I've done a fair amount of work with chainsaws and have never seen this happen. Chain came off during side cut and I was having difficulty getting it back on when I noticed damage to sprocket teeth on chain. Several chewed up to some degree, two in particular, badly. Possible to clean these up with a file and still use chain? It's bran new.
(https://forestryforum.com/gallery/albums/userpics/72561/IMG_2644.jpg?easyrotate_cache=1676504197)
I have done that many times. Put the file to it and let it rip!!!
:D Thanks!
I had damaged the teeth on a chain as well when it came off like yours did. A file will work but a dremel tool is even better to remove the burrs and dings.
Yup file the burrs off so it sits in the bar and you're good. Might have a few teeth to clean up too😄
I would say no. The drivers are damaged too bad. Three in a row are damaged with the ends gone and that is about all that are in the drive sprocket at any one time.
I'd say try it and see. My concerns are with Grandpa's due to having a few consecutive drivers severely damaged. I've tidied up one or two, and it worked fine, but not that many in a row.
I would grab the cordless four inch grinder and touch the drivers up and put it back on. Normally it doesn't damage them that badly when the chain comes off. Since its a new chain I would give it a try. If it was a older chain I would toss it.
I've had this happen a time or two.I took mine to a saw shop and they can replace damaged section.
If it were mine I'd hang it on a nail and use it for repairs .Some you can save but that one you can't because in that shape all it will do is ruin the rim or sprocket .
I have had lots of chains come off , especially when cutting brush and berry vines. Take it off, then I would clean it up ( taking the burrs off the edges of the drivers) with my 41/2" grinder with a thin cutoff blade then try running it, if I felt it jump, I would take the chain off and punch out the three links and replace with good ones and put it back to work.
Minor burrs on the drivers I would clean up and use again. You have several in a row that are badly damaged enough that I would be concerned to run them. It MIGHT be something I would try if the bd ones were widely interspersed among good drivers so I knew some would have a good grip on the drive sprocket. as it is, I'd be inclined not to use it (or maybe use it for parts, if I were spinning my own chain).
It's probably worth taking a look at your drive sprocket to see what condition it is in. It may be time to replace it.
Put it on loose, rev it, tighten, done.
But not sure about those drivers missing the tips...
