General Forestry => Timber Framing/Log construction => Topic started by: Fred Pilkington on September 24, 2024, 06:57:18 AM
Title: Teak wood design values
Post by: Fred Pilkington on September 24, 2024, 06:57:18 AM
Hello!
I was wondering if I could get some insight into a historic post on this Forum please.
In 2012, Jim Rogers the moderator posted: " I used the values for teak of 1950 Fb for Maximum allowable fiber stress in bending. And 1.5 million in Modulus of elasticity. And also, 245 for shear parallel to grain, which is also known as Maximum allowable horizontal shear" (Link at bottom)
I would be extremely grateful if someone knows the source of these very helpful values! So I can understand them better and read around the subject.
The only (less useful) values I've found were from D W Green's 1999 book Mechanical Properties of Wood, Ch. 4.
Thanks!
https://forestryforum.com/board/index.php?topic=62341.0#:~:text=When%20I%20sized%20your%20rafters,as%20Maximum%20allowable%20horizontal%20shear.
Title: Re: Teak wood design values
Post by: Jim_Rogers on September 24, 2024, 09:39:29 AM
Back in those days, I did a design for that fellow FF member.
I consulted with my timber frame experienced structural engineer and he gave me the values as he determined them. Here is his values from my records.
Went through the quick and dirty ASTM approach to adjust from ultimate to design.  Assumed "#1" for grade factors.
Table 2. Mechanical properties of teak
Origin
M.C.
Static bending
Compression
Shear
MOR/Fb
MOE
Fc
Fcperp
Fv
Phrae PL
99.3*
84.0
10941
36.1
7.1
12.7
12183
1.6E6
5356
1030
1842
Phrae PL
11.4
104.0
11156
53.5
9.2
16.9
15084
1.6E6
7760
1334
2451
WH
Green
11600
1.4E6
5960
930
1290
WH
12%
14600
1.5E6
8410
1000
1890
Avg
Green
11892
1.5E6
5658
980
1566
Design
psi
1950
1.5E6
1400
700
245
Post by: Fred Pilkington on October 02, 2024, 11:24:13 AM
Thanks very much Jim! Super helpful
Post by: Fred Pilkington on October 07, 2024, 10:03:23 AM
Hi Jim,
I'm struggling to find information on the ASTM method for converting ultimate to design values. Please may you link or briefly explain how you make the conversions for FC and why you left MOE the same?
I understand that for MOR and FV, you've found a design value 6X less than ultimate which is what Chappell states.
Many thanks
Post by: Jim_Rogers on October 07, 2024, 06:09:03 PM
Quote from: fabpilkington on October 07, 2024, 10:03:23 AMHi Jim,
Fab:
I didn't do it my engineer did.
I'm doing some research through another engineer who did a presentation showing how to determine strength values.
I'll let you know when I know.
Jim Rogers
Post by: Jim_Rogers on October 08, 2024, 09:51:25 AM
Here is a link to a video showing the presentation of how to determine the values of the type of wood you want to use.
https://youtu.be/G0p-pMGUYqQ?si=1hIlP9FLVCgC7_Fn
Jim Rogers
Post by: Fred Pilkington on October 09, 2024, 06:55:12 AM
Thanks Jim for that video. Do you know where I could find ASTM D245 (Standard Practice for Establishing Structural Grades and Related Allowable Properties for Visually Graded Lumber) without the $75 fee?
Post by: Jim_Rogers on October 09, 2024, 10:02:44 AM
Quote from: Fred Pilkington on October 09, 2024, 06:55:12 AMThanks Jim for that video. Do you know where I could find ASTM D245 (Standard Practice for Establishing Structural Grades and Related Allowable Properties for Visually Graded Lumber) without the $75 fee?
No I don't.
Sorry can't help you with that.
Jim Rogers
Post by: beenthere on October 09, 2024, 04:00:46 PM
https://www.astm.org/d0245-22.html
Post by: Fred Pilkington on October 10, 2024, 06:49:32 PM
No problem's Jim, thanks for all your help!
@beenthere - *without* ;) :)
Post by: beenthere on October 11, 2024, 12:50:25 AM
Write to them and ask if you can get a free copy.
What is your purpose for using the standard?
You may find a Library that has a copy that you can access.
