General Forestry => Forestry and Logging => Topic started by: Trav the ax on October 06, 2023, 01:40:15 AM
Title: 648g2 park brake stuck
Post by: Trav the ax on October 06, 2023, 01:40:15 AM
Yesterday I tested the park brake coil which is gd cleaned and blew out the spool and sprayed the valve out with cleaner reinstalled with no luck. I'm going o che k the white wire eon the starter later today. I noticed a break in the plastic of a wire running to park brake and differential valve could this be ot or any other deas out there
Title: Re: 648g2 park brake stuck
Post by: kiko on October 06, 2023, 07:21:37 PM
Sounds like you have lost the transmission pump or have a suction issue.  Could also be that white wire to starter it is the ground f9r the park brake relay when not in the start position..
Post by: Trav the ax on October 12, 2023, 01:22:28 PM
Thanks for reply if it was the wires off starter would I still have power at the park brake solenoid when I tested with a meter
Post by: Trav the ax on October 12, 2023, 01:24:56 PM
Also when tested the valve oil shot out both places would it still for that if it was a pump f327 Ia a code I'm getting
Post by: Trav the ax on October 12, 2023, 05:08:23 PM
What would happen. If the pressure switch  is bad how do I test it
