General Forestry => General Board => Topic started by: SawyerTed on October 31, 2024, 02:28:32 PM
Title: RV CO and Propane Detector
Post by: SawyerTed on October 31, 2024, 02:28:32 PM
(https://forestryforum.com/gallery/albums/userpics/48503/IMG_3233.jpeg) (https://forestryforum.com/gallery/displayimage.php?pid=356455)
This (insert adjective) THING is a carbon monoxide and propane detector.   Last Sunday morning about 12:20 am, it began beeping every 40 seconds.  Along with the infernal beeping was a plethora of flashing LEDs.
I couldn't reset it and had to resort to reading the manual in the wee hours of the night.  To shut the thing up, I had to disconnect the wiring.
It turns out these things only last a few years.  That one said 7 years.  When they reach their end of life, they beep and flash.
Who knew?
Now the replacement says five years until end of life for it.
(https://forestryforum.com/gallery/albums/userpics/48503/IMG_3239.jpeg) (https://forestryforum.com/gallery/displayimage.php?pid=356456)
Title: Re: RV CO and Propane Detector
Post by: Magicman on October 31, 2024, 03:13:15 PM
Remember that a dog fart will set it off.
Post by: SawyerTed on October 31, 2024, 03:32:45 PM
ffcheesy  ffcheesy ffcheesy
So will aerosol sunscreen. It uses propane for propellant.
Post by: Ron Scott on November 02, 2024, 06:59:57 PM
Learned this the hard way also. The carbon monoxide detectors only last 7 years and now 5 years. They will beep constantly when time is up.
I've now underlined this in the instruction's pamphlets.
Post by: doc henderson on November 02, 2024, 10:53:42 PM
Ron, did you mean CO (carbon monoxide)?
Post by: SawyerTed on November 03, 2024, 05:36:25 AM
Alcohol of a certain proof will set off the detector too!   Tragically, I spilled a few ounces of some homemade and the detector let me know I messed up.
I stuck a label with the install date on the front of the new one and put a reminder in my phone's calendar to change it out in 2029.
Post by: dougtrr2 on November 05, 2024, 07:09:46 AM
I had a detector go off.  In hindsight it was a false alarm.  But I took it down while beeping, saw a switch on the back that said "Deactivate".  Flipped the switch and all was quiet.  In the light of day I did my research.  The detector was a 10 year life that had only been up 5.  But once you hit the deactivate switch, you cannot turn it back on.
Doug in SW IA
