General Forestry => Ask The Forester => Topic started by: Gumpisan on January 21, 2023, 12:12:04 PM
Title: What is this growing on all of my bushes and trees?
Post by: Gumpisan on January 21, 2023, 12:12:04 PM
Hi, My property is located near Pensacola Florida. Ever since Hurricane Sally, there has been something growing and consuming all of our trees and bushes. It is growing on Oak trees, Tallow trees, Magnolia trees and even Blueberry bushes. Can you please identify it and tell us if we can do anything to stop it. Thank you!
>(https://forestryforum.com/gallery/albums/userpics/57330/IMG_2374.jpg?easyrotate_cache=1674320327)
(https://forestryforum.com/gallery/albums/userpics/57330/IMG_2372.jpg?easyrotate_cache=1674320326)
(https://forestryforum.com/gallery/albums/userpics/57330/IMG_2370.jpg?easyrotate_cache=1674320326)
(https://forestryforum.com/gallery/albums/userpics/57330/IMG_2368.jpg?easyrotate_cache=1674320326)
(https://forestryforum.com/gallery/albums/userpics/57330/IMG_2366.jpg?easyrotate_cache=1674320325)
(https://forestryforum.com/gallery/albums/userpics/57330/IMG_2367.jpg?easyrotate_cache=1674320325)
(https://forestryforum.com/gallery/albums/userpics/57330/IMG_2364.jpg?easyrotate_cache=1674320323)
(https://forestryforum.com/gallery/albums/userpics/57330/IMG_2365.jpg?easyrotate_cache=1674320323)
Title: Re: What is this growing on all of my bushes and trees?
Post by: rusticretreater on January 21, 2023, 12:43:01 PM
That is lichen.
https://www.bladenjournal.com/news/agriculture/17004/lichen-cute-and-fuzzy-but-also-a-serious-problem (https://www.bladenjournal.com/news/agriculture/17004/lichen-cute-and-fuzzy-but-also-a-serious-problem)
If you absolutely must remove lichen, spray your branches with a gentle soapy solution. After wetting the lichen, you can use a natural-bristle scrub brush and gently exfoliate the lichen off. Don't scrub hard, especially on young, thin bark. You can wash off the residue with a stream of water from your garden hose.
TREATMENT ON TREES In late autumn and winter you can use Lime Sulphur to remove lichen on deciduous trees only. Do not use it on evergreens, as they will defoliate (lose their leaves) and will not recover.
Post by: barbender on January 21, 2023, 01:19:48 PM
Is it mistletoe?
Post by: Gumpisan on January 21, 2023, 01:53:11 PM
Thank you for the information!! Would it be safe to use the " Lime Sulphur" solution on Oak and Magnolia trees because they don't lose their leaves?
Post by: barbender on January 21, 2023, 02:21:54 PM
I really don't know, I'm not even sure what it is. It does look like the mistletoe we have up here, and I know there is a different variety in the South.
Someone with more knowledge of your area will be along. @caveman (https://forestryforum.com/board/index.php?action=profile;u=12883)
Post by: barbender on January 21, 2023, 02:24:06 PM
Sorry RR, I completely overlooked your post. It does look like the stuff in the article you linked.
Post by: Ianab on January 21, 2023, 02:34:45 PM
I wouldn't be too worried about lichen, it's not feeding on the trees or really harming them. Here in my part of NZ is will grow on anything that's not moving. Rocks, fences, cars etc.
If it's only appeared after the storm it's possible that more light is getting into the area, due to missing / damaged trees? That type seems to need some direct sun to grow, a more shaded spot will tend to grow mosses etc. It is often seen on dead / dying trees, but again I think that's due to more light reaching lower branches, not the lichen killing the tree.
So just be careful you don't kill the trees trying to remove it.
Post by: rusticretreater on January 21, 2023, 02:57:37 PM
Quote from: Gumpisan on January 21, 2023, 01:53:11 PMThank you for the information!! Would it be safe to use the " Lime Sulphur" solution on Oak and Magnolia trees because they don't lose their leaves?
You have to be careful with Magnolia trees as there are both deciduous and evergreen varieties. how can you know if it is one of the deciduous magnolia varieties? If the plant is just showing flowers but the leaves have not yet unfurled, it is a deciduous form.  You can try using a tree ID app to help you out.
There are some oak trees labeled evergreen, but if the tree drops its leaves in the fall it is ok to use the lime sulphur on it.
Post by: KEC on January 21, 2023, 05:39:23 PM
Likely some kind of Usnea.
Post by: caveman on January 21, 2023, 08:42:53 PM
Looks like lichens to me.  It should not cause any harm to your trees.
