General Forestry => Drying and Processing => Topic started by: JP Wazz on October 20, 2024, 02:29:49 PM
my kiln is built but i don't have fans yet. can i use the box to keep my wood out of the weather until I've fabbed up and installed the fan baffle? maybe for just a week or 2 or would that be bad for the wood?
As long as the wood is not green you should be fine.
Green lumber in a solar kiln w/o airflow will mold pretty extensively.
you can cover the roof with a tarp and then it is just a shed. you could get cheap box fans for some air movement.
Quote from: scsmith42 on October 20, 2024, 02:39:21 PMAs long as the wood is not green you should be fine.
This...
If the wood is air dried (under 20%) then it won't grow mold or fungus, even if there is no airflow. But if it's still green, better to leave it outside until you get the fans hooked up.
