General Forestry => Chainsaws => Topic started by: gman98 on May 20, 2024, 09:20:26 AM
Title: History of the Stihl 028
Post by: gman98 on May 20, 2024, 09:20:26 AM
Can anyone here tell us about the history of the Stihl 028's?  When they were built, what market/users were they designed for?  I got a couple of them a while back and they seem to be nice bulletproof saws.
Title: Re: History of the Stihl 028
Post by: Magicman on May 20, 2024, 02:14:06 PM
Sorry, no history from me except that I have had an 028AV since the 1980's.  It has to be one of the easiest cranking and sweetest running that I have ever had.  In a roundabout way it became my "farm property" saw and was replaced by my MS261.
For whatever reason I replaced the rim sprocket, bar, & chain to 7/32, which is something that I will not do on the MS261.
I googled and there is a good bit of information on the ArboristSite.com, for example;
Here are some 028 notes. There were three different bore sizes on the 28: 42mm (AV and WB), 44mm (Woodboss) and 46mm (Super, Super Woodboss, anything with Super in it). The ci are 2.92, 3.07, and 3.18 respectively.
Post by: Al_Smith on May 22, 2024, 03:21:53 PM
Magic i just noticed this "traveling man " I too am one .Hard to say about the 028 history .I have a wood boss  .Little brother to the three models of 038 plus 042 and 048 .Decent saw for the size though I must say .Not exactly bullet proof so to say but in tune a good steady fire wood saw .Taken proper care of  should last about a life time . I will have to admit mine doesn't see much run time simpley because I have faster and lighter saws in that class .
Post by: sablatnic on May 23, 2024, 07:37:45 AM
Quote from: Magicman on May 20, 2024, 02:14:06 PMFor whatever reason I replaced the rim sprocket, bar, & chain to 7/32, which is something that I will not do on the MS261.
7/32, is that the file size?
Post by: sablatnic on May 23, 2024, 07:39:21 AM
A link to a chainsaw site: https://www.acresinternet.com/cscc.nsf/GasbyManufacturer?OpenView&Start=1&Count=1000&Expand=145#145
Post by: Magicman on May 23, 2024, 07:51:13 AM
Quote from: sablatnic on May 23, 2024, 07:37:45 AM7/32, is that the file size?
Yes, file size.  At the time I was also using two other saws that used the same 7/32 file so I wanted them all to be the same.
That was not reason enough to change.  :uhoh:
Post by: YellowHammer on May 23, 2024, 11:46:34 AM
I had one for 30 years or more, but it got real cranky many years ago, and I had lots of trouble getting spare parts.
It was a very good saw, used around here at the time as the preferred rental saw.
Post by: Magicman on May 23, 2024, 03:32:00 PM
I put a top end, boot, and carb that came from sponsor Chainsawr on mine.  :thumbsup:
Post by: old 030 on May 27, 2024, 06:14:33 AM
IIRC the 028 came out in '77. I've owned a few over the years, my neighbor still owns and uses an early 028 that I repaired for him, it still runs strong. Here's a couple I re-did and sold several years ago.IMAG0031.JPG
