henderson on September 11, 2022, 12:16:32 AM
you could pull them when not being used, and could overlap a bit further.  try them out and see if they work for you.
