General Forestry => Drying and Processing => Topic started by: DocGP on September 11, 2024, 10:48:30 AM
Title: Chain lube inside of edger
Post by: DocGP on September 11, 2024, 10:48:30 AM
What are the thoughts on the best chain lube for inside the edger??
Would atf be as good as anything, or would a dry lube chain spray be better?
Thoughts appreciated.
Doc
Title: Re: Chain lube inside of edger
Post by: customsawyer on September 12, 2024, 06:33:31 AM
I just use ATF on my edger chains and the shafts that all of the collars slide on.
Post by: 240b on September 12, 2024, 07:07:42 PM
ive been using bar/ chain oil
on shafts an chains
seems to work
Post by: customsawyer on September 13, 2024, 06:59:04 AM
Any lube will help. I use the ATF as it is thinner and all of the sawdust doesn't stick to it, like it would with a thicker oil. I buy whatever is cheapest in 5 gal. buckets and put it in a pump up sprayer.
Post by: YellowHammer on September 13, 2024, 02:06:14 PM
I've been using cotton picker spindle oil
Really
I've got buckets of it
