General Forestry => Forestry and Logging => Topic started by: tberry on July 01, 2025, 10:01:01 PM
Title: gearmatic 119 backlash
Post by: tberry on July 01, 2025, 10:01:01 PM
I have my gearmatic 119 out of the TJ 240E and Im thinking about changing all the bearings while i am working on the clutch and brake.
I need to get the end play and backlash specs for the ring and pinion so if i have to shim the pinion i will set it up right. does anyone have these specs?
I also have beel looking for a bearing and seal kit for this winch. does anyone have a source where i can get a kit or do i have to get the bearings and seals individually( is it cheaper to do it that way.
Im going to do the winch first and then tackle the transfer case
Title: Re: gearmatic 119 backlash
Post by: BargeMonkey on July 02, 2025, 01:14:18 AM
Harold's -  Randy Nason. About the best place I know to go for older parts. 207-942-8331  he should have whatever you want. Get all my 440D winch parts from him.
Post by: tberry on July 03, 2025, 09:52:04 AM
Thanks Barge
onkey, I will give him a call
