General Forestry => Sawmills and Milling => Topic started by: grweldon on October 05, 2023, 01:41:49 PM
Title: Alternative to awful Kohler fuel pump inside valve cover?
Post by: grweldon on October 05, 2023, 01:41:49 PM
After about 4 years of use on my 25HP Kohler (CH730) the fuel pump quit working.  I replaced it with a genuine Kohler and got another 4 years out of it.  These things are over $130 these days.  Last year I bought a cheap Chinese knock-off.  It lasted less than a year.
So I'm wondering if there might be an alternative type of fuel pump that any of you have used to replace your "less-than-ideal" original Kohler fuel pump and if so, how is it working out?
Thanks y'all!
Title: Re: Alternative to awful Kohler fuel pump inside valve cover?
Post by: Magicman on October 05, 2023, 01:43:53 PM
I can not help you with your fuel pump issue, but Welcome Home Glen.  8)
Post by: sawguy21 on October 05, 2023, 02:21:51 PM
How many hours on each pump?
Post by: chet on October 05, 2023, 02:51:03 PM
Don't know if you have electric start, but if you do, I would just switch to an electric fuel pump and be done. I've done it on quit a few small engines, the last being an Onan.
Post by: ladylake on October 05, 2023, 03:12:36 PM
 Get yourself a carter p60430 from ebay or amazon for under $40.  They last lots of hours.  There are cheaper pulse type ones but they dont last.  You need to mount it no more than 1 foot above the fuel tank.  steve
Post by: grweldon on October 06, 2023, 01:33:10 PM
Quote from: sawguy21 on October 05, 2023, 02:21:51 PM
About 40 on the first two original Kohler, about 5 on the Chinese knock-off.  I use ethanol-free fuel...always...  Thanks for the reply...
Post by: grweldon on October 06, 2023, 01:36:02 PM
Quote from: chet on October 05, 2023, 02:51:03 PM
Thank you for the reply. I do have electric start.  I was thinking about electric but wouldn't I need to have a return line?
Post by: grweldon on October 06, 2023, 01:42:42 PM
Quote from: ladylake on October 05, 2023, 03:12:36 PM
I just looked this up.  Sounds like it might be the way to go.  Other than hardwiring with a switch, I'm not exactly sure how else to wire.  Ignition switch is part of the engine.  Also, as I asked previously, wouldn't an electric have to use a return line to the tank?  Wouldn't the pressure at the float needle would be too great otherwise?  Thanks for your reply.
Post by: grweldon on October 06, 2023, 01:44:41 PM
Quote from: Magicman on October 05, 2023, 01:43:53 PM
Thank you Lynn!  I've been gone too long.  Not doing much sawing but I'm thinking real hard about preparing to!
Post by: Wlmedley on October 06, 2023, 02:56:31 PM
Don't know what would be causing pumps to fail so soon.I have the same engine in a welder and a cub cadet mower both with over 600 hours on each and haven't had a fuel pump failure. I did have one go bad and dump gas in my crankcase on a air compressor which was on a service truck but it also had a lot of hours on it.Replaced pump and changed oil and had no further problems.
Post by: grweldon on October 06, 2023, 05:53:52 PM
I would think that being stored outside uncovered has something to do with it. ;D
Post by: ladylake on October 06, 2023, 07:14:35 PM
Quote from: grweldon on October 06, 2023, 01:42:42 PM
I just looked this up.  Sounds like it might be the way to go.  Other than hardwiring with a switch, I'm not exactly sure how else to wire.  Ignition switch is part of the engine.  Also, as I asked previously, wouldn't an electric have to use a return line to the tank?  Wouldn't the pressure at the float needle would be too great otherwise?  Thanks for you  T
These fuel pumps are made for cars with no return lines and run at 5 or 6 # pressure.  Mine is diesel with a return line.  Mine seem to last around 4000 to 5000 hours, I did have one that didn't last very  long .  I tried those cheaper pulse type ones but never got more than a couple of month out of them Steve
Post by: esteadle on October 06, 2023, 07:21:12 PM
Post by: ladylake on October 07, 2023, 04:30:27 AM
 Just put on a good electric pump mounted down by the tank and bypass the engine pump. No need for 2 pumps.  Steve
Post by: moodnacreek on October 07, 2023, 09:43:52 AM
That is what everyone says. I have had worse luck with small electric pumps than diaphram  style. It seams that these days any non oem parts are worthless like coils, pumps, carbs, etc.
Post by: ladylake on October 07, 2023, 01:56:40 PM
 The carter 60430 is a rotary pump and last a long time, the pulse type ones dont last on my mill.  Steve
Post by: stihltoomany on October 07, 2023, 05:02:39 PM
Get pump with 2.5-4 psi. Should work fine no return needed.
Post by: grweldon on October 09, 2023, 07:43:39 AM
Thanks to all for your recommendations.  Looks like I'll most-likely go with the Carter that Steve (LadyLake) recommended.  I'll update when it gets done...might be a few weeks!
