General Forestry => Sawmills and Milling => Topic started by: Dewey on September 27, 2023, 02:18:03 PM
Title: Edger conversion form Gas to Electric
Post by: Dewey on September 27, 2023, 02:18:03 PM
I have a Thomas Edger that is gas powered with a 8.5 HP Honda.
Want to convert it to a 10 HP Electric single phase.
I can't go 3phase because my sawmill is run with a phase convertor.
I don't have enough electric power to run another.
With gas there is a clutch that engages when RPM is up there.
With electric the RPM are instant... DO you think there would be a problem or should I incorporate the clutch somehow. Or should I not use a clutch ( I'd prefer)
Title: Re: Edger conversion form Gas to Electric
Post by: charles mann on September 27, 2023, 03:05:59 PM
Use a single phase motor speed control and bring the rpms up gradually.
Post by: Bruno of NH on September 27, 2023, 04:33:45 PM
I wouldn't think it would be any different than my single ph unisaw cabinet table saw
It has just on and off
The Woodmizer eg 100 is single ph , I don't know if it has speed control of the arbor
The belts do
Post by: Southside on September 27, 2023, 08:32:04 PM
I have a 7.5HP farm duty motor on my 725, just push the start button on the contacter and off she goes, zero to zoom instantly.  The only thing you need to make sure of is that you have enough amps available for the start up load.
Post by: PAmizerman on September 28, 2023, 08:47:40 AM
I would try it without first
You can always ad a soft starter later.
You could also use a VFD. There's settings in the parameters for ramp up and coast down
Post by: scsmith42 on September 28, 2023, 09:28:28 AM
Here is what may be your best solution.
1 - get a good, used 3 phase electric motor for your edger.  My Woodmizer twin blade edger uses 15hp and that's marginal for 8/4 oak.
2 - use a VFD (Variable Frequency Drive) to convert from single phase to 3 phase for the edger.  VFD's also allow you to bring the speed up slowly.
This way you can benefit from a larger 3-phase motor and have a soft start system to boot.
Post by: muggs on September 28, 2023, 11:17:47 AM
I think I will chime in here. A few points. A VFD will not work on a single phase motor. If you are satisfied with the power of your 8.5 hp gas engine. A 5 hp electric motor would be about equal. I have 15 and 20 hp single phase motors but the shipping would be a killer. How big is your service coming in?
Post by: SawyerTed on September 28, 2023, 11:50:34 AM
If you can figure out a 3 phase solution, you'll get better performance and lower amperage draw.
Full Load Current on a 10 hp single phase motor will run around 100 amps at 220 volts.
FLC on a 3 phase 10 hp motor will be 28-30 amps at 220 volts.
Depending upon the service entrance amperage 100 amps could max out the service.   That's especially true if your mill is already on the service.
Even if the motor never reached FLC, half is still 50 amps on the single phase.
Switching to lower hp than 10 hp 3 phase would be the alternative.  FLC on a 5 hp 3 phase is 18-20 amps at 220 volts.
Smaller motor, smaller amperage will make wiring less expensive.
Post by: Southside on September 28, 2023, 09:23:03 PM
Muggs - what did that 20HP come off of?  Didn't realize you could get a single phase that large.
Post by: PAmizerman on September 28, 2023, 10:02:05 PM
@muggs (https://forestryforum.com/board/index.php?action=profile;u=31240) they make a single phase to single phase VFD
They are just crazy expensive
Post by: Southside on September 28, 2023, 10:49:19 PM
Browsing around on CL just now I came across a 250HP, waterproof, 3PH, NOS, motor for sale in Richmond.  That will likely handle 8/4 oak just fine.  :D
Post by: muggs on September 29, 2023, 04:26:02 PM
PAmizerman I learned something new. Southside, yea 250 hp ought to turn the blades 8) The big motors are heavily modified 3 phase motors, I have a small motor shop. I will see if I can put up a video.Bob Motor July 2020 - YouTube (https://www.youtube.com/watch?v=i4SjEgr_774)
Post by: bushhog920 on September 29, 2023, 06:21:16 PM
Look into Soft starters.
(https://forestryforum.com/gallery/albums/userpics/20928/Screenshot_2023-09-29-17-21-43-470_28129.jpg?easyrotate_cache=1696026010)
(https://forestryforum.com/gallery/albums/userpics/20928/Screenshot_2023-09-29-17-22-11-080.jpg?easyrotate_cache=1696026010)
Post by: Southside on September 29, 2023, 11:43:51 PM
Ok Muggs - you got me.  HOW did you do that?  Is it economical to do?  What is the size limit on such a modification?  What voltage motor do you need to start with?  You have absolutely peaked my attention.
Post by: Ianab on September 30, 2023, 12:41:26 AM
Soft starters would get around having marginal power supply to start a large motor.  A motor that needs 20A to run, might need 40 or 50 to get it started. Maybe only for a couple of seconds, but long enough to blow a fuse or brown out the power. Soft starter ramps up the current slower, might take a couple more seconds to spin up, but you dont have that initial spike, and should be OK running a 20A motor on a 20A circuit.
Post by: muggs on September 30, 2023, 02:49:07 PM
Quote from: Southside on September 29, 2023, 11:43:51 PM
Southside, this is the most I can say. The 3 phase motor needs a partial rewind. A lot of components are added. Voltage needs to be 230V. Size limit depends on the size of your incoming power and my ability to lift it. These motors will also work as a phase converter with a slight change in wiring in the junction box. All motors can't be converted, I need to see inside of it. cost is about $100 a horsepower. Biggest drawback is shipping. I think I live in the wrong state. :'(
Post by: Southside on September 30, 2023, 09:11:01 PM
Is this something you figured out?  Seriously I am amazed at this.
Post by: muggs on September 30, 2023, 10:55:42 PM
Quote from: Southside on September 30, 2023, 09:11:01 PM
First. I have background in electrical. It was several years in the making. Studying other peoples patents. Making every mistake there is. Writing down the mistakes. Keep moving forward. Finally success.
Post by: Sod saw on October 05, 2023, 12:42:48 PM
muggs,  I think that I may be confused (normal for me).
In your video, you started two machines.  The one with the two display readouts, , ,  was that the motor in question?  Was the top display showing voltage?  What was the bottom readout showing?
Post by: muggs on October 05, 2023, 05:33:16 PM
Quote from: Sod saw on October 05, 2023, 12:42:48 PM
On the displays, the top one is voltage, bottom one is amperage. Yes that is the cutterhead motor ( the modified motor) The second motor I started is the feed motor, no connection to the cutterhead motor.
Post by: Sod saw on October 05, 2023, 07:58:27 PM
Thanks for clearing up the display question.
Which motor is the one that you changed from 3 phase to single phase?
Post by: muggs on October 05, 2023, 08:43:02 PM
Quote from: Sod saw on October 05, 2023, 07:58:27 PM
The main motor, the one that powers the cutterhead   5 HP
Post by: Sod saw on October 05, 2023, 09:19:17 PM
Let me see if I understand this.
A normal single phase 5 hp motor at 230 Volts will draw in the neighborhood of just under 30 amps operating full load but not locked rotor.  I will not talk about inrush here, for now.
A normal 3 phase 5 hp motor at 230 volts will draw in the neighborhood of about 15 amps operating full load but not locked rotor.
Your converted 3 phase 5 hp motor operating on single phase 230 volts is drawing just under 7 amps with full load but not locked rotor.        According to your video.
If I understand correctly, the cost to change from 3 phase to 1 phase; a 5 hp motor is about $500, plus the initial cost of the 3 phase 5 hp motor (or tool with that motor).
Please correct me if I am off base here.   My impression is that a small 3 phase motor might be less costly to replace with a single phase motor but a larger motor might be less costly for you to modify it compared to changing over your (our) electric service entrance equipment.
If your ratio of current draw "savings" follows thru as horse power increases, we could also save on wire costs due to smaller wire gauge, circuit size, etc.
Now to the subject of locked rotor.  What is your converted motor (branch. circuit) current draw with a locked rotor?  Will your new control box shut down the motor if the rotor becomes locked?
OK, enough questions for now.  thanks
Post by: muggs on October 06, 2023, 03:27:32 PM
Quote from: Sod saw on October 05, 2023, 09:19:17 PM
.Lets see if I can clear up a few things.1.. the price includes the motor. 2.. I don't test for locked rotor. My service is not big enough. I would just pop the breaker. The 5 hp motor in my demonstration was the largest motor I had on a machine. I would not build a 5 hp motor. There is no advantage to it. Just buy a single phase motor. 3.. My controll box will not shut down the motor, that is the job of the magnetic motor starter overloads and now I can't type anymore.
Post by: Southside on October 06, 2023, 09:39:00 PM
Muggs, whatever magic you have figured out there I sure hope it has paid you well and it lives on for a long time.
Post by: muggs on October 07, 2023, 01:32:42 PM
Thanks for the kind words Southside. At age 75 I don't want a big business, I have been in business all my life. All I want is something to keep me busy and get me a little walking around money. I have not sold any so far. Shipping is very expensive. The big boys must get breaks that I can't get. Any ideas are welcome.
Post by: Southside on October 07, 2023, 09:09:17 PM
Advise?  Cut me in on the action, then we can have shipping from each coast and cut the cost in half!!!   :D
Post by: SawyerTed on October 07, 2023, 09:26:12 PM
Are Hotshot truckers still a thing?   Some of those guys have better rates.
I've used several to move some equipment and machinery but it was over 18 months ago.
Post by: Sod saw on October 10, 2023, 01:13:12 PM
Is it possible to get a patent on your process?  I am not a lawyer and have no idea what I am trying to say, here.
Can you protect your hard work and teach your methods (ideas) to younger folks who would be required to pay you a fee for each modification? ? ?   Sort of like paying a penny or two each time a song is played on the radio or a record is sold.  Maybe someone else can elaborate and clear up my thoughts.
Or just sell your process outright?  And still be able to retain the rights to putter?   The best of both worlds.
Is there any reason that the motor manufactures couldn't use your system (design) to make new motors that operate on single phase but still hold up to 3 phase abilities.  That may be asking a lot, but you would know better than those of us out here.
What documentation do you have from multiple independent testing labs (universities, etc) showing motors do not loose speed or ability to hold up to 3 phase specifications?
-just some random thoughts-
Post by: Southside on October 10, 2023, 01:20:26 PM
The concept you are speaking of would be licensing the process so others can perform the work while Muggs gets paid for his creation.  Eugene Stoner did exactly that with his AR platform.
Post by: Ljohnsaw on October 10, 2023, 03:37:16 PM
Pretty cool. I'm running my old planer with a 3hp ( or maybe 2, I don't remember right now) on 220 single phase on my 50 amp welder circuit. It boggs down at times. I can get 3 phase motors for free every now and then. Did I read it right that you have to do some magic on the motor as well as having the control box?
Post by: muggs on October 12, 2023, 11:21:44 AM
Quote from: Sod saw on October 10, 2023, 01:13:12 PM
No, I don't want a patent, ever since I got divorced, when ever I get close to a lawyer, I get the shakes >:(  All I want to do is sell a motor now and then. Motor manufacturers used  to build large single phase motors in the 30s and 40s for farm use. They just stopped doing it. Must have been a business decision.
Post by: muggs on October 12, 2023, 11:32:37 AM
Quote from: ljohnsaw on October 10, 2023, 03:37:16 PM
For your planer, if you separate the feed from the cutterhead, with a gearmotor, you will get more power to the cutterhead. I replaced  the reeves drive with.  a dc motor to get variable feed speed. The 3 phase motor is modified internally. In the future I will put a motor in the for sale section. It will have to be picked up locally, due to shipping being so expensive
