General Forestry => General Board => Topic started by: sprucebunny on November 19, 2005, 09:32:24 PM
Title: Ice things ?
Post by: sprucebunny on November 19, 2005, 09:32:24 PM
I don't know what this kind of formation is called. Rime came to mind but that is more ' ice deposited by wind' ..... I think...
It happens in the spring and fall . When the ground freezes it seems to squeeze the water out and these upsidedown icicles form ;D
(https://forestryforum.com/gallery/albums/userpics/11412/jmicethingsOP.jpg)
(https://forestryforum.com/gallery/albums/userpics/11412/jmicethings1OP.jpg)
Title: Re: Ice things ?
Post by: Paul_H on November 19, 2005, 09:35:17 PM
That is Buck ice.Did you know that Ohio is the Buck ice state?
Yes,it's very common there.
Post by: Frank_Pender on November 19, 2005, 09:39:14 PM
Quick thinking, Paul.  I do not care what Carla said about you being a bit late on things, when you were down this way a few months ago. 8)
Post by: chet on November 19, 2005, 09:40:35 PM
I hate ta be da one ta disagree with ya Paul but, it looks more like New Hampshire Buck Ice.   :P
Post by: Paul_H on November 19, 2005, 09:43:31 PM
Since when have you hated disagreeing with me Chet?  :D
Post by: chet on November 19, 2005, 09:46:32 PM
  :o   ;D
Post by: Quartlow on November 19, 2005, 10:32:56 PM
I don't know what kind of ice that is but I'm going to hang out witht the bunny, she's got money just laying around!!  :D :D :D
Post by: sprucebunny on November 19, 2005, 10:36:21 PM
It don't grow on trees where you are ??? :D
Yup...fall's the time to rake it up :D
Post by: Fla._Deadheader on November 19, 2005, 10:37:12 PM
 Buck ICE ???  Ohio the Buck ICE State ???  ::) ::) ::)
 That looks like the first freeze and partial thaw, when I youster was a "yankee".  :-[ :-[ :-[ ;D
Post by: isawlogs on November 19, 2005, 10:44:15 PM
Those are really cool pics Joan .
But gotta say I dont got a clue to what they are called ... Icycles for what its worth  ;D
Harrold .. you yousta be a Yankee ....  :o  :o :o  and are admitting ti it   ::) ::) ::) ;D
Post by: Fla._Deadheader on November 19, 2005, 10:48:34 PM
Dat's rite, Marcel, but, I converted just as quick as I could.  Them Arkansaw folks hepped us immensely, and adopted our family as true converts.  ;) ;)
Post by: isawlogs on November 19, 2005, 10:57:32 PM
 :D :D :D :D :D :D :D ;)
Post by: chet on November 19, 2005, 11:39:52 PM
Bunny,
I have aways known them as Frost Columns. But I don't know if that is the proper name for them.  :-\
Post by: sprucebunny on November 19, 2005, 11:54:41 PM
Thanks, Chet.
They fascinate me . I think they ought to have a special name from a fairy tale or something.
They appear overnight and vanish quickly and have such a delicate and variable structure.  :)
Post by: Fla._Deadheader on November 20, 2005, 12:11:23 AM
  Kinda related to Hoar Frost. Here's a write up, sorta.
   Frost often appears as a light feathery deposit of ice, often of a curious and delicate pattern. The dates on which killing frosts (frost destructive to vegetation and staple agricultural products) occur vary considerably.
Post by: Paul_H on November 20, 2005, 12:15:41 AM
I was thinking Hoar frost too but from a google search tonight,it looks like we tend to use it as a blanket term here.
SB,
Do the columns sound like breaking glass/plastic when you step on it?
Post by: CHARLIE on November 20, 2005, 12:19:40 AM
Dat ain't Hoar Frost as I know it FDH.  Hoar Frost appears on bushes and trees, usually on a real cold foggy morning when the moisture freezes on the branches and twigs. It's real pretty and resembles a flocked tree.  Dem Tings Sprucebunny took a picture of are pure ice.  Note:  I'm trying ta write so Chet can unnnerstan.
Post by: sprucebunny on November 20, 2005, 12:23:00 AM
Yup....pretty crunchy :D
Next time I see them I'll be sure to get closer and poke them with a stick. Might sound different than just stepping on them :D
Hoar frost and rime ice form on THINGS....
Post by: Fla._Deadheader on November 20, 2005, 12:38:15 AM
Not necessarily, according to the info I googled up  ::) ::) ::)
  It also stated that it is formed from moist gasses that rise from Things, grass, leaves, etc., and forms little delicate columns of "HOLLOW" stemmed structures, rising from the ground ???  ::) ::) ::)  I forgot all them "Yankee" things, long ago.  ::) ;D :D :D :D
Post by: Ianab on November 20, 2005, 01:57:42 AM
We get that sort of frost a lot here.
It usually forms on moist dirt areas, and because it usually melts every day it doesn't get that long.
If it forms on bare clay it usually lifts a crust of loose dirt and moss on the ends of the crystals.
Then it melts during the day and turns the otherwise dry track into a slippery mess of mud and ice  ::)
I think FDH has got the right reference, it seems to form here from moisture escaping out of the soil.
Cheers
Post by: sprucebunny on November 20, 2005, 06:44:15 AM
You left that part out the first time , Harold . Moisture rising would explain it. I'll have to beep in on it and see if it's hollow.
Ya, Ian, I've seen it lift up a layer of moss or dirt.
So what is the origins of the term " hoar frost" ? I still think it should have a more magical name ;D
Post by: crtreedude on November 20, 2005, 07:04:51 AM
I used to see this kind of ice in the spring when the ground was soaked and then it turned cold again.  I also used to see it in the fall when I was hunting. I think you all are right about the source. Their is a mist rising because the ground is warm, and then it freezes.
We don't see that down here...  ::)
Post by: SwampDonkey on November 20, 2005, 08:15:15 AM
I agree with Chets explanation with the emphasis on frost. ;D It's a big problem with certain types of plantation scarification where all the litter and fermation layer is scalped off the topsoil. I've seen the frost pop the trees out of the ground as if the seedling was just throwed on the ground. To prevent it there has to be a good bunch of organic mixed in the soil or a thin layer of duff. :o
Post by: Tom on November 20, 2005, 08:24:34 AM
I saw that phenomenon back in '64 or so in Athens Georgia.  That was back before the turn of the century and almosst forgot.  We had snow that year too. :)
Post by: chet on November 20, 2005, 09:13:04 AM
I did a little diggin'  :P  Check out the third picture down on the left Frost Column (http://www.nps.gov/yell/slidefile/water/icesnow/page.htm).
Post by: sprucebunny on November 20, 2005, 09:14:55 AM
SECURITY VIOLATION !!!!!!!!
What did you get me into, Chet ???
They'll be comin' for me, now  :o
Never mind ::) It worked. Thanks, Chet
Post by: chet on November 20, 2005, 09:17:04 AM
I must have a higher security clearance.  :)
Post by: sprucebunny on November 20, 2005, 09:23:06 AM
Third row down far right looks JUST like them but the ones you spotted have neat headgear on ;D
The security guys were VERY worried that I was packin' an unlawful item of punctuation :D
Post by: chet on November 20, 2005, 09:26:44 AM
they got ta be really careful around dem government sites.  :D  ;D
Post by: SwampDonkey on November 20, 2005, 10:35:10 AM
I got ejected errrr was I a reject  ::)
Post by: iain on November 20, 2005, 12:02:18 PM
I've never seen that kind of formation, it sure looks nice
any one tried ice painting?
    iain
Post by: Fla._Deadheader on November 20, 2005, 12:04:32 PM
  Not lately. All the little square chunks keep disappearing  ??? ::) ::) ;D ;D
Post by: iain on November 20, 2005, 12:47:23 PM
No its using water colour wet on wet then lay it out in the frost to slowly freeze
the ice patterns form in the paint and fix when it dries
i'll ask Linda when she pops up for air
iain
Post by: Fla._Deadheader on November 20, 2005, 01:08:13 PM
That sounds interesting.  8)  Got any photos ??
Post by: Paschale on November 20, 2005, 05:33:07 PM
hey Joan...
Here's a little poetic reference to "hoar frost" with a fairyland type theme for ya...   :)  This woman must have felt the same way about hoar frost as you do.   :)
I found it on http://www.Bartleby.com, a very cool website.
34. Fairyland
By Anne Glenny Wilson
DO you remember that careless band,
Riding o'er meadow and wet sea-sand,
  One autumn day, in a mist of sunshine,
Joyously seeking for fairyland?
The wind in the tree-tops was scarcely heard,         5
The streamlet repeated its one silver word,
  And far away, o'er the depths of woodland,
Floated the bell of the parson-bird.
Pale hoar-frost glittered in shady slips,
Where ferns were dipping their finger-tips;         10
  From mossy branches a faint perfume
Breathed o'er honeyed clematis lips.
At last we climbed to the ridge on high.
Ah, crystal vision! Dreamland nigh!
  Far, far below us the wide Pacific         15
Slumbered in azure from sky to sky.
And cloud and shadow across the deep
Wavered, or paused in enchanted sleep,
  And eastward the purple-misted islets
Fretted the wave with terrace and steep.         20
We looked on the tranquil, glassy bay,
On headlands sheeted with dazzling spray,
  And the whitening ribs of a wreck forlorn
That for twenty years had wasted away.
All was as calm, and pure, and fair,         25
It seemed the hour of worship there,
  Silent, as where the great North Minster
Rises for ever, a visible prayer.
Then we turned from the murmurous forest-land,
And rode over shingle and silver sand,         30
  For so fair was the earth in the golden autumn,
We sought no farther for Fairyland.
Post by: sprucebunny on November 20, 2005, 08:11:35 PM
Thanks, Paschale  :)  That's a very nice poem. It's been quite a while since I read any peotry. The rythem can be very soothing and that author sure made me visualize the forest ;D
Post by: Texas Ranger on November 20, 2005, 09:46:26 PM
Ah, Sprucebunny, we don't have stuff like that in my part of Texas, but if ya got a Scotch Tree that grows up there, I could  be convinced to relocate!!!! 8)
Post by: Paschale on November 20, 2005, 11:59:30 PM
Quote from: sprucebunny on November 20, 2005, 08:11:35 PM
I don't read poetry either, though when I did a search for "hoar frost" on that site, I thought it was really interesting that one of the first things it came up was this poem that talked about something you talked about--that it should come from a fairy tale.  So I thought I'd post it--gotta add a little culture from time to time!    ;)
Post by: SwampDonkey on November 21, 2005, 07:31:13 AM
I be cultured.  :D ;) ;D
Post by: crtreedude on November 21, 2005, 08:07:11 AM
It is okay SwampDonkey - you will recover...
Post by: Paschale on November 21, 2005, 08:43:16 AM
Quote from: crtreedude on November 21, 2005, 08:07:11 AM
Thank God!   :D :D :D :D
Post by: iain on November 21, 2005, 12:49:21 PM
Deader i will ask the one with the "talent " in the family to sort it out for you
iain
Post by: Modat22 on November 21, 2005, 12:57:27 PM
speaking of ice things, heres a few cloud based phenomina cause by little ice crystals.
Pretty stuff.
http://flatrock.org.nz/topics/environment/sun_pillars.htm
Post by: SwampDonkey on November 21, 2005, 03:14:06 PM
Yeah we sometimes get ice crystalls (no not snow) in the air right before a winter thaw spell.
Post by: pappy on November 21, 2005, 07:45:25 PM
Quote from: iain on November 21, 2005, 12:49:21 PM
iain
iain, could you do that fer me too... please..please  :D :D :D
Post by: pappy on November 21, 2005, 08:05:32 PM
Quote from: SwampDonkey on November 21, 2005, 03:14:06 PM
OR when the air temp drops below -40F and the moisture in the air crystallizes  on a beautifull clear winters night  ;)
Post by: SwampDonkey on November 22, 2005, 08:11:05 AM
Quote from: pappy on November 21, 2005, 08:05:32 PM
That's what sometimes happens here, it will drop to -30 or colder then in a couple of days it's raining.  ::)
Post by: Fla._Deadheader on November 22, 2005, 08:27:29 AM
Thanks Iain. Sounds really interesting. Not that I could ever try it in CR, but, I like to see other peoples talent.
