General Forestry => Firewood and Wood Heating => Topic started by: Joe Hillmann on April 12, 2024, 09:04:36 PM
I have some 6 inch double wall pipe that I assume was on someones outdoor wood boiler that I want to clean up and use.
The problem is two of the sections are completely plugged up, there is no longer a hole in the middle of the pipe, it is COMPLETELY plugged up.
Some of it is sticky and tar-like, some it hard and glass like and some is burned to charcoal.
The problem is I don't know how to go about cleaning it.
I think the hard stuff can just be broken up with hammering.
But I need advice on how to clean of the tar like stuff. By the looks of it in some places it is 6 inches thick but for the most part is is probably an inch or so thick.
That stuff is creosote. Even if you get it unplugged, it will be a fire hazard.
Sounds to me like that chimney has had its day. What did you want to use it for?
set it on a stove OUTSIDE and get it warmed up. it will prob. catch fire, so this is not near any trees or buildings. the question would be, is it worth it? could try solvents. the burn method may advance the age and poss. ruin the pipe. be careful.
my 2 cents, all it is worth
use a 1/2 inch metal conduit pipe. make one end have a cutting edge, the other end into a powerful 1/2 inch drill
maybe use a propane torch to heat the pipe
punch holes around the inside of the chimney, then remove the center
then use the propane weed burner to burn the remainder. then scrape and scrape and scrape,,,,,,,
i use the propane weed burner on my Central boilers 750 and 760 HDX.
both to start the fire and later to clean the Furnace.
