General Forestry => General Board => Topic started by: PAmizerman on January 16, 2023, 07:35:54 PM
Let me know what you have
4'x12' would be ideal
You may want to look into get a couple smaller tables and building a top to go across both of them. a table of that size is going to be very hard to find and very expensive.
I have a motorcycle lift that is wide enough to drive a quad on. You can get them in air, hydraulic or an electric motor for the lift part. If you want the table larger you could mount a wood top over it.
Just a thought.
Harbor freight has a motorcycle lift that measures about 3 x 8. I use one as a variable height work table. Raise it up to desk height for a single board, lower it to build boxes and cabinets, lower yet for sanding a chest of drawers.
