General Forestry => Drying and Processing => Topic started by: Mesquite cutter on January 06, 2023, 06:02:05 AM
Title: What moister meter to buy?
Post by: Mesquite cutter on January 06, 2023, 06:02:05 AM
I am undecided on what moister meter to buy.   There are so many out there.  I was looking at the Wagner brand.  Even that brand has many different models to pick from.   I plan on using it to measure MC on slabs ranging from 1 inch to 6 inches thick.  It will many be used on mesquite, oak and ash.  What brand do ya'll recommend?
Title: Re: What moister meter to buy?
Post by: doc henderson on January 06, 2023, 06:08:31 AM
It depends on the use.  I think for thick stuff, I would like the painless Wagner.  that is all I really use.  It becomes relative at some point as they only penetrate so far.  I have one I have had for 7 years and still my daily "beater".  I have one of the new ones, and I leave it in the case in a drawer and take it out for special occasions.  they work well.  I leave mine set at 55 for specific gravity.  that covers most hardwoods I mill.  I will check pine and know that the number will be low for the real M.C., but can follow the water loss.  It works great for what I do, but if I got a kiln, I may add the Delmhorst.
Post by: Stephen1 on January 06, 2023, 09:36:46 AM
What is the final use of the wood. Are you kiln drying? Are selling the wood?
Anything over 2" thick needs a probe. Delmorst J2000 or the newer model with the hammer probe.
I like the Wagner and when I have another spare  $500 I will buy the surface meter.
I am adding this
I have the J-2000 with the hammer probe now and could not operate without it. It is imperative that I know what the moisture content is at the centre of the thick wood.
Post by: K-Guy on January 06, 2023, 09:40:46 AM
I only recommend pin type only, like the one in the link below. Pinless meters don't always read thicker material well.
https://www.nyle.com/lumber-drying-systems/kiln-store/kiln-accessories-2/delmhorst/delmhorst-jx30-moisture-meter-package/
Post by: Mesquite cutter on January 06, 2023, 08:32:49 PM
Quote from: Stephen1 on January 06, 2023, 09:36:46 AM
I am adding this
For now, I am only selling the slabs.   Most of the slabs are 2 inches or thinner.   I have a few slabs that are cut for fireplace mantels but not many.
Post by: Mesquite cutter on January 06, 2023, 08:38:22 PM
Quote from: K-Guy on January 06, 2023, 09:40:46 AM
Wow, the price is bit steep but I am sure it will eliminate errors.    Right now most of my customers are purchasing the mesquite wood air dried.   I let them know before they buy.   I have not had any problems.    I want to build the solar kiln so I can pick up the serious wood worker that wants dried wood.   And I will be able to sell the slabs for a bit more money.
Post by: Larry on January 06, 2023, 09:31:31 PM
I have three.  The first two I bought 28 years ago.  One was a Wagner pinless and the other was a Electrophysics, both pretty high end for the time.  The third is a Delmhorst J-2000 which is fairly new.  The Wagner still gives good readings but a bit on the high side compared to oven dry.  The Electrophysics has been flaky for a couple of years now.  The J-2000 has always been closest to oven dry.
I mostly use the J-2000 in the kiln but use the Wagner a lot to check lumber in storage or if I want to check for wet spots.
A little story.  I sawed a lot of 10/4 walnut live edge slabs for a guy.  He air drys than sometimes gets a few kiln dried.  Wanting to check the MC he bought a meter at Harbor Freight.  He called and said his air dried slabs were reading 7%.  A bit skeptical he brought his meter out to check against mind.  His meter read 7% on everything!!! no matter how wet.  Quick thinking on my part I could get rid of my kiln and buy his meter. :D :D :D
